Thermal Explosive Energy
  • Thermal Explosive Energy
    HHO proveniente dallo STEAM RESONATOR realizzato con piastre in acciaio inox (responsabile della creazione CO2) e semplice ARIA dopo la compressione si ottiene nitroglicerina .. Niente di magico .. nessun complicato circuito elettronico .. no plasma ma una semplice scintilla per accendere la nitroglicerina.
    CO2 + H2O + O2 + N2 = nitroglicerina
    12 CO2 + 10 H2O + O2 + 6 N2 = 4 C3H5N3O9 HHO from the STEAM RESONATOR made with plates in stainless steel (responsible of CO2 creation) and simple AIR after compression you obtain NITROGLYCERINE.. Nothing of magic .. no complicated electronic circuit.. no plasma .. just an simple spark for ignite the NITROGLYCERINE.
    CO2+H2O+O2+N2=NITROGLYCERINE
    That method works only with INJECTOR on the head of engine but first you must start your engine initially to gasoline and after change to NITROGLYCERINE because for start the reaction you need HEAT!!
    Thanks for read me.
    Thanks for read me.
    Sounds interesting, when can we buy one to power our electric gasoline generator? Or is natural gas/propane electric generator easier to convert?
      The injection system is the only way.. is safety and work better.
        Hello World..
        Finally the Stan Meyer secret has an name.. the fantastic THERMAL EXPLOSIVE ENERGY discovered from Meyer is simply NITROGLYCERINE. How is possible? Thanks to the casuality .. mixing the HHO from the STEAM RESONATOR made with plates in stainless steel (responsible of CO2 creation) and simple AIR after compression you obtain NITROGLYCERINE.. Nothing of magic .. no complicated electronic circuit.. no plasma .. just an simple spark for ignite the NITROGLYCERINE.
        Thanks for read me.
        The flame speed for a gas engine is typically 16.5 m/s.
        Flame speed - Wikipedia, the free encyclopedia
        Low speed diesels: 8.5 for marine and electric power generation applications.
        Medium speed diesels: 11 m/s for trains or truck.
        High speed diesels: 14 m/s for automotive engines.
        Medium speed petrol: 16 m/s for automotive engines.
        High speed petrol: 20-25 m/s for automotive engines.
        ICE: Mean piston speed
        Explosive velocity
        7700 m s−1
        Nitroglycerin - Wikipedia, the free encyclopedia
        @tutanka, where ignition takes place (crankshaft angle)?
        Al
          So any fuel injection car engine will work?
          Need to replace the fuel injection system of the car?
            Exist only an scooter injection engine that can be modified simply for run with nitroglycerine.. no car engine is present on market with that injection system
              Explosive velocity
              7700 m s−1
              Al
              Probably the same of old engine because you need little time for obtain the reaction.. very important is PRE-HEATING the engine. For decrease the velocity speed you recycle the exaust gas also as Stan Meyer suggested.
                This is the engine..
                The attached engine is what you need.. after you can use also glycerine instead of gasoline or maybe you can recycle the exaust gas
                  Looking forward to your engine running on Youtube
                    Isn't an my engine.. is old scooter engine produced from peugeout or aprilia.
                    An model you can find is Aprilia Ditech 50cc.. You can modify easily... this engine use orbital injection system and little air compressor.. what you need ffor make an real Meyer engine. Here more information in italian but you can translate easily.. Sistema di iniezione elettronica Aprilia Di-tech.
                    Normally this engine with that injection can run for 50KM with one liter of gasoline.. The engineers don't have understand why.. but if you reassume all informations written on threads you understand the reason... when understand the principle there are some ways without complicated modifications..
                      more "Aprilia SR50 DiTech injector" picture:
                      aprilia sr 50 ditech injector | eBay
                      Find information, resources and relevant links for scootergrisen.dk. This domain may be for sale.
                      DITech - 2 takt motor
                        Thank you for replying, Al.
                          I ordered one
