Originally posted by Vickers
Ionization & Water Fuel
Complete Micronic System
Micronic System is ready!!
In the next days the test results ...
[img=http://img245.imageshack.us/img245/9409/dscf1437.th.jpg]
[img=http://img714.imageshack.us/img714/4971/dscf1438n.th.jpg]
[img=http://img716.imageshack.us/img716/5919/dscf1439n.th.jpg]
[img=http://img841.imageshack.us/img841/2540/dscf1440.th.jpg]
[img=http://img101.imageshack.us/img101/2048/dscf1441.th.jpg]
[img=http://img201.imageshack.us/img201/5936/dscf1442.th.jpg]
[img=http://img266.imageshack.us/img266/3061/dscf1443l.th.jpg]
[img=http://img844.imageshack.us/img844/3984/dscf1444y.th.jpg]
[img=http://img839.imageshack.us/img839/7247/dscf1445.th.jpg]
[img=http://img409.imageshack.us/img409/866/dscf1446.th.jpg]
[img=http://img836.imageshack.us/img836/5048/dscf1447.th.jpg]
[img=http://img715.imageshack.us/img715/6107/dscf1448y.th.jpg]
[img=http://img829.imageshack.us/img829/333/dscf1450s.th.jpg]
[img=http://img413.imageshack.us/img413/1855/dscf1451w.th.jpg]
[img=http://img819.imageshack.us/img819/6515/dscf1452u.th.jpg]
[img=http://img291.imageshack.us/img291/4153/dscf1453b.th.jpg]
[img=http://img705.imageshack.us/img705/1820/dscf1454z.th.jpg]
[img=http://img832.imageshack.us/img832/6061/dscf1455y.th.jpg]
[img=http://img441.imageshack.us/img441/8310/dscf1456k.th.jpg]
[img=http://img833.imageshack.us/img833/7937/dscf1457.th.jpg]
[img=http://img442.imageshack.us/img442/4282/dscf1458q.th.jpg]
[img=http://img44.imageshack.us/img44/3144/dscf1459z.th.jpg]
[img=http://img688.imageshack.us/img688/772/dscf1460m.th.jpg]
[img=http://img245.imageshack.us/img245/2060/dscf1461u.th.jpg]
[img=http://img51.imageshack.us/img51/3199/dscf1462.th.jpg]
[img=http://img201.imageshack.us/img201/604/dscf1463r.th.jpg]
[img=http://img245.imageshack.us/img245/6499/dscf1464m.th.jpg]
[img=http://img375.imageshack.us/img375/8032/dscf1465s.th.jpg]
[img=http://img291.imageshack.us/img291/6807/dscf1466d.th.jpg]
[img=http://img44.imageshack.us/img44/5041/dscf1467.th.jpg]
[img=http://img291.imageshack.us/img291/4440/dscf1468i.th.jpg]
[img=http://img839.imageshack.us/img839/345/dscf1469.th.jpg]
[img=http://img202.imageshack.us/img202/2329/dscf1470.th.jpg]
[img=http://img338.imageshack.us/img338/2835/dscf1471t.th.jpg]
[img=http://img153.imageshack.us/img153/7007/dscf1472d.th.jpg]
[img=http://img823.imageshack.us/img823/9383/dscf1473.th.jpg]
[QUOTE=tutanka;105826]Micronic System is ready!!
[url=http://img245.imageshack.us/my.php?imag[/QUOTE]
Thank you for the update Tut
Looks impressive and complicated. What type of tests will you be performing?
Keep up the good work!
Thanks, Mike
Hello, what are the 3 tubes with holes in them? Are they homemade high voltage diodes?
In effect system is an little complicatedOriginally posted by vrand View PostThank you for the update Tut
Thanks, Mike
We need to start new efficency test. Probably, adding a new low power stage, we have increased a lot the efficency convertion of nitrogen and water into NH3 and N2O that actually is 81.375% per mole of N2 . Regards
Interesting, looking forward to the test results.Originally posted by tutanka View PostIn effect system is an little complicated
I see that you use bottled N2 gas? Can you make your own N2 gas?
To run a 18HP engine electrical generator set, how much N2 gas will be needed?
Thanks, Mike
HI Fabio,Originally posted by sebosfato View PostHi alex,
Can you tell us the name of the components?
What are the gray tubes for? The ones with spark plug yellow and red cables going out from it.
Did i recognize well? Are you passing the nitrogen thru spark plugs?
I have changed method an semplify a lot.. with plug you don't have enough time for ionization, more visible vapour go out freely.. now I use an resonance NTP as pre ionizer stage in association with an UV stage first to send nitrogen/water inside reactor for eliminate the dangerous condense and obtain an special transparent gas mixture..Last edited by tutanka; 08-05-2010, 04:00 PM.
