Ionization & Water Fuel
    Here is a pdf of the 1919 version - IT'S FREE.
    http://www.archive.org/download/chem...00teedrich.pdf - (me)
    What of Meyer’s original WFC? - (me)
    I looked through about 75% of the book that Schpankme posted
    last night - very simple straight forward explanations - even nh3 reference
    from just nitrogen + hydrogen + silent electric discharge
    page 26 - "With Nitrogen* Donkin has shown that when a
    mixture of hydrogen and nitrogen is subjected to the
    silent electric discharge, a partial union of the two gases
    takes place, with the formation of ammonia :
    N2 + 3H2 = 2NH3
    However, this reaction could in no way be regarded as
    commercial, as the quantity of ammonia produced after
    the gases have long been subjected to the silent electric
    discharge is only just sufficient to be identified by the
    most delicate means.
    Recent investigations have, however, shown that if
    the two gases are mixed and subjected to very great
    pressure (1800 Ib. per sq. inch) in the presence of a
    catalytic agent, union to an appreciable extent takes
    place. This process, which is now being used on a
    CHEMICAL PROPERTIES 27
    commercial scale in Germany, is known as the Haber
    process, but few details as to the method of operation
    are available. In the earlier stages of the working of
    this process the catalytic agent was probably osmium,
    but it is considered doubtful if this is still being employed.
    Yes, not sufficient for commercial production - however,
    super ionized nitrogen is NOT accounted for amongst a few
    other parts of the full reaction - but I'm happy to see the
    reference and further proof of NH3 on demand production.
    Thank you Aaron for the references (I will study them) and the chem book in PDF
    From the Chem. book:
    The Bergius Process (page 63-64)
    If metallic iron is heated in the presence of water under very high pressure, hydrogen is evolved and magnetic oxide formed, in accordance with the following equation:
    3Fe + 4H2O = FeO4 +4H2
    Inside the engine combustion chamber the iron walls of the engine block gets hot. The reaction of the water mist as it hits the hot iron walls has not been accounted for. I wonder it there is something similar with NH3? Just food for thought.
    Best regards, Mike R.
    • I don't know if this has been posted before:
      Flammability Limits, Ignition Energy and Flame Speeds in H2-CH4-NH3-N2O-O2-N2 Mixtures (2000)
      The goals of this study are to experimentally characterize the combustion behavior of hydrogen, methane and ammonia with nitrous oxide or air.
      However, there are some peculiar aspects to these fuel-oxidizer combinations, particularly with mixtures containing nitrous oxide. N2O decomposes slowly at low temperatures (Arrhenius activation energy of ~251 kJ/mol [15]) but is extremely exothermic. N2O can behave as an explosive if the ignition stimulus is large enough and there are sufficient H atoms present to catalyze the decomposition. However, for very low temperature flames, the N2O does not appear to react at all [15, 16]. Mixtures of ammonia and air burn very slowly and in many situations are considered to be non flammable, but mixtures of NH3 and N2O appear to react much more rapidly. The reaction mechanism of NH3 and N2O is particularly uncertain. Hydrogen has a very large flammability range and unusually high flame speeds
      I think this tell that NH3+N2O can burn even better than NH3+Air. Lack of oxygen theory debunked...
      And more supporting reason for why we have to ionize the air.
      • last edit...
        • Originally posted by chasson321 View Post
          For in all cases the oxygen must be removed from the reaction and pure nitrogen has to be used, and in some pure hydrogen too.
          I don't remember ever mention that 100% NH3 is required.
          But in your NH3 on demand theory it is immediately burned with oxygen as fuel and you have said nothing about separating the gases from the electrolyzer or the incoming air supply to get at the pure elements as all of the sites you just posted did to create NH3 on demand.
          Read this and imprint it in your memory:
          pure element is not required!
          extreme heat is not required!
          extreme pressure is not required!
          And the last reference I post even support the idea that we can go all crazy and dissociate all the nitrogen and all the oxygen in the ambient air and still can burn the NH3, in fact, better.
          Then the temperatures all had to be between 400-800 degrees C and the pressures range from 10 ATM to 300 ATM.
          It is obvious that you are not reading Aaron post.
          Honda motor is a big corporation and yet they claim they can produce NH3 at exhaust. It is obvious that Honda do not need 400 degree or 10ATM or pure elements. And the link is even posted by h2opower himself... h2opower know that NH3 can be made at exhaust without your forced limitation.
          Tim, trying to force NH3 manufacturing process to debunk nitrogen theory is weak argument, anyone taking the time to read the literature will see it immediately. This is where you should look into context.
