Look @ this image.
Ionization & Water Fuel
Tim,Originally posted by chasson321 View Post
Can you spell it out for us the reactions as they take place and how you are achieving thermo explosive energy? This shouldn't give any secrets away for we wont know the process but it will show how you think Stan system works for us all to view.
Again just trying to understand your point of view.
Tim
Sorry I can't ... If I write chemical reactions in fact I explain system.. You need to wait an little .. we are working hard on that.. some news about that
Thank you for that kind insult, but no, that was not the intention with that image, but something entirly different. There is more to it then just a refferance patent - but if you (members) read this, you will be closer.Originally posted by tutanka View PostWOW.. Congratulations oneminde with that you have solved the mistery
There is also another reason why I posted this... let's see if anyone besides Tutanka can mention this.- Behold the truth -
Now are two the mysteriesOriginally posted by Oneminde View PostThank you for that kind insult, but no, that was not the intention with that image, but something entirly different. There is more to it then just a refferance patent - but if you (members) read this, you will be closer.
You are incredible... and for your info.. I don't need to read you.. you have to read me when all is ready...
I do actually write to other members also but it is nice to know that you are ready with your system.Originally posted by tutanka View PostNow are two the mysteries
So what is the "mysteries" in my post? and no, you do not need to read my post's.- Behold the truth -
Then use this tread, Puharich's patent and also Meyers Canadian Injector patent in relationship. Reading up on the Air Gas Processor should also help to get a general understanding - not to copy, but to understand, not that these are the only method to manufacture ammonia, but it is a start and should soon be obvious what is going on and why.Originally posted by HairBear View PostAh! Puharich! Very interesting! I thought that molecule drawing looked familiar...
Yes yes, there are more then just ammonia, ammonia is part of the so called fuel mixture but not the only "molecule" that perform during combustion.
PS; What do you see now?- Behold the truth -
Tutanka,
once there were claims that Tetrazine C2H2N4 formed under plasma discharge.
In post 90243 you are stating that
In the following post you are implying that deflagration is taking place thus formed fuel heats nitrogen and combustion byproducts.Originally posted by tutanka View PostTHERMAL EXPLOSIVE ENERGY is effectively released from final reaction..
On a small budget it is not possible to confirm what reactions occurred inside the cylinder therefore, do you have and are willing to share the crank angle versus cylinder pressure chart as a function of your variables?Originally posted by tutanka View PostThe angle of ignition is the same of gasoline, problem is energy discharge
Al
Originally posted by Oneminde View PostThen use this tread, Puharich's patent and also Meyers Canadian Injector patent in relationship. Reading up on the Air Gas Processor should also help to get a general understanding - not to copy, but to understand, not that these are the only method to manufacture ammonia, but it is a start and should soon be obvious what is going on and why.
PS; What do you see now?Last edited by tutanka; 03-30-2010, 12:34 PM.
Smitkin engine Picture from archive.org
tutanka: taken a stab here:
Why meyer use exhaust gas?
The exhaust gas would contain water vapor to be recycled back into gas process.
Why meyer use ionized air?
Ionized air is more conductive. (Lighting)
Why isn't present any internal design of mixing chamber?
It was a secret or
It was just mixing chamber for gas, very simple.
Why was Meyers using light?
How is nh3 formed if at all?
Would have to happen during combustion. The only place were temperature and pressure would be adequate.
