Stan Meyer Bifilar Chokes
  • #46
    Maybe it would help if you explained what exactly do you mean with "linear circuit"
    hehe, i'm afraid my knowledge of electronics is not what you would call sound.. therefore i searched on wiki and found this explentaion:
    "A linear circuit is an electric circuit in which, for a sinusoidal input voltage of frequency f, any output of the circuit (current through any component, voltage across any component, etc.) is also sinusoidal with frequency f. Note that the output need not be in phase with the input.
    Another (equivalent) way of defining a linear circuit is any electronic circuit whose output is a linear transform of its input, where linear means that f(ax1 + bx2) = af(x1) + bf(x2). Some examples are amplifiers, differentiators, and integrators, or any circuit composed exclusively of ideal resistors, capacitors, inductors, op-amps (in the "non-saturated" regime), and other "linear" circuit elements.
    Linear circuits can be analyzed using the superposition principle, which, for example, allows Fourier analysis to be used."
    what i need to know is if the meyer cell does in fact have the characteristics
    described above...
    "A goal is a dream with a deadline" - N. Hill
    • #47
      described above...
      By that definition and my experience in electronics, and minimal experience with Meyer's set-up, I would say yes it's Linear up to the Coils (chokes).
      So I guess you could say it is "Modified Linear"
      Anyone else have anything I would be missing for him?
      RedMeanie
      (psst...Don't Tell Anyone, But I'm Really Not Mean!)
      • #48
        VIC, bifilar chokes, Meyer, wfc, water capacitor, etc...
        Hi Everyone,
        I probably get asked about the VIC/bifilar choke circuits more than anything else. I have been hesitant to post all the details because the results I had were not like Stan's and I don't want anyone going off on the wrong track in case I'm misinterpreting something. I'm not saying no results, just not the same.
        The closest thing to this VIC circuit that I have seen is in a "pulse forming network" circuit for radar transmitter plates in Nike missile silos. All these docs are online and public domain now, but again, that doesn't mean anything. I'm just saying it resembles Stan's circuit closer than anything else I've seen.
        Here is what I believe is a necessary concept that must be throughly explored or it doesn't matter what circuit you have...if, you want to use only voltage potential to separate water with no current or bare minimum.
        INSULATION to make the cell a capacitor in the true sense of capacitor.
        Stan showed using delrin to encase an entire inner/outer tube setup.
        I have seen attempts with van de graff's, etc.. and other high voltage means to accomplish pure electrostatic separation and nobody has succeeded in any significant ways. The voltage is leaking all over and dust and other stuff is attracted to the cell from the floor, etc... that means it is not a capacitor...it is not holding that voltage to any high degree in the water cell itself. If that is the case, there will never be enough voltage for true electrostatic separation.
        The best I have seen is high voltage going to a gap between 2 rods. WHICH IS WHAT MEYER'S VERY FIRST PATENT WAS ALL ABOUT IN HIS CANADIAN PATENT...ALSO MAKING MAGNETIC GAS.
        Look 1st: Canadian Patent # CA 1213671 (look at last drawing with the 2 rods and voltage applied at gap...NOT tubes or plates.)
        Look 2nd: Canadian Patent # CA 1228833
        How many people have attempted the Stan Meyer process and measured voltage at the cell to see that it is all gobbled up no matter what is thrown at it...2 volts, 5 volts, 20 volts, 80 volts, etc...? Has anyone measured with a HV probe 10k? 20k? 30kv? 40? 50? +? I haven't seen this...not to say nobody has done it, BUT, where is it?
        Everyone is measuring an inner/outer tube setup and finding virtually no voltage...why? The annode-cathode set is short circuited. Put a wire between the + and - of any capacitor and measure how much voltage you get? little to none...effectively short circuiting the capacitor.
        Through the water by whatever conductivity does exist, the top edge of the annode and cathode are short circuited to each other. The bottom edges are short circuited through the water to each other. The annode outer side is short circuited through the water to any exposed metal on the cathode.
        The ONLY place the voltage should be directed between the annode/cathode set is in the gap and nowhere else. If there is all the short circuited leakage, how can anyone expect to find any high voltage in that water capacitor? They won't.
        Stan showed a delrin encasement around the annode with small openings at the top and bottom. The cathode is inside the annode. As water is drawn into the opening at the bottom of the delrin encasement, the ONLY PLACE THE WATER EVEN TOUCHES IS THE GAP. The inner part of the annode and outer part of the cathode is the ONLY part where the water touches without the voltage leaking out everywhere else. What that means is that the annode/cathode tube set really has become a capacitor to lock in as much voltage as possible where it counts...the gap where you want the water to split from nothing more than pure voltage potential.
