Me thinks I know a bit about Water Fuel Secrets. Me also thinks it can update the forum too.
If one manufactures a substitute of atmospheric nitrogen to make air that say is 15% oxygen and 1% carbon dioxide and the usual trace elements but using say an INert Gas instead of the Nitrogen, the car engine will not run... Why?
Because the Heat from Hot Fusion as the South Pole Positive Energy water vapor is released by the Frequency change of a PetroCarbon vapor causing HEAT (its a TRAIT of South Pole Energy. COLD FUSION is North Pole Energy or what you call hydrogen) this HEAT causes the Nitrogen to expand and push the cylinder down. Fire or explosion does not push the cylinder down. Expanding nitrogen does. its why they add Nitrous Oxide to drag cars.... its a double whammy of heat source and expansion gases.
Why Petro carbons create energy from South Pole positive water vapor is because the Petrol has been refined above the Earth in a tower and so was given a 3 harmonic of the Number for Heaven. Same as why alcohol burns… But we arent up to the numbering system just yet and its impact of Frequencies of Matter.
One must think in terms of Energy, Frequency and Vibration..... not H2O and N or Carbon. Said Tesla. He was clearly smarter than Bedini or Meyers or ANYONE Else since.
Petrol changes the frequency of water vapors. The O energy or the Positive Field Energies want to rust the other vapors in the cylinder namely the Neutral Energies too. Rust is a Hot Fusion process regardless of whether its instantaneous in an engine or on the panels of the mudguards. Rust expands that which surrounds it as in concrete cancer or in between two steel plates. Why this happens is to far advanced as the very nature of water isn’t understood yet.
Here is a cut and paste I wrote a couple years back….
Two Electrode Electrolysis verses Multi-Electrode Magnetic Field Generation in Water.
The scientific branches of physics and chemistry are based upon the singular experiment that when 2 electrodes are placed in water (caustic solution) the two gases produced are ‘hydrogen’ and ‘oxygen’.
This constitutes how the Lab Coat kind sees their universe.
This highly publicised experiment is known to every student who enters high school. It forms the corner stone of Belief in the Cult of H2O. To fully understand this 2 electrode experiment we need to re-examine this experiment, from an outside the box perspective, and do so with an open mind.
Despite the fact one needs specific materials in the electrodes and specific additives in the water, and no mention of voltage or amperage requirements, this singular controlled experiment is hailed as the Holy Grail of the Atomic Structure and constitutes the foundations of all that man believes.
At
Is a device with 6 electrodes with DC applied and one neutral.
This “electrolysis” device offers independently verified PROOF that electrodes in water makes impurities disappear. With little to no production of gasses in any ratio that conforms with H2O.
The variation to the above PROOF that “electrolysis” with more than 2 electrodes does other stuff besides splitting water into two gases is that when water is injected with electrons first for 15 minutes then the Food Dye is added and again it fails to mix and “DISSAPPEARS” completely allows independent experimenters to do further experiments upon making ‘elements’ disappear.
The Device that turns water into silver is made with 4 electrodes. Colloidal silver makers use the standard 2 electrolysis electrodes and so the electrodes disintegrate. When 4 electrodes are used in a SPECIFIC electrical power hookup, the wires NEVER wear out and the water tests for silver. Further explanations at; joecellwaterscience.com
These multi electrode “FIELD SCIENCE” experiments are based 25 years of experiments, reports, some certified, video evidence testimony and devices that can be made by anyone and they are even commercially available.
What we have discovered, is that when more than 2 electrodes are powered with DC in an electrolysis like experiment, the water purifies like in the above experiment or it ‘dirties’ like in the silver experiment. NO gases that test H or O. The gases actually test….. Water vapor or moisture. Without heat even, in fact most experiments the container drops in temp.
The types of multiple electrodes (materials and shapes) Orientation to the earths magnetic field, The number of electrodes, and their ratio to Neutral plates effects the outcomes of the waters treated. In fact in most multi-electroded electrolysis experiments it’s the Neutral plates with NO DC hooked up that produce the most bubbles.
Brand new physics.
Brand new inventions
Brand new concepts
Multi-Electrode placements in Water, (H2O) is the new Field Science of Atomic Structure.
Depending upon the device’s polarity in electrode configuration, will see the device either clean or dirty the water. In some configurations with 4 plates and 2 neutral plates with the center positive instead of making H and O it turns the water into OIL see Videos – MAGNETIC WATER SCIENCE password still being wizzzard777
So what do we make of water being H2O by just applying ONLY 2 electrodes to the water giving H and O but when more electrodes and neutrals are added to the vessel of water you get salts/dyes/saline/oily and raw sewerage grey water turning into pure fresh drinking water or pure water being turned into silver or oil?
Does it not give new evidence about the makeup of water?
Thinking outside the box is usually a cognitive disassociation for those who must believe water is H2O in order to wear a lab coat and keep the faith.
This Field Science where one creates a magnetic field in water rather than electrolysis in water by the addition of more electrodes and neutral plates is actually bigger than Tesla in sending energy across the nation and is bigger than crystals replacing valves moving electronics into the space age. This is the next quantum leap of understanding for mankind
At
Brand new physics.
Brand new concepts
