Kit Board For Hho Dry Cells
  • #46
    Originally posted by tutanka View Post
    In my stove I use pellet wood creating syngas.. that interact with plasma air producing plasma flames. I don't know rossi device ..
    Yeah, we get it, now. You always need ADDITIONAL FUEL although the plasma air is the REAL FUEL. Same as Stan Meyer's WFC--it runs exclusively on water but for some strange, inexplicable reason, needs more gasoline than water.
    Andrea Rossi from Bologna, Italy is known for his highly controversial E-Cat cold fusion reactor:
    Fusione Fredda, l'E-Cat da 1 MW funziona 8.000 ore in un anno - International Business Times
    • #47
      When electrolysis occurs at a higher rate than ever before...
      Enough HHO gas to power a vapor fuel carb at 1.4 volts DC 15A is less watts for the same volume.
      • #48
        @Einstein
        You'll be removed next time you post false information about the Meyer technology using gasoline. You are an obvious disruptor. You claim to be so ignorant about all of this yet you have all the answers. Give it up.
        • #49
          Great!! If you are found with my informations the right way remember that if you are using my air-as-fuel tech as company and not as private customer you have to pay me an license because this is patented...
          • #50
            A variac sends the generator output into resonance with the dry cell and Meissner setup.
            • #51
              "hho-torch" heating water and nitrogen gases in a "cylinder"
              Maurice Ward Starlite The Great Egg test - YouTube
              Al
              • #52
                For run an little engine 200cc without modifications you need an lower amount of hho, about 0.5-0.6LPM, plasma air and plasma ignition. If you add modifications inside the engine you need just 0.5-0.6LPM of hho using an normal ignition. In that case plasma air is produced internally to the engine!! I repeat again and again.. Meyer use the same concept.. air as fuel (plasma air) and hho gas just as igniter (free electrons)!!
                1 car for run 100 km with v= 100 km/h consuming = 7 litre.
                7 litre x o.85 = 6 kg about
                Potere calorifico - Wikipedia
                6kg x 44.5 (43-46) MJ / Kg = 267 MJ of energy
                =============== SO HOW HYDROOGEN ===============^^
                267 MJ / 130 ( 120-140 mj/kg) MJ = 2.05 kg of Hydrogen =2050 gr
                2050 / 0.09 (becouse 1 liter Hydrogen= 0.09 gr) = 22777 liter / h
                22777/60 = 379 liter in minute!!!!!!!!!!!!!!!!!
                NEED 379 LITER IN MINUTE FOR RUN WITH 100 KM/H
                TOTAL CONSUMING IS 22 777 LITER OF HYDROGEN 100 KM
                MY GENERATOR GIVE ME 4 LITER IN MINUTE I PUT IN MY CAR, NOTHING HAPPEN.
                WHEN I PUT IN MOTO 50 CC, JUST A LITTEL POWER.... PFFFF
