All about electrolysers, HHO, joecells ect. :)
  • #91
    Hi Redmeanie,
    Thanks for the tips again. If the situation like as you said then I need to check and adjust the idling during half way of testing. It makes sense but in real world this could be a problem.
    We need to wait till the electrolyser gets warm enough before sufficient amount of gas puts out. Other way is to check and heat electrolyte using heater before pour into electrolyser before start driving.
    I didn't notice much on idling during test to get base millage. The car is very old (1981 model) so I doubt previous owner changed the engine. This could due to old motor as well.
    I send the car for repair (engine oil leak). Maybe I do base millage test again before I could confirm if its engine, carburetor or hydroxy causing the idling problem.
    • #92
      query
      Redmeanie posted
      "Well a Booster does just that INCREASES the Octane of the fuel you are using, well over 100 this allows you to subtract some of the Fossil Fuel you are using because you are getting the same amount of combustion with less fuel. Thats the benefit of Hydroxy Gas Boosters. So technically you are not leaning out the engine per se, but you are leaning out the Fossil Fuel and replacing it with Hydroxy..."
      I communicated with savefuel.ca and they informed me that I would not need a O2 sensor bypass on my 2006 Subaru if I were to run hydroxy, do you concur?
      • #93
        Originally posted by rangerbentman View Post
        Redmeanie posted
        That depends on what your goals are....Also which subaru you have. If you just want more power than you can use just the Booster on just about any vehicle. If you want to increase mileage than on most vehicles there is no way around it.
        Your Subaru Im almost certain has a Wide Band O2 Correct? Also does it have the AVCS? I guess you could always just put a booster in and see what happens! Worst case is your mileage will drop dramatically because of the excess fuel being dumped in by your ecu. Then you will know for sure if you need it or not.
        RedMeanie
        • #94
          New acronyms to look up. My subie is a 2006 forrester and I was hoping for better mileage. This is the reply from savefuel.ca when asked about the O2 sensor .
          02 sensors
          "When you are driving down the highway at 3000 rpm, you're putting in thousands of cubic feet of air per minute into your engine. Now putting an oxy-hydrogen unit into the air intake will give you approximately 50 L of hydrogen per hour. Which is 2 hydrogen and 1 oxygen. So you are putting in 17 L of extra air into your engine, 17 divided by 60 min. =0.283 L extra oxygen. And the 02 also gets combusted.
          What 02 sensors can read that?
          We concentrate on HH0 units, we do not want you to spend another $60.00 for something you do not need.
          Hope this Helps
          John"
          Well I guess I'll have to try and see if it does as you suggest. I think that I should have bought the VW TDI but I had a bad experience with front wheel drive so I chose a bigger gas guzzler.Oop's.
          • #95
            Hi guys,
            I have collected the car from repair shop. Mechanic fixed engine oil leakage problem and did tune the carburetor setting to default settings. Yesterday, I took the car to get base millage readings. Fuel consumption for 100KM run without modification is 6.34L.
            6.34L/100KM (new base millage readings) is so much better compared to earlier base millage reading which was 7.74L/100KM. I do notice that the is no idling fluctuation after 100KM run and the idling stays at 1000 rpm. The engine runs much smoother compared to previous.
            Now, I had to start testing all over again with hydroxy, fuel vapor and water injection. Have to wait till weekend to do test run. During weekdays, I prepare all setup for weekend run.
            Redmeanie, I'm going to adjust just fuel knob only to lean fuel. I won't be adjusting air intake screw at carb.
            • #96
              Hi all,
              Do any of you know where to get such fittings:
              But not in brass or zinc, I need them made of stainless steel. I know that there should be some place where you can buy such stainless steel ones, because I have one such connector taken from an old printer. I have serached all over the google and ebay with no luck.
              Jetijs
              • #97
                Found some of these:
                They are from automatic car heater set. I tested them in strong KOH solution pulling about 3 amps through for about a hour. After that there was no sign of corrosion at all.
                • #98
                  Hi Jetijs,
                  Maybe I missed it but did you every find the cause of the foam? And does it cause a problem in the function of the torch?
                  • #99
                    Hi sykavy,
                    I did not make any tests to see why the foam is forming. I still believe that this is due to the neutral plates. I have a friend who has build a similar electrolyzer and he has also neutral plates. He also gets foam, but not at the first times, it starts to appear only after a few days. Just like in joecells. When I find the right stainless steel connectors, I will run my electrolyzer without the neutral plates, then we will see if this foam is due to the neutral plates or is it just a chemical reaction.
                    Jetijs
                    • Hi guys, finished a Chris Felton Joe cell replicaiton, has nice gas but we forgot our meters
                      YouTube - Panacea-BOCAF / Chris Felton power supply
                      more to come.
                      • Comment
                        • The attached PDF should make everything more or less clear for you.
                          • 316
                            I work in non-ferrous metals recycling and we get 316 in all the time in varing thickness from paper thin to 3+ " so try the scrap metal joints as they may have it at a much cheaper price than retail.
                            • Hi Alex,
                              You can use 314SS and will work fine. The concept of using parallel series design like yours should be the way to go. I notice that in each cell the plates are not even number. Use 3 for negative and 3 for positive for each cell (Just suggesting). Also use wider SS strip to connect plates from one cell to another. If use small SS wire for connection, the connection tend to get hot and overall the cell efficiency suffers.
                              Please post the setup photos.
                              • Thank you guys for the info!
                                I took out the connection rods and decided to go with a strips of SS
                                I changed the number of plates to 28 but they are twice as big.
                                Here is the new design..
                                Which is better, more plates or bigger plates? When hooking it up to a car battery
                                Alex
