Stanley Meyer Explained
This topic is closed.
  • It may sound funny but all of you may have right.
    Surely Meyer method is pure potential but the effect could be large power generated from electrons pulled from water which is natural ground.
    Did you saw Kapanadze device videos on youtube ? He is sucking displacement current from ground using high frequency HV in resonance with telluric current I suppose.
    100W=1A at 100V = 0.001A at 100000V
    You cannot get 1A from ground fortunately but what about 0.001A=1mA ?
    What would you need ? Or course 1000000V with no current !
    • @lamare dont let yourself get distracted from this three Guys, they only spread misinformations in here.
      And thanks for putting them at the Ignore List, h2opower.
      That saves a lot of distortion again, they actually have nothing to say, as only some Nonsense.
      • Originally posted by Joit View Post
        Please explain your "attack" on me - reffering to a group of individuals making it sound like we are workng together is jus stupid. All i did was saying that tutanka had a point, that was all... what are you 14, becouse it does not sound like an adults mind.
        I said, keep an open mind and i have also noticed that two persons can say the same thing, but only one will be listened to...
        - Behold the truth -
        • H2OPOWER, Great post. I've seen those vids before, good stuff!
          Sebosfato-Where did Meyer show or mention Planks Constant?
          Back to the Gas Processor.
          Upon further research: Meyer States in his patent
          The polar pulsating frequency applied
          is such that the pulsating electric field induces a resonance with respect to an electron of
          the gas atom. A cascade effect results and the energy level of specific resonating electron
          is increased in cascading, incremental steps.
          Next, the gas atoms are ionized and subjected to electro-magnetic wave energy having a
          predetermined frequency to induce a further election resonance in the ion
          , whereby the
          energy level of the election is successively increased.
          Electrons are extracted from the
          resonating ions while such ions are in an increased energy state to destabilize the nuclear
          electron configuration of said ions; and the gas mixture of destabilized ions is thermally
          ignited.
          In the
          ELECTRON CASCADE EFFECT from The Encyclopedia of free energy,energy21.org,energy 21 org Geoff Egel
          Electron avalanche - Wikipedia, the free encyclopedia
          • electro-magnetic wave energy
            Thought this was interesting.
            • HMS-776
              He talked briefly and as i said he change his words as to make you think he was doing another thing but is clear from his drawings what's happening.
              Atomic Energy Balance of water Memo WFC424. You might look at fig 5-4 A B and C he clearly show the collision graphics that talk not about resonant or current limiting. If you read the book i posted you will see clear as water.
              Figure 10 is the most important it shows the free electrons that are inside the chamber.
              Anyway the formula is at Page 5-6
              • HI Everyone,
                I think you don't have clear ideas about GP. Are present two versions as patents show. One small and other big. Inside the small unit no more components are present and seem simple ionizer. However If, as ask sebosfato, inside gas processor is present plasma as result of reaction you have as molecules N2O and O3 no anything else.
                • The function of Gp is to generate electricity.
                  • Originally posted by sebosfato View Post
                    Circuits inside GP are been powered with electricity!! is OU machine now?
                    • @ HMS-776 and Chasson321,
                      Both of you seem to have read my mind with my current studies. Though I was looking at the EEC and coherent light interactions with the atoms, it took me down the same roads as you two. All those electrons get sweep into the screen mesh grid of the Gas Processor's EEC. The coherent light, if absorbed, will push the electrons further away from the nucleus, thus allowing the high voltage poteintal field to bombard the atoms with great speed. The negetive voltage poteintal has to be allowed to grow in field intensity so the speed of the electrons are greater. If one puts 20k volts to capacitor with the VIC circuit the poteintal differance will be 40k volts if it is an isolated circuit. If the negetive has been grounded to the chaisy of the car which is an isolate unit all on it's own due to rubber tires, the voltage poteintal will not build up as great, thus slower speed electrons moving around.
                      That blocking diode is placed in a very unusal spot. It is not place after the thrid coil which would double the voltage in the primary capacitor the GP or injectors voltage zone, but place infront of the thrid coil which has a capacitive charging effect when the pulse terminates. I wonder if it would double the voltage of the multipling effect or just what the true effect is? The only way to study that is to move the blocking diode about to see the effects through expirementation and note what changes you find.
                      The higher the pulsing rate the more chances we get to deal with the atoms as the pass through the voltage zones. And it is clear we must have the atoms absorb the coherent light, so the right wavelengths have to be used. Inside the Gas Processor I designed the coherent light will be reflected all over the place due to I took great time and effort polishing the surfaces of the voltage zones. This will bounce the light of one LEDs' around making it seem as 6 or more LEDs before the light intensity degrades to the point of being non usefull. So when it comes to how I built the Gas Processor the reflective surfaces I gave it also have to be taken into account. I just hope none of the wavelengths I chosen will be absorbed by the two metals I used.
