take look at this web site
Atomic Hydrogen Source - thermal hydrogen cracker
Atomic Hydrogen as a Fuel
William Lyne
William Lyne will be speaking at the conference!
It will be a rare opportunity to spend some time with this legend. He is the author of multiple books including Occult Ether Physics and is well known for his work with Atomic Hydrogen Torches.
In several interviews, Eric Dollard has said many of the aetheric concepts that William Lyne shares are valid - much is rooted in the works of JJ Thompson and Tesla. This is a presentation you'll want to see!
You can find his full bio and talk description here: 2014 Energy Science Conference
prevent formation of water molecule
Just looking through some old threads.Originally posted by wojwrobel View Postbut when im listening Meyer lecture Stanley A. Meyer The Safe Free Energy Conference Einsiedeln_Switzerland-1989 mostly from 39:44 to 41:30 i came to idea that what we sould do is to prevent recombination off hydrogen and oxygen to form water to get more energy right?
so what hes saying is to ,after water separation, hydrogen and oxygen sould be energized to create bigger than normal charges in nuclei to weken the attraction force with electron so it will not be in stable state and will not recombine to form water molecule wich will result in combustion in even higher energy output .
Yes - prevent the formation of water molecule by adding ionized nitrogen though. H and O will go to the reactive atomic nitrogen instead of to each other. That prevents the formation of the water molecule and that allows you to get the thermal combustive energy from the hydrogen. It slows the burn and lowers the temp so the water gas is more like gasoline.
Interstellar hydrogen
I found an interesting article on hydrogen. This is the closest thread that I could find.
River of hydrogen flowing through space observed -- ScienceDaily
God created the earth and all that is in it from WATER.
People tend to have a misguided belief that the Bible is some fairy tale but I will tell you right out that the Bible is the only Truth in this world. It is the divine word of God and without it, no one can know the truth of why we are here and what it's all about.
All things were created by God from water. Water is not simply H2O but the first matter of generation for all other matter.
Forget your microwave ovens, forget whatever anyone claims.
Trust in God alone and know that water can create ANY matter because that is where it all came from.
But if one don't read their Bible or desire to know God, what is the point of explaining things any further to that person.
Matthew 6:19-21
Lay not up for yourselves treasures upon earth, where moth and rust doth corrupt, and where thieves break through and steal:
But lay up for yourselves treasures in heaven, where neither moth nor rust doth corrupt, and where thieves do not break through nor steal:
For where your treasure is, there will your heart be also.
Final Events of Bible Prophecy - YouTube
Originally posted by Lightworker1 View PostInteresting thought. I will like do do the experiment myself. However from the choice of your thread name, it appears that conversion of SiverToGold is also your passion. If you have any info, it will be appreciated. Like oil, gold also creates divided humanity. I have come across one statement, "It is possible for example, to convert Tin to Gold plus one other element (may be catalyst) in a microwave oven." Some years back, I was thinking of using microwave oven to create (replicate) room temperature ceramic super-conductors.
So microwave oven can be very useful tool. Thanks.
Warmest regards
lightworker
Hello @Aaron on the subject Atomic Hydrogen, JL Naudin has conducted some excellent work. In one of the experiments, ONE HOUR tests with a COP of 21, was seen. Full tests of the MAHG by JL NaudinOriginally posted by Aaron View PostMaybe, I was only quoting that from a reference. Other references show
416 J, etc... it depends on whose book you read.
Lyne's work is not infallible.
In any case, this concept is in the context of dissociating h2 to h with an
arc.
Nh3 production route then cracking ammonia doesn't require as much,
which will ultimately give atomic hydrogen where it needs to be when
only starting with air and water.
The Moller's Atomic Hydrogen Generator
Also, I few days back, presented on your other thread, "SUPERLIGHT" , post #8
I hope, it will be interesting
Warmest regards
lightworker
Interesting thought. I will like do do the experiment myself. However from the choice of your thread name, it appears that conversion of SiverToGold is also your passion. If you have any info, it will be appreciated. Like oil, gold also creates divided humanity. I have come across one statement, "It is possible for example, to convert Tin to Gold plus one other element (may be catalyst) in a microwave oven." Some years back, I was thinking of using microwave oven to create (replicate) room temperature ceramic super-conductors.Originally posted by SilverToGold View PostFrom William Lyne's book "Occult Ether Physics"
1) From Van Nostrand's Encyclopedia of Science
So,
is not correct! It's only about 412 J to disassociate the H2 into 2 H's atoms !!! This is where the extra energy comes in from the vacuum and what makes this process have an optimal energy gain of about 1000 times the input.
Warmest regards
lightworker
Zero-Point is present
Hi guys,
unfortunately I have no background in physics but I found the following interesting statements on wikipedia when i looked for monoatomic hydrogen and the lamb shift:
'There are always vacuum fluctuations of the electromagnetic field, according to quantum mechanics. Due to such fluctuations degeneracy between states of the same j but different l is lifted, giving them slightly different energies. This has been demonstrated in the famous Lamb-Retherford experiment and was the starting point for the development of the theory of Quantum electrodynamics (which is able to deal with these vacuum fluctuations and employs the famous Feynman diagrams for approximations using perturbation theory). This effect is now called Lamb shift.'