          • space for three electrons
            Originally posted by Shamus View Post
            An N2 molecule has 14 electrons between them, 3 of which are shared between the two atoms. The outer valence shells are full; the atoms are happy. Now when you break those guys apart, you still have 14 electrons; seven in each atom with five in the outer valence shell. Now the atomic nitrogen atoms very much want their outer valence shells to be full, and they each have space for three electrons.
            Those electrons can come from just about anywhere: A passing electron, or another atom looking to do the electron swapping thing like an atom of hydrogen. If the outer valence shells of the atomic nitrogen fill up with free electrons (what some might call a "natural electron extraction circuit") you end up with an atomic nitrogen ion with a 3e- charge. If the outer valence shells find hydrogen atoms, then covalent bonds are formed and you have a molecule of ammonia. Other combinations are of course possible, depending on energy levels among other things. But that's the basics as far as I understand them.
            Hi Shamus,
            Getting nitrogen into a state where there is space for three electrons in the
            presence of electrolytic hydrogen will form NH3
            as an absolute SCIENTIFIC
            FACT that has been known for 203 years.
            When I kept mentioning in this thread the thing that many of the Meyer
            purists keep regurgitating over and over about ionization is they always
            talk about stripping electrons from oxygen but they are completely
            silent of the fact that nitrogen is being ionized as well. This is why I
            mentioned at least twice that it is ridiculous to think that nitrogen is
            sneaking through an ionizer in a Ninja like way totally undetected and
            unaffected.
            This is what the cynical misinformation specialists don't want
            you or anyone else to understand and why they continue to ignore basic
            scientific facts. This is why they press the issue of nitrogen just "getting
            in the way" because they don't want you to see what in my opinion, has
            been self evident for quite a while in this thread. So in the Meyer process,
            this is happening anyway but Meyer doesn't spell it out. He directs your
            attention only to oxygen. His claims are covered in the patent, while
            everyone remains ignorant of what he was doing. Very clever. Almost
            everyone has been fooled that is.
            My first clue was the moment I saw Alex's air processor diagram with the
            multi stage screens. He may see the process different but the point is,
            the moment I saw that, it was very clear in my mind that the nitrogen had
            to become stripped of at least three electrons so that it can bind to three
            hydrogen atoms.
            Alex's diagram only had two screens, but it was enough
            to show a concept and he called it a gift. Only the blind laughed at
            that.
            Perhaps he does not agree with
            my perspective here, but my perspective is consistent with 203 year old
            science and science that is about 100 years old. That diagram has been
            posted for months by the way. A lot longer than that in the original thread
            he posted it in until I brought it into this thread.
            When that ionized nitrogen that has SPACE FOR THREE ELECTRONS -
            "electron stripped NITROGEN" - encounters electrolytic hydrogen, NH3 will
            form - and can form at low temperatures and low pressures. The haber
            bosch process needs such high temp and pressure for the heat ionization
            or "thermionic emission" in my opinion for the right condition to get the
            hydrogen and nitrogen to bond.
            But if the nitrogen is already ionized enough before it every encounters
            the electrolytic hydrogen,
            that extreme high heat and pressure is completely unnecessary. Heat is
            still needed for this whole process, but nothing like industrial ammonia
            production.
            The nitrogen is 78 percent, oxygen is 21 percent. The nitrogen is not
            simply "getting in the way" as some individuals want to claim,
            that nitrogen is an electron vacuum cleaner and has the ability to
            electrically interfere with the recombination of hydrogen and oxygen,
            which reduces the ability for h2o to form.
            This is one general principle that is involved with this process without
            revealing anyone's specific way of doing it.
            I'm open to correction on the above only by Mike, Alex and a few others.
            The cynics are not welcome to debate me on something that they have
            completely refused to even consider so any comments from them are not
            considered honest communication as far as I'm concerned. I'm open to
            correction and discussion by anyone else in this thread that has been
            honest enough to have some real conversation and has been open
            enough to consider other things.
            Anyway Shamus,
            There are other parts of the process. This concept is only one.
            But knowing this CONCEPT - anyone should be able to figure
            out how they want to ionize their nitrogen without needing any
            schematic from Alex, Mike or anyone else, in my opinion.
            Many other parts have been discussed in detail in this thread
            already. I think everyone needs to read the two Langmuir articles
            on the Lateral Science website, again to clearly see a couple
            other significant parts that again, those that are cynical about
            this process are unfamiliar with.
