Ionization & Water Fuel
  • Hi Aaron,
    I'm sorry to don't be here now to write something related to tutanka technology, but i think that there are too many pages of pure guessing here and i think that faraday is kinda right when he says that there is no science in this.
    I know people that ran engines with only hho and it work just fine, no gas into the pistons or this kind of things...
    Hydrogen in the atmosphere is about only 0.6 parts per million.
    And I would say that thermal energy meyer said is not reduce the burn rate of the hydrogen but is meant to be use the hydrogen avoiding water reformation allowing him to get enormous amounts of energy...
    The fact that you reduce the hho speed by having it mixed with air is all you need to get the explosion expansion ... What one might call thermal expansion energy, This happens when hho recombine into water witch do not become vacuum (never) but high temperature steam witch heats up the air around inside the engine rising it's temperature and so the pressure forcing the piston to go down...
    I hardly believe that nitrogen has not much to do with any gain ... only the fact that it reduce the speed that hho recombine if its well mixed. I've done some tests and many have done many tests and i watched almost all you can find on internet about.
    We know that dissociating events are endothermic and so absorb energy from the environment for the dissociation so if the process is to use the heat loss in the engine to create the NH3 ok but if is to use electrical energy to do it i believe is not the way to go... However what i believe does not matter here...
    Facts are NH3 or HHO you still need quite a lot to run an engine...
    Here we should talk about science not science fiction.
    I don't know if hydrazine killed stan... I still believe he was murdered...
    I still believe tutanka have something on his hand, not hydrazine, not NH3, something else.. . I still believe i have something in my hand.
    • Originally posted by Farrah Day View Post
      Can someone please explain to me why you would want to produce Ammonia on demand? It's not particularly calorific, so how will this help run an ICE where H2 would not?
      H2 can run an ICE, however people who able to run an ICE meet some obstacle. Meyer feel the need to slow down the H2 burning rate that he introduce slower burning gas.
      There's plenty of Nitrogen in the air, sure, but to produce Ammonia you're still relying on the limited availablity of H2, so I don't see how producing Ammonia helps the cause.
      In a similar process, GEET device can use up to 80% water and 20% used oil or other hydrocarbon.
      The output of GEET is certainly not hydrogen according to marc.
      GEET is a working system with water as input. And yet it is not hydrogen that make the engine run. However no one achive 100% water yet. The idea of NH3 generation can aid GEET system to use 100% water by referring to Meyer Canadian patent, adding ionizer etc.
      During World War II quite a few businesses converted their vehicles to run on Hydrogen because of a petrol shortage. I don't believe the issue is with running a vehicle on H2... it's simply making enough of the stuff to do so!
      At that time and before, there are also NH3 powered car.
      Originally posted by pengrove
      How can they be using devices like this with out also releasing Nitrous Oxide?
      Agree that there could be NOx too.
      Info, page 155, referred by http://www.eagle-research.com/cms/faq/browns-gas:
      Archive Viewer | Popular Science
      Uploaded with ImageShack.us
      Dr. J. D. Cobine. It uses a magnetron tube to generate radar-frequency waves (one billion cycles a second), which make the molecules in a nitrogen gas jet break up into atoms. When the nitrogen atoms hit a surface, they join up into molecules again, liberating a great deal of heat. However, the heat exists only at the surface of the work, so the flame itself is not hot in the ordinary sense
      Why don't anyone having GEET already running do the test? In GEET exhaust gas is bubble to the water + oil container. How about powering it up a little by introducing electrolizer and instead of bubling the water exhaust gas is combined witht the waetr+oil jar output.
      Or if you are alrady having 1 liter per minute hho generator, try to mix it with ozonized exhaust gas.
      This is why I really want to know who is the one who mention the use of exhaust gas in hydroxy generator. From what I recall, he claim to be able to run an engine with it.
      • nh3 on demand
        Originally posted by sebosfato View Post
        Hi Aaron,
        No science in it? All the rebuttals against it are pure fantasy, fact. It
        is a serious case of selective vision. The cynics (they're not skeptics)
        only choose to see what they want and refuse to answer anything that
        is pointed out.