                      The combination of coherent lights electromagnetic energy and the energy of the corona discharge, plus high potienal difference given by the VIC transformer circuit for speedy electron speeds should do a number on the oxygen atoms that pass through it. Plus at the end the resulting electron cloud is sent to the EEC where are consumed, so no reballancing of the said stripped atoms.
                      The EEC is a vital part of how all of this works, and yet we will be the first ones to use it correctly in over 11 years to the best of my knowledge. That is saying something if you ask me. My different aproach to the work of Stanley Meyer in looking for energy content seems to be on the right track.
                      The one stentence where Stanley Meyer talks about the, "4th energy level or more," only makes sense when talking about what the Gas Processor is doing. Occam's razor, as to what the GP is doing, The simplest answer is usually the correct answer. So what this means is the gas processor assembly is where the energy content is coming from in Stanley Meyer's invention. And it only makes sense when talking about the oxygen atom for hydrogen only has one electron. So, for those who say I am doing it wrong, this is the simplest explainations of how Stanley Meyer made use of water as a fantastic new source of fuel.
                      h2opower.
                      • Actually the effect is that you use lets say 40w 40kv 0.001 amps to create maybe 40kv 40 amps generating electricity or 12v 10000 amps whatever come out of the circuit depends on how you recirculate this electrons being ejected. Stanley explained it in a very cleaver way on the new Zealand house meeting saying that "if i can extract for say 100 amps from the water and than use it at 100v i have 10kw of power" and than he said "can we take this electricity restrict amps allow voltage to take over and extract more amps "... "it's a self sustained oscillation system and what power is supplied it is the water or the air actually once the reaction start will stop only when the water inside is completely finished." His words ok
                        H20 now you'll understand and find the right track but is not so easy as seems.
                        The blocking diode as I explained in my thread is only to make of the transformer a charge pump or electron pump with very high impedance output it pumps electrons in a tank. To charge up the resonant cavity (tank) explained in my thread, to its maximum voltage.
                        I'm really not sure about the gases that will come out of the gas processor i know what stan said if you lose mass you increase the energy yield or if you oxygen lose electrons you are reaching stable state al the time and if you find a little hydrogen atom with only one electron it will say hey give me your electron because I'm bigger than you and than the hydrogen will open the universal path of energy or nuclear fusion fission not sure.
                        About the coating you can design it to be the one will work for you and your calculations research and you will find something that is not ormes.
                        More information on my thread http://www.energeticforum.com/renewa...er-true-3.html
                          We all are rotating around the same concept. Basically it is :
                          take HV without current (pure potential like) and somehow MERGE with low voltage low amperage electron current displaced from water,ground or air to get incredible power. DO YOU SEE IT ?
                          No electronics will help us here, they are planned to be toys.But somebody like Stanley Meyer (and MacGyver also) was patient enough to use toys to build something usable.
                          • Bogus law as this technology is so much complex and at the same time simple we can't use confusing terms Like high voltage with no current This simply don't exist. To charge a capacitor for example to its maximum voltage you will input current ok when the capacitor reach the supply voltage depending on the leakage it has, you will have a current flowing.
                            In a tank it work in the same way if you read my thread you will understand.
                            If you have a 40kv and 40Mohms of complex impedance you will have 1ma being consumed and many amps flowing between the components this condition is not very easy to reach.
                            Is all about electronics and physics. But the idea is this i put 10 and takes out of it more because I'm not only transforming energy but I'm also transporting energy like an air conditioning. The amount of energy in form of heat it transport is much greater than the energy it consumes and so on.
                            MacGyver is my inspiration every morning to keep working.
                            • Well, since I really don't see any questions about the water for fuel technology I guess it's time to rest. Trying to get me to talk to the three ignors is like trying to get you to poke a needle in your eye, it's just not going to happen. If you spend anytime talking to them all you will get into is an arguement. They spend more time posting on this little thread than they do their own.
                              So, I will take a break until I have more on the circuit to share.
                              Cheers,
                              h2opower.
                              • Originally posted by tutanka View Post
                                HI Everyone,
                                LOL you guys dont quit. The GP wont make NO2 or O3 for a number of reasons. Can you just move along, oh i forgot no you cant becuse you have notheing to back up what you say. I use UV and HV on air all the time and dont get NO2. I use multiple pecise of equipment some that the UV is aimed at the H and some that it is aimed at O, none produce NO2.