        Even if I had the 100% foolproof VIC circuit, it would do nobody any good at all hooking it up to a short circuited cell.
        I'm not a machinist and am not interested in dealing with delrin. There is a product called "SUPER CORONA DOPE." It is a xylene lacquer type of mix that you can brush on to metal or whatever and then it hardens like a glass and resists 4000volts per mil or 40,000 per mm thick. If you had 2 flat plates and each was thoroughly coated with 1mm each, that is a dielectric strength high enough to hold back 80,000 volts.
        Another option I have no tried yet but bought some to mess with is PLASTIDIP...the liquid plastic stuff you can dip pliers into and it makes a rubbery coating on the handle. I think putting some kind of plug in the top and bottom on a annode cathode set and dipping the whole thing in plastidip could encase it like the delrin. Anyway, the super corona dope painted on could do the same...just some ideas.
        Stan shows a lot of bare metal tubes...it is 100% possible they were thoroughly coated in corona dope (been around a long time), etc... just speculation but as a possibility, something to consider. Even if not, he DID show the delrin encasement concept in the tech manual, etc...
        This message is just to show where my focus is and where I think there needs to be ample collaboration on is to validate and verify the concept of making a true water capacitor then applying higher voltage to it to see if there is high voltage that does actually build in the gap since it isn't short circuited elsewhere.
        Since about November, I have had this project in various stages. I would love to see others play in this area. I think it is effort in vain to focus on the circuits that just pump voltage into a black hole. Anyway, check this patent for the best simple start for anyone to see...the CONCEPT accomplishes what Stan Meyer is showing with the delrin encasement.
        Water decomposition method and ... - Google Patents
        Also read this page thoroughly...study it:
        K9 Passage of electricity through gases
        Ionization by collision is where a lot of water gas is produced without having to increase the power to the cell...as electrons are freed, they accelerate towards the annode knocking out electrons from other water molecules on the way...that is FREE water gas production without extra input. The higher the voltage, the stronger the effect, but again, pointless unless you can maintain true HV in the gap. This effect will be there with any true HV potential/electrostatic separation of water.
        • #49
          Hi Aaron,
          i'm afraid i'm having some problems picturing those small openings between the solid dielectric and the annode. do you think it would be possible to explain that part of it in more detail?
          Thanks anyways for all the great information
          • #50
            Thanks! But why just up to the Chokes? why not all the way to the capasitor?
            • #51
              wfc encasement
              Hi Octavian,
              This is straight out of Meyer's WFC Tech Manual/Brief:
              • #52
                Thanks, i just remembered i have the entire WFC manual in PDF
                • #53
                  • #54
                    Has anyone here had substantially better results with a high voltage resonant coil?
                    • #55
                      after reading the tech brief, i was left more confused than i was before hand.
                      so i read the original WFC patent 4936961.
                      it made life ALOT simpler for me, told me what gauges to use for each coil/choke, how many winds and what size to make the core.
                      i know the tech breif might be a more advanced model, but i'm sure the things he mentions in the patent isn't stuff your allow to fudge the facts on.
                      • #56
                        Sorry for the double post, but i thought i should bump to make sure people see this info.
                        just read a patent for the control module, where the bifiler choke your worried about is used and sourced.
                        that coil is for a MUCH MUCH more advanced circuit
                        have a look
                        • #57
                          Hi
                          I have build my pulse generator and a WFC 2 SS 304 2 inch square 1/8 thick for test purpose. Gap 1mm
                          I'm using an transformer 12v -> 120. + wire is connected to the blocking diode one wire in the bifilar coil (2 times 300 turns gauge 19) and the + of the "water capacitor"(ER) -> back to the coil then - of e transformer.
                          My question is if there is no water in my cell i can get 1000V+ reading my MY64 multimeter, but when I add water I get 2V max why ?
                          Is it because of the bifilar coil is no more resonating with the cell ?
                          Thx
                          Gab
                          • #58
                            need to insulate the tubes
                            As said Aaron, you need to insulate the tubes/pipes, in and out.
                            May be you could read this page and the others relating to Meyer:
                            regards ,
                            MDG
                            • #59
                              thank's a lot Aaron. I will applied this one to my next experiments.
                              • #60
                                water capacitor
                                Hi, according to Meyer's info for the water cells, he shows he went towards insulating the tube sets with the Delrin encasement. I haven't seen any video of that or pics and perhaps he just wanted to cover that in patents, I don't know...but with the voltages he is working with and what I have seen....the dielectric of the delrin locks in the potential to create more of a real capacitor.
                                It keeps the voltage pressure in with less leakage.