        You don't know if hydrogen leaked past the pistons or not because you
        didn't know to check for that. Also, you have not investigated if the
        metal is deteriorating or not and you cannot do that with the naked eye
        until it is too late. I personally never said an engine cannot run on hho
        alone, because it can but that is not what Meyer was doing. Plus, show
        me a motor running on just hho from these typical wfc's and typical circuits
        that produces enough to get enough mechanical power to turn a generator
        that can produce it's own water gas. You want to debate about power
        from nh3, yet none of you can get any power from just hho. That makes
        no sense.
        Why are you posting how much hydrogen is in the air? What has that got
        to do with any of this?
        Meyer discusses avoiding water reformation. Why don't you think about
        that. You think it is because nitrogen is just physically getting in the way?
        Or, do you understand that ionized nitrogen will attract something to itself
        or not? Whenever I ask specific questions, Tim and the rest develop
        instant amnesia to my questions. Nobody here has even been able to say
        how many electrons a N2 molecule has but they want to debate this
        process? That is completely ridiculous.
        Whether you know it or not, a skeptic actually has to have qualifications
        to be skeptical of something.
        You think the "thermal energy" is simply hydrogen and oxygen increasing
        in volume in order to push a piston down? I'm not saying that can't happen
        but you're ignoring so much of the process.
        You're entitled to your personal belief. However, it doesn't take into
        account many significant factors.
        There are others with the answers to this process and each person has
        a slightly different viewpoint on the best way to achieve it. NH3 is
        the common denominator whether you like it or not. I only know of one
        water engine that doesn't run on the nh3 process, it doesn't need plasma
        and off the shelf spark plug and ignition works just fine. And it has nothing
        do with with any variation of anything Stanley Meyer did. And has nothing
        to do with producing massive amounts of hho.
        I don't know what "killed" Stanley Meyer either and as far as anyone knows,
        he faked his own death and is posing as his own twin brother.
        And why does everyone that does "tests" assume they considered
        everything?
        • A positive corona generates much less ozone than the corresponding negative corona. I am wondering if a positive corona will produce more N2O than a negative?
          The positive back-corona discharge is more effient than the negative one in removal of NOx from tested gas mixtures.
          • Hi Aaron
            ok
            The thermal energy meyer was talking about is not related to the nitrogen or related to the burn rate even if to regulates the burn rate of the gas with increased thermal energy up to the levels he said was possible you would need to control the burn rate!
            I think!
            I believe it has to do with creating other molecules, not NH3 (amonia)
            I believe It have nothing to do with hydrazine.
            I believe that he was linking H's with more O's to obtain increased thermal energy gain!
            Maybe using nitric acid as oxidizer.
            About pushing the piston down
            I mean that we could call this thermal expansion energy witch come from the combustion of the H2 + 02 witch free up a lot of heat witch will heat the rest of the air inside the cylinder witch will develop a pressure and will push the piston down.
            This is not invented by me and is just like how the gasoline or diesel also work.
            About thermal energy increase
            I think that he meant to bound more O's to less H's this would not allow the water to reform giving a clear energy gain OH until it get recharged in the atmosphere like he described becoming H2O again.
            about nitrogen i don't know everything but
            Nitrogen atom have 7 as atomic number and 14 atomic mass witch mean it have 7 neutrons and 7 protons. The molecule N2 has five electrons in its outer shell and is therefore trivalent in most compounds. The triple bond in molecular nitrogen (N2) is the strongest.
            The main neutral hydride of nitrogen is ammonia (NH3), although hydrazine (N2H4) is also commonly used. Ammonia is more basic than water by 6 orders of magnitude. In solution ammonia forms the ammonium ion (NH+4).
            The higher oxides dinitrogen trioxide N2O3, dinitrogen tetroxide N2O4 and dinitrogen pentoxide N2O5, are unstable and explosive, a consequence of the chemical stability of N2. Nearly every hypergolic rocket engine uses N2O4 as the oxidizer; their fuels, various forms of hydrazine, are also nitrogen compounds.
            N2O4 is an intermediate in the manufacture of nitric acid HNO3, one of the few acids stronger than hydronium and a fairly strong oxidizing agent.
