YouTube - High Frequency D.C. Energy & Water#3
That is a little interesting only because he is showing you that you can use the brushes in a DC motor to do your switching in a hostile environment.
In Meyer's pulse generator you see what appears to be a generator coil that produces a constant DC bias and a series of magnetos which produce the necessary high voltage to produce the shockwave. That of course approximates what you are doing here.
I have played with this a bit myself a while back and used a DC motor from a $12.00 cordless drill from harbor freight and a 20K plasma generator from Ramsey electronics ~$75.00
The spark gap and efficient electrolysis have come up many times by many different people. He does not appear to have the unswitched DC bias (which it should be) and also run through a resistive element.
Rather than use a inverter, you could just use a cheap 555 to trigger a SCR and a resistive element like your light bulb or better yet isolate and pulse with a little saturable inductor, mag amp or isolation transformer so you have no electronics on the secondary side - bulletproof.
