real time steam engine
Hi again,
Since I was a kid I have always wondered if it would be possible to make a 'direct-fired' steam engine. It would be nice to be able to have a gas 'cold-combust' into a lower temperature high pressure gas. Maybe I should revisit that notion.
Peace,
Greg
Peace,
Greg
. I was going to mention before that anyone doing what I convered in my previous post should test on a small engine first. What I propose is a bit of a balancing act to say the least, start with water injection first to ensure your system can react fast enough to throttle changes, your EGT should not vary by more than 100 Deg C through all throttle settings. Once this is working then you can progress to the intake bypass valve to lean your air/fuel mixture, again we want slow incremental changes and the EGT should be monitored. Once this is set then and only then should you start loading the engine, you may find the power will start to drop off at higher throttle/load settings at which point you are too lean and the motor will bog----but here is the kicker, when the motor bogs under high load this is because the cylinder pressure is too low to carry the load
it does not produce extreme pressures nor extreme heat and cannot hurt the engine--the forces have balanced, cylinder pressure with load.
I do believe this would be the correct direction we need to take.