            Nitric acid is used as an oxidizing agent in liquid fueled rockets. Hydrazine and hydrazine derivatives find use as rocket fuels and monopropellants. In most of these compounds, the basic instability and tendency to burn or explode is derived from the fact that nitrogen is present as an oxide, and not as the far more stable nitrogen molecule (N2) which is a product of the compounds' thermal decomposition. When nitrates burn or explode, the formation of the powerful triple bond in the N2 produces most of the energy of the reaction.
            Monopropellants are propellants composed of chemicals or mixtures of chemicals which can be stored in a single container with some degree of safety. While stable under defined storage conditions, they react very rapidly under certain other conditions to produce a large volume of energetic (hot) gases for the performance of mechanical work.
            • Originally posted by sebosfato View Post
              Hi Aaron,
              And from that answer you want that peoples send you moneys for yours experiments you don't have idea how an endothemic engine work and you want ask about that.. From your words seem that at today around the world all cars works to HHO .. Why BMW have stopped test on hydrogen? You read but not remember better.. can be Alzhaimer?? BMW have stopped test because for use hydrogen first you need cryogenic tank and some security sensors that have an high cost but also the major point is because you need an large amount of hydrogen for run properly an engine and as sub-product you obtain water and that is very dangerous for internal parts of engines.. instead you need little concentrate combustible mixture for obtain as Meyer called the THERMAL EXPLOSIVE ENERGY and to exaust gas very little amout of water.. of course you can't use ONLY NH3, you need other .. but.. "the other" is been posted inside the thread but you don't read because you want to only criticize.. I don't understand the humans.. instead to collaborate to find an green energy start every useless discussions but at the same time they use every gasoline and continue to pollute.. really is an crazy world
              • last edit...
                • Aaron
                  For some reason you seem to feel I'm only here to disrupt this thread or as a distraction... why you should think this, I'm not sure. And why you feel so offended and threatened by my questions is a mystery to me.
                  is pointed out.
                  Am I a cynic because I want to see a little scientific explanation? This has nothing at all to do with me or anyone else seeing only what we want to see... surely we all want to make headway, we all want to make progress.
                  I see nothing wrong in analysing posts and asking valid questions. None of which, I might add, have yet been satisfactorily answered, nor - contrary to what you say - has any meaningful science been put forward. It's not me that's blinkered here. All I'm attempting to do is follow the line of thinking that takes you from hydrogen, oxygen and nitrogen to Ammonia as a fuel. Surely that's not too much to ask.
                  In my experience the people who feel insulted are those that cannot come up with answers to questions posed of them. It's like a defence mechanism.
                  And like it or not, most of what has been written is not backed by any facts, so yes, it is pure speculation. Nothing wrong with speculation if you are then going to put forward some science and a sequence of events that lead us from A to B. But this is not happening.
                  There are also clear misunderstandings here that really need to be addressed.
                  The first is something which, at this stage, should no longer be an issue, but obviously is.
                  When igniting hho mixture, it instantly explodes and then reassembles into
                  h2o shrinking in volume greatly causing a vacuum. This you would also know
                  if you really tread this thread.
                  Let me clarify this.
                  This is pure fallacy that people truly interested in this subject should well be aware of - indeed I'm astonished that this is still cropping up!
                  When we dissociate water into it's constituent gases, we add energy, it's an endothermic process. We then add energy in the form of a spark to get the H2 and O2 to split into atoms (which they have to do in order to reform as H2O). This again is an endothermic process.
                  However, then the H and O recombine back into the water molecule. This now becomes an exothermic process dissipating much thermal energy - more so than the endothermic energy provided by the spark. Hence we get an explosion as the air in the mix greatly expands.
                  Now this is the thing. In the confined space of a combustion chamber, the temperature stays hot enough for the resulting water molecule to remain gaseous. It is water yes, but liquid no! It is water vapour, and as a gas it will be expelled on the exhaust stroke and exit out of the exhaust pipe where by it can cool and become liquid.
                  This fabled implosion stuff is a common misconception that does not occur in an ICE.
                  Do you really think WWII vehicles were being driven about relying on an implosion?
                  They simply had tanks of hydrogen gas attached to the vehicle. I've seen them with large balloons of H2 strapped to the roofs.
                  Furthermore, I think it's too early to worry about hydrogen embrittlement. This is getting a little ahead of ourselves, don't you think? Unless we have enough gas to run an ICE in the first place, this is surely a non-issue.