            • @Mike
              Hi Mike,
              Iron oxide is a common catalyst for ammonia production.
              The main point in those old references was not to show the optimum
              way of producing nh3 but simply to show that nh3 absolutely can be
              produced with nothing more than air, water and electricity and for
              those that are cynical about this to pretend this is about
              something else is ridiculous.
              • @Tim
                Now being how I am I read all of them and the all have one thing in common and that is separating the oxygen from the reaction and using pure nitrogen. Do you mean to tell me that in that video of Tutanka's he separated the oxygen from the unseen electrolyzer? For it is clear that if oxygen is present in the system the process will not work correctly or if at all or why bother with the membranes to separate the oxygen out and away from the reaction?
                You post this as proof but I don't see anything that supports your theory in the sites you just posted. For in all cases the oxygen must be removed from the reaction and pure nitrogen has to be used, and in some pure hydrogen too.
                Now I am not the only one that is going to really read those and when they do they will also see what I did in that oxygen has to be removed from the reaction. But in your NH3 on demand theory it is immediately burned with oxygen as fuel and you have said nothing about separating the gases from the electrolyzer or the incoming air supply to get at the pure elements as all of the sites you just posted did to create NH3 on demand. Then the temperatures all had to be between 400-800 degrees C and the pressures range from 10 ATM to 300 ATM. Again that doesn't in the slightest support you theory and or claims.
                Thanks for the sites for it shows the truth and now all will be able to read and see for themselves just as I have done.
                Tim
                The spin isn't appreciated.
                First of all, I never said these were
                the processes used for nh3 on demand for water fueled engines. I posted
                these as proof that nh3 CAN be created out of air, water and electricity
                and are NOT the same as the haber bosch process. I have posted
                at least once, probably twice and possibly three times in this thread
                that these references do NOT spell out the nh3 on demand for water fuel
                engines explained in this thread.
                You refuse to acknowledge that
                copper and other possible materials that WERE discussed in this thread
                that create oxides when oxygen contacts it increasing the % of nitrogen.
                Of course you will ignore this little paragraph, pretend I never said this,
                and pretend that none of these points were ever mentioned in this thread.
                IF above 78% nitrogen is desired, it can be accomplished in the nh3
                on demand process. Yes, membranes are possible, there hasn't been
                mention of that publicly, but different metals have been mentioned and
                you claim to have actually read this thread? I think there are other
                subjects that you would more wisely spend your time on - this isn't for
                everyone.
                Pure nitrogen is NOT necessary. It only allows for higher amounts of NH3
                production if it is pure. If it is not pure and there is oxygen, then there is
                simply less NH3 produced.
                • nh3 in exhaust production
                  That's right! NH3 production in EXHAUST at EXHAUST TEMP AND PRESSURES.
                  Honda isn't the only one doing that. Tim won't acknowledge this though.
                    Aaron,
                    If you wrote that pure nitrogen isn't needed you know also why .. explain also to peoples (I know that) .. Regards
                    P.S. Maybe isn't needed also electricity
                    • Originally posted by Vickers
                      It just gets worse. No electricity? U mean no electrical input yeah? Let me guess? Motion = energy.
                      Hello,
                      Maybe
                        LOL I understand. But old microwave ovens are so cheap? And there are millions of them all over the mother earth.
                        WHY SPENT MORE ENERGY WHEN YOU CAN OBTAIN SAME RESULT USING SMALL PART OF THAT? HOWEVER INITIALLY YOU CAN BUY MICROWAVE SYSTEM FROM JAMES OF POWERCORP
                          Ok my friend. How?
                          I DON'T KNOW.. I HAVE WRITTEN MAYBE..
                            Sure. why not. Laughing man. First u dry the air with molecular sieve, second pass air thru 12 volt red hot carbon fiber filled ceramic tube, third 2 ordinary household microwave oven magnetrons diametrically opposed in a steel tube and than I got bored. LOL
                            That is your method.. work?
                            • Come on guys don't let the naysayers get you all wound up.
                              I have to be more skeptical than I am about things like these. I wasted a pile of cash on replications and fairy tails over the years. But I can say that I understand this discovery for the most part and it sounds very promising. I hope no one steals it from you guys. But understand that if I understand many others do too by now. So you better hurry with the patents.
                              It amazes me how we rediscover things and run with them like they are ours. Like the HHO sandwich cells that are popping up all over the place. Cell designs like that are in books that are 100 years old, only problem was is that they didn't have Stainless Steal back then.
                              • We should call this the blender method. Lets take some molecules and put them in the blender and see what comes out.
