Ionization & Water Fuel
Hi Aaron - I have finally finished reading through the whole thread. Wow - very interesting. I believe you, Tutanka and likely many others of like mind are on the right path. I am one of those that totally believed the Meyer's stuff for years. Having built a WCF based on his patents I can vouch it doesn't work - at least not based on the information as-is in the patent(s) for the purpose of running an engine. It has been a good learning experience though.Originally posted by Aaron View PostSo it it helps a reaction but doesn't get changed itself, it's usually
referred to as being something very specific even though it may not be
technically considered that.
As soon as I got to the point of the incoming air stream being ionized as suggested in this thread, the lights came on for me! I picked up materials over this weekend to start creating my own experimental work. I'll keep everyone posted as progress (or regress?? lol) is made!
You must be thinking of tungsten as a *catalyst* in this reaction, no?
Cheers!
I hope u dont mind me butting in here Powerman... Can u tell me what kind of engine u are trying to run?Originally posted by Powerman View PostHi Aaron - I have finally finished reading through the whole thread. Wow - very interesting. I believe you, Tutanka and likely many others of like mind are on the right path. I am one of those that totally believed the Meyer's stuff for years. Having built a WCF based on his patents I can vouch it doesn't work - at least not based on the information as-is in the patent(s) for the purpose of running an engine. It has been a good learning experience though.
Cheers!
Hi Vickers - no probs jumping in. I have a few engines at my disposal. A couple of Briggs & Stratton 3.5HP lawnmowers, a 6HP Lawntop 3.0kW generator, a 3.8L Pontiac V6 , and a 1981 460CID Ford V8. The vehicles are still running. All of these engines run on gasoline.Originally posted by Vickers View PostI hope u dont mind me butting in here Powerman... Can u tell me what kind of engine u are trying to run?
So far my sights are set on the 6HP Lawntop to start with. It's a single cylinder. Not sure of the exact displacement but personally I think it's got to be less than 400cc.
No because as I have written is very dangerous and that method can't pass with governative authorizations, at the same time that is the reason because Meyer have created injector plug. That component have double function.. wfc and arcjet at the same time.. water fuel is composed from excited ions but isn't an burnable mixture, is sended inside first stage (wfc) and transformed in N2H4/N2O and sended directly to second stage (arcjet) connected in combustion chambre. Using similar wfc method (but not arcjet) and use other type of water with different PH you can create with success NH3/N2O as gas and send inside engine. RegardsOriginally posted by vrand View PostDo you use a plasma arc?
RegardsLast edited by tutanka; 06-07-2010, 10:45 PM.
Ahh ok, thanksOriginally posted by tutanka View PostNo because as I have written is very dangerous and that method can't pass with governative authorizations, at the same time that is the reason because Meyer have created injector plug. That component have double function.. wfc and arcjet at the same time.. water fuel is composed from excited ions but isn't an burnable mixture, is sended inside first stage (wfc) and transformed in N2H4/N2O and sended directly to second stage (arcjet) connected in combustion chambre. Using similar wfc method (but not arcjet) and use other type of water with different PH you can create with success NH3/N2O as gas and send inside engine. Regards
Do you corona discharge, in 3 to 4 stages of electrode zones?
How do you determine you are creating NH3/N2O gas?
Originally posted by Aaron View PostTungsten and the plasma arc has multiple purposes or properties and one
is heat dissociation. There are others - just check those two articles.
Something mentioned as being important.
When tungsten electrodes are used, the heat dissocation of H2 to 2H runs at "atmospheric pressure", says lateral science.
(When no tungsten electrodes, then no atmospheric pressure????)
When tungsten, then AC arc is possible, says lateral science.
(Some advandage of AC????)
Lets have N (made fresh from N2, but what methode?), and lets have H and H and H (fresh made from what, with what methode?). Is it enough to make NH3 or what? Must something else provide this 3e- or is that singleone e- from each H enough?So, it looks like the atomic nitrogen seeks 3 electrons to make nh3.
Wilbert
Back to basics
Lets get back to basics.
First of all N2 has to be changed as N2 is one of the most stable elements in its N2 form, but once changed it is one of the most UNSTABLE and will want to go back to what it was before "stable", that is its nature.
So before anything you need to crack nitrogen in an energy efficient way and mix it with other atomic or molecular elements to form what you want in 0.5-5sec. Can't be done, yes it can, but you will have to wait a bit to know how it is done, and no, I will not be patenting this, that would lead to locking it up so as not to be used, there is a prior art dating back nearly 30 years, so a patent would probably not be granted.
Mike
What is the 1930's prior art patent #?Originally posted by Michael John Nunnerley View PostLets get back to basics.
Mike
Yeah sad really, if applied for a patent here in the US it would be slapped with a NSO (National Secrecy Order), i.e. the inventor can not even talk about it let alone try to build and market it.
something wrong with your maths
We are in 2010, 30 years ago would be 1980'sOriginally posted by vrand View PostWhat is the 1930's prior art patent #?
Mike
tungsten
I do. I'm not sure if anyone else would consider it to technically be aOriginally posted by Powerman View PostYou must be thinking of tungsten as a *catalyst* in this reaction, no?
catalyst, but seeing it is THE metal to use and that it doesn't get oxidized,
I would call it a catalyst. It appears to aid in the reaction while not changing itself. (if there is enough hydrogen engulfing the metal)
Whether or not it is really a catalyst, tungsten is the material to use
for plug electrodes - used with a plasma ignition - or as the ignition
industry calls it - "plasma jet ignition".Last edited by Aaron; 05-17-2010, 09:13 AM.Sincerely,
use plasma
A real plasma burst is desired.Originally posted by Wilbert View PostWhen tungsten, then AC arc is possible, says lateral science. (Some advandage of AC????)Sincerely,
Hi,Originally posted by tutanka View PostIf in first stage is used thermal plasma maybe in second stage is used non thermal plasma, however thermal plasma is very similarry to an flame that Meyer use for consume oxygen
from your answers I interpret that you create N (from air) and water vapour at the same place. Since you don't use thermal plasma that consumes the Oxygen, so I guess you do it much like it happen in the stratosphere (Google Translation Ozone N OH in the atmosphere).
The chapman-reaktion only consider the O in the atmosphere, but there is also water vapour and nitrogen. Peter Fabian has written a lot about it.
This maybe also the reason why you have repeatedly posted this picture.
QUOTE:"however my object is dissociation of water OH- H+ and N+ atoms because I need NH3 and N2O like explain my posted diagram"
The O get consumed by N2O, NO and OH:
N2O + O* ------> NO + NO
NO + O3 ------> NO2 + O2
NO2 + O ------> NO + O2
OH + O3 ------> HO2 + O2
HO2 + O ------> OH + O2
OH and NO act as catalysts, as they are each again at the end of the loss reaction they are unspent available.
thermal plasma = plasma which is in thermodynamic equilibrium
non thermal plasma = plasma which is not in thermodynamic equilibrium
non thermal plasma creation
1st variant low pressure plasma:
pressure < 0,001 bar
with the help of elektromagnetic waves which selective heat the small amount of free elektrons up to several 10000 °C
most gas particle stay at room temperature
most usage:
fabrication of micro electronic devices, surface coating
2nd variant temporal highly vary plasmaparamter with normal gas pressure:
dielectric-barrier discharges/ dielectrically impeded discharge with high freq. AC voltage
So i guess it's 2nd for stage 2 and/or three.
Best regards, Tobias
