Water Sparkplug
This topic is closed.
  • schematic
    Originally posted by Kinetix View Post
    Very nice, Greg.
    It sounds/looks a little familliar to me, cause I have played with a somehow similar circuit, but I have abandoned it. It did not manage to make plasma at high rpm... And I used a 0.22uF/630V capacitor...
    Would you please show us the schematic?
    Thanks!
    HI,
    It's on its way. I just needed to make sure multi-plug was no problem.
    Greg
    • VIDEO multi - plug VexUs circuit bench test
      Hi all,
      New VexUs multi-spark plug circuit operating with standard 12VDC coil now on video at:
      YouTube - VexUs Circuit - Multi Spark Plug Adaptation
      Peace,
      Greg
      • Wow, excellent job Greg
        The VexUs name still makes me
        Thanks for sharing
        Luc
          Hi all,
          Peace,
          Greg
          Can you post the exact circuit for this?
          Jetijs
          • VexUs Circuit
            Hi all,
            Peace,
            Greg
            Awesome job!!!
            Do you think that you will be installing the VexUs Circuit on your Beetle?
            Lapperl
            • circuit
              Jetijs
              Hi Jetijs,
              I'm probing the circuit now to see if there are potential problems with hooking it up to an engine with ICM or other computer stuff ... looking for transients, etc. ... so far it's clean. Will post the circuit when done.
              Thanks for your interest. Peace,
              Greg
              • VexUs
                Hi all,
                Peace,
                Greg
                Greg,
                You outdid yourself again !!! Hats off to you
                Dang, you're moving so fast, I can't keep up, I'm still finishing your last circuit on my V6.
                Can you speak a little about the current limiter ? Does that mean when you move to higher power, you're allowing more current ?
                My question is the fundamental theories tossed out about high potential / low current vs, high current / low potential. There was a belief early on that this phenomenom was associated with high potential, low current, and the idea of a potential compression caused by the diode slamming shut. And I thought the booster cap experiments showed best results using a smaller cap with higher potential ?
                I remember one of your earlier videos showing a very unique plasma spark, it was broad and expanding rather than a bolt between electrodes. Do you see that same type of effect with this system ? You are in the best position to compare your finding and give guidance to the group.
                Timm
                • My first video................
                  Hey guys,
                  I just uploaded a video to Utube of my V-8 distributor plasma firing all 8 spark plugs. I have no idea how long it takes for them to "process" a video, but as soon as they do, it can be viewed by everyone.
                  Mike's first video - V-8 HEI Plasma
                  The video is not very good quality, due to a piece of junk camera. The spark looks alot better in person, have to get a better camera. I only have 110V supplying this circuit right now. I intend to build part of Greg's circuit to go along with mine and up the volts to around 300 or so. I found out that the Crydom mosfets also come with a volt rating of 400, for about $30 more each. Anyway, there's my first vid, can't wait to finish stabilizing this circuit and try it out in a Chevy 350!! Later....................................Mike
                  IF IT DOESN'T EXIST, CREATE IT!!!
                  • Great job there jstadwater
                    Video looks good to me
                    Thanks for sharing
                    Luc
                    • Thanks Luc,
                      Next thing is to make sure it's nice and stable at higher frequency and then hook it up in my GTA Trans-Am and see how she acts!! I could not have accomplished this without the help of all you guys, thanks a million!!! Later................................Mike
                      • VexUs circuit diagram
                        Hi all,
                        I've attached the hybrid circuit diagram. It should be noted that the choice of R1 and C1 are critical to the frequency response the circuit will have. For instance if C1 is 22uf and R1 is 55ohms then one RC time constant is 0.0012 seconds. 5X RC gives you a quick enough charge for a 4-cylinder engine turning 5000 RPM. The discharge time is dependent upon the circuit resistance ... it should be kept as low as possible. This will determine how completely the CDI Cap discharges and how much it floats above 0-VDC like shown on the VexUs scope trace in the last video.
                        In the video I used a 0 - 3500 ohm pot just for test and development since I didn't know what to expect. This is all new to me too.
                        The mechanism of the circuit is no mystery. Most welding equipment especially Tig welding equipment have a feature called 'high frequency start'. In this type of welding you use a torch that's not really a torch but an electrode holder with a sharp tungsten tip shrouded in inert gas. A high current arc is generated between this tungsten tip and the workpiece and that's the heat source. To start the welding arc you normally would need to touch the tungsten tip to the workpiece. But with 'high freq' a high frequency (low current) spark 'dances' around in the gap between the tungsten and the workpiece ionizing the space and making it very conductive. The high current welding arc now starts all by itself. This is likely what is happening in our circuits. The regular ignition spark is ionizing the spark plug gap allowing the higher current stored in the CDI Cap to flow.
                        Peace,
                        Greg
                        • Great Video!
                          Originally posted by jstadwater View Post
                          Hey guys,
                          Fantastic Mike. Doesn't it feel great to do get to this point. The video shows great detail in fact. Keep chuggin' along. We've formed quite a group of 'doers' and 'builders' here.
                          Peace,
                          Greg
                          • Originally posted by jstadwater View Post
                            Hey guys,
                            Mike,
                            I agree with Greg and Luc and others... Great job !!!
                            These forums are usually 99% lurkers, and 1% doers.... It's great to see members building !!! ... We need a few to assist Jetijs on his builds, he's also been blazing his own trail too....
                            Greg, Mike,
                            Did you switch plugs wires to lower resistance ? or did you use stock ?
                            Timm
                            • great plasma video
                              Awesome Mike!
                              It is incredible the real applications surfacing here! Thanks for sharing your work!
                              • Excellent simple circuit Greg,
                                To me this new circuit looks to be about the simplest multi plug circuit to date and I like simple solutions.
                                Thanks again for all this most excellent research and development and coming up with a simple solution.
                                Your dedication is a true example of Open Source Sharing (OSS)
                                May your life be blessed for your effort to help our World.
                                @everyone, you must all look at this video presentation and reflect as the message is real. We need to work together as we are doing here to fix what we have let them do to US.
                                Video Link: The Story of Stuff with Annie Leonard