                  Farrah
                  • Originally posted by tutanka View Post
                    Hi Tutanka,
                    I see you are a really funny person - I see you laughing so much.
                    So I want to dare to ask you 3 questions of interest for me.
                    1. does your application produce over unity? yes/no
                    2. how do you measure and proove the energy input and energy gain?
                    3. do you recirculate any produced power to the system to power the process? yes/no
                    Thanks in advance for a short and precise and self explaining answer.
                    bussi04
                    • Originally posted by pengrove View Post
                      Where do you get this?
                      Meyer also have this method (page 2-4 Technical brief):
                      The Gas Combustion Process of the Gas-Flame eliminates oxygen and burnable gas atoms from the expelling gases ... producing an endless supply of non-combustible gases.
                      Mixing the "processed" Air-Gases with an Hydrogen Supply Source sets up The Gas Retarding Process ... allowing the Hydrogen Gas-Mixture to be transported safely through existing Gas-Grid System.
                      Anyone refer to Meyer should translate the terms "gas retarding process" as mixing hydrogen with non-combustible gases with contain no oxygen.
                      We usually get more heat when we do water electrolysis, why choose to call it endothermic?
                      With control, the H and O would not stabilize yet.
                      at 2:1 ratio, H and O implode. And it is possible that even at excess of oxygen, there could be localize implosion that hamper the overall explosion.
                      Experiment of implosion combustion of hho output by mogli mentioned at page 17 of this thread:
                      Google Translate
                      • We usually get more heat when we do water electrolysis, why choose to call it endothermic?
                        With respect Sucayho, electrolysis is an endothermic process. It requires energy to produce H2 and O2. The heating of the solution itself is a by-product of inefficiency.
                        No it does not. It explodes. It only implodes after initial explosion if there is no residual thermal energy to prevent the resulting water molecule from going to liquid state. This is not the case in the combustion chamber of and ICE. I reiterate this is a common myth.
                        Farrah
                        • n2
                          If that is your belief of what Meyer is doing, that is off topic for this thread.
                          You should discuss it in a new thread you start on your own or post in
                          another Meyer thread that is agreeable to your opinion. There is nothing
                          stopping you from doing this and you are actually encouraged to do this.
                          How many TOTAL electrons are in N2? Simply having five in the outer shell
                          is a partial answer.
                          If you honestly answer that then...
                          The next question is, if you break the triple bond, how many
                          electrons does each atom/ion have out of the two nitrogens?
                          I'm talking
                          BEFORE either has a chance to attract an electron from elsewhere
                          or rejoin.
                          Do they each have the SAME number of electrons or do they have a
                          DIFFERENT number of electrons?
                          • RIP Todd
                            Why you want use microwave??
                            Todd William Wallin - Patent application
                            Todd William Wallin Obituary: View Todd Wallin's Obituary by The Atlanta Journal-Constitution
                            • Thanks Aaron
                              Hi Aaron,
                              You've got a wonderful thread here. There is so much incredible information within this thread and there is a lot here to digest. Each time I go back and scan through it, I find something I overlooked before. Thanks so much for starting this thread and for all your very astute explanations.
                              Best Regards,
                              Slovenia
                              • Hi Tutanka
                                I want to collaborate with my ideas, i'm not criticizing i questioning sorry if sound like critics.
                                Hi Aaron,
                                You made a good question i'm going to find the answer.
                                Just found something interesting
                                Power generation using N2O4
                                The tendency of N2O4 to reversibly break into NO2 has led to research into its use in advanced power generation systems as a so-called dissociating gas. "Cool" nitrogen tetroxide is compressed and heated, causing it to dissociate into nitrogen dioxide at half the molecular weight. This hot nitrogen dioxide is expanded through a turbine, cooling it and lowering the pressure, and then cooled further in a heat sink, causing it to recombine into nitrogen tetroxide at the original molecular weight. It is then much easier to compress to start the entire cycle again. Such dissociative gas Brayton cycles have the potential to considerably increase efficiencies of power conversion equipment.
                                Hi sucayo
                                with that stan mean that he had mixed the h2 gas with non combustible gases before sending to the nozzle as to have = to or safer than that butane or other combustible gas transport inside the tube.
