Hi Rosemary
In an electrolyser, the cathode supplies the electrons, hence is negative so attracts the protons. Vice-versa with the anode.
I take it then that you assumed that the cathode attracted -ve charges!
Pulsed dc works just fine, after all it's just switching dc on and off. Some people claim to get better efficiency by doing this. Why this is appears to be the case is open to debate.
AC electrolysis has been documented, but not reliably proven and is another area of great contention on these forums. As of course is Stanley Meyers, supposed dissociation of water by voltage alone.
Harvey
Not exactly sure what you're asking here. But I can say that you can use litmus paper to determine the proximity of the cations at the cathode and anions at the anode. The litmus paper indicates the water is more acid at the cathode and more alkaline at the anode. Can be a good indication of the whereabouts of ion concentrations.
Something I've never looked into, but some people claim that the gas produced by an electrolyser is not the more common forms of O2 and H2. Most of what I've read on the forums however, is based on nothing more than heresay - rumbles through the grapevine. Though, with all the recent talk about gas processors, you'd think someone might have mentioned these states of oxygen... wouldn't you?
Farrah
Harvey
I would also like to see some mention of what pH really is and how it relates to this process and how it was used to prove the chemical reactions involved.
The thing that intrigued me the most in this discussion is the valence bonding of H2 and O2. The stable ground state of Oxygen is Triplet Oxygen which is paramagnetic, but there is also a form of O2 that is less stable known as singlet oxygen which is diamagnetic.
Farrah
and this gives us 4H and 4O. Two of the O join to make O2 and the other two each join with two H to may H2O. Again timing is only needed to grab those electrons and then we allow the electrode to return to neutral and we wait. We wait for the O2 to escape. (good thing Oxygen is heavier than Hydrogen or they may rejoin up there above our solution given an opportunity to oxidize - aka burn). So we get a layer of hydrogen above a layer of oxygen that can be siphoned off laterally.