'In 1947 Willis Lamb and Robert Retherford carried out an experiment using microwave techniques to stimulate radio-frequency transitions between ^2S_{1/2} and ^2P_{1/2} levels of hydrogen.[3] By using lower frequencies than for optical transitions the Doppler broadening could be neglected (Doppler broadening is proportional to the frequency). The energy difference Lamb and Retherford found was a rise of about 1000 MHz of the ^2S_{1/2} level above the ^2P_{1/2} level.'
Moray King mentioned that quite often but it's nice to read it in the mainstream, too. Keep it coming guys this thread is interesting.
btw Defkalion is also mentioning monoatomic hydrogen in this article: http://dl.dropbox.com/u/5905445/Ener...121102_ENG.pdf
Prato
Atomic hydrogen in an internal comb.engine
Nice info, thanks.
May i conclude that if we use H2 as a fuel, use that in an engine, use an ac spark, which reverses polarity, we can have an engine running on atomic hydrogen?
Adding some waterdrops, because of the enormous heat, we get some extra power?
Steve
Miller also made a AHW unit, Model #100HVAP, and the owners manual with circuit diagram can be downloaded from their website:
Miller - Owners Manuals
There was a discussion on this unit, and the G.E. AHW unit, that was discontinued back in the late 1970's:
Atomic Hydrogenatomic hydrogen torch, nascent hydrogen torch or Langmuir torch. The process was also known as arc-atom welding."
Atomic hydrogen welding - Wikipedia, the free encyclopedia
To weld thin metal the video said 35 amps was needed and that there was a chart for welders to look up the amp setting and tungsten gap settings for the particular weld job.
Now is there was a way to create the arc at lower voltage, then maybe we can convert current TIG or AC plasma unit to an AHW Unit?
CheersLast edited by vrand; 12-09-2012, 07:05 AM.
Very interesting lost technology, here are some videos from 1943 that just came out recently on the G.E. Atomic Hydrogen Arc Welder unit used back in the 1940's
The Inside of Atomic Hydrogen Arc Welding, Part 1 - 1943
The Inside of Atomic Hydrogen Arc Welding, Part 1 - 1943 - YouTube
The Inside of Atomic Hydrogen Arc Welding, Part 2 - 1943
The Inside of Atomic Hydrogen Arc Welding, Part 2 - 1943 - YouTube
Published on Oct 16, 2012
Instructional film on atomic hydrogen arc welding, a method of precision welding especially useful for light materials. Two tungsten electrodes, hydrogen gas flame surrounds arc. Arc changes hydrogen to atomic form, heat generated when atoms recombine. Includes John McGee, the cartoon character from other instructional films.
in this video i am using hydrogen and oxygen derived from water to cut through aluminum, steel and other materials. the oxyhydrogen flame possesses many interesting characteristics.
please watch:
YouTube - ‪Water Fuel Oxyhydrogen Gas Torch‬‏
many have stated that the flame is electrical in nature - i will try to test for and measure this electrical voltage potential of the flame today
best,
alex
alex petty
email: [email protected]
skype: alex.petty
mobile: +001.540.272.7970
Regarding the degree or level of radiation. It is not clear what is the safety
guidelines for the many varieties of hydrogen technologies.
And which of those technologies would require security measures.
As you can see on the news with the recent Japan nuclear disaster
While clearly on the opposite side of the earth there has been panic
behavior ; runs on potassium iodide tablets and other bazaar disaster frenzies.
These are some of subconscious reactions by entrainment from internet and TV.
I believe some effort in understanding some of this background radiation
terminology and data that health and safety gives would help define what
is considered safe levels.
When we get a medical xray our health officials refer to millirems per year average statistical data.
or
Radiation dosage is measured in millisieverts (Sv)
and then there are also Soft Xrays
As part of education of hydrogen technologies public understanding and safety by public forum.
I believe safe hydrogen has little or no radiation but are confounded by the "atomic" misunderstanding.
It would be helpful to have an informative utube aimed specifically on distinguishing
safe hydrogen and how we can be reasonably certain it is safe.
In order to help current and future safe hydrogen experimenter become successful faster.
A good utube may be helpful on the subject.Last edited by mikrovolt; 03-21-2011, 01:29 AM.
I thought I'd add my last post that I made in the "Atomic hydrogen furnace with COP of 21" thread. As it's relevant here, even if the use for atomic hydrogen isn't furnace related.
I'd like to make this a reference post, so can others check my calculations, the basis of my calculations, and my reasoning/conclusions.
Start of: Basis of my calculations:From en.wikipedia.org/wiki/Calorie :
One gram calorie is approximately:
1 mole is about 12g - based on the weight of a mole gram of Carbon. Hydrogen is 1/12 the mass of Carbon: 1 gram. Based on the following: en.wikipedia.org/wiki/Mole_(unit)
The following is from sciencegeek.net/Chemistry/taters/Unit5MolarVolume.htm :
More power = bigger reaction chambers (unless you start to pressurise the hydrogen gas).
Bigger reaction chambers = less splitting and recombining of the hydrogen to get the same amount of output.
