Stanley Meyer
  • Andreev wrote plumbum-can be used as a catalyst
    • Originally posted by wolf234 View Post
      make test only in that way you can be sure
      • Mike use foil - separate gas. use fuel cells and we're home
        • what will work tutanka only heat with catalyst? lead platinum what?
          The pure in heart will see the light.
          • Originally posted by Michael John Nunnerley View Post
            Electro chemical complex reactions even the best of scientists do not know all the reactions that take place, it is still an open book.
            One thing that is real is energy gain from these reactions, the only thing is something is always consumed or transformed to give the energy out, including nuclear.
            When using flyback HV where the primary input does not see the load, we have two reactions, one electric and the other chemical. On the electric side we create HV at low amps from low voltage, medium amperage (the gain is not here). This is then changed to a high amperage not by reducing the voltage but by a chemical electron cascade from the electrode metal (that metal is comsumed or changed) the voltage stays HIGH, in time that electrode (the fuel) will have to be replaced. The system is not exactly electrolysis as in Faraday's Law, partly yes and partly no, the no part will take you way over normal Faraday.
            The system is a two part system, the high amperage did not come from the high voltage, the high voltage is still there if using distilled water.
            regards
            Mike
            \ what happens when two different metals are joined together and the drift speed of electrons is different in one another? except the voltage drop
            • Originally posted by tachyon View Post
              This is called seebeck effect.. you have an electron flow.. and the voltage depend from metal used
              • Originally posted by tutanka View Post
                It's also called a thermocouple, thermopile and many other names, heat it and produces a current
                regards
                Mike
                • except the voltage drop/difference...
                    discoveries forget in time ..
                    • michael doesnt forget
                        Michael Nunnerley or another ? Please explain your theory..
                        • nothing idea... nothiung theory
                          No idea no theory .. is very difficult think in this world no more time , no illuminated minds just some beers are sufficient for live better.
                          • I told you my theory is that this is an electrodynamic interaction, if you give me more info about how this works I can drop to conclusions but you only care about making patents...what is ionized?
                              Sorry but you can take your theory all to yourself
                              • yes I'm going to believe in magical electrinos instead...
