bang for the buck - universal multi channel pulse generator
  • #16
    Sounds awesome.
    Thanks!
    • #17
      Delorean, I've sent you a PM mate
      • #18
        Hmm, he hasn't replied.... Maybe they got to him :/
        • #19
          circuit design, simulate and build tools
          there are great tools for circuit design and development.
          of course it takes some time to make good use of them but they are powerful and efficient.
          1. KiCad for circuit design and layout
          Download - Kicad EDA - KiCad EDA
          2. LTSpice for circuit simulation and circuit layout prototyping
          Linear Technology - Design Simulation and Device Models
          I use them to build applications integrating PGen pulse generator components.
          enjoy!
          • #20
            Ok thanks mate.
            Hopefully I can wrap my head around it.
            If I can get thru the electrician course, I should be able to get thru this
            • #21
              P Gen
              Anyone is using it? Any results so far?
              I'm considering buying one, to use with a tube hydrogen cell and a fat bifilar inductor in between. I'd like to figure out how to set it up for resonance sensing.. any idea?
              • #22
                Trial version of PGen pulse wizard available now
                You can download a free operational trial version at https://www.dropbox.com/s/d8wd7coxux...Gen_demo_e.pdf
                It works with and without µC hardware connected.
                For the resonance sensing you have to use the pll mode and feed the phase shifted signal back into the controller.
                the controller will change frequency until given phase shift for resonance is reached.
                • #23
                  Update: newest version of 08-20-2014 supports frequency sweep and pulse frequency to > 3 MHz.
                  • #24
                    At 15:30 min this video shows how to create pulsetrains and create resonance swings in a transformer
                    • #25
                      Adding process control to your electronic workbench
                      Combining a microcontroller with an easy to use programming interface:
                      • #26
                        Fibre optics connections against electromagnetic interference
                        A fibre optics connection solves ground related problems by isolation between pulsing source and power switch.
                        A fibre optics connection also solves problems related to connection wires acting as antennas and creating ripple voltages.
                        The ST connectors of the fibre optic connection are similar to electrical bnc connectors but smaller.
