Good evening
I have been regularly posting the progress of my experiments on Electricity's Watson Machine thread. However several freinds here on the forum suggested that I start a different thread since I am the one who is still actually working on this project so here it goes...
Also it has been made very clear that John Bedini is the person who actually developed this type of machine first before Watson so I thought it only fitting that I call my machine a Bedini Machine instead. I have a great admiration for John and am truely in awe of his work.
Basically in this thread I am attempting to run a standard off the shelf motor with an alternator for a power source. Eventually it is my goal to have the alternator supply all the power required to the motor which actually drives itself.
In theory this is helped along in two ways.
First of all the power to the motor is pulsed from what ever source is used. Once the momentum in a motor is started there is less power required to continue its movement. The transfer switch that I developed is timed to pulse once per revolution.
Secondly a fly wheel is used on the shaft of the motor to store the power in momentum so that the motor continues forcefully spinning while the power is off during the pulsing cycle. The magnets and counter weights on the trigger wheel that triggers the transfer switch, acts as the weight of the flywheel to keep momentum.
One of the basic problems in this type of machine is that when a motor and alternator are hooked directly together, Lenz's law greatly slows down the alternator and decreases the current going into the motor.
In my last video I demonstrate this
Transfer Switch.AVI - YouTube
When I attached a motor directly to an alternator there was a 507 rpm decrease in the alternator.
However when I isolate the motor from the alternator using my transfer switch there is only a 277 rpm reducing in the alternator.
Since the last video I have made several improvements and am now able to run a motor from an alternator via the transfer switch with only a 90 rpm reduction in the alternator.
Transfer Switch part 2 - YouTube
This is achieved by a better matched switch and alternator capacitor. I have also added several diodes to help guide the currently properly. In addition I attached the positive side of the fly back diode directly to the switch capacitor. This uses the back emf from the motor to keep the switch capacitor charged more so that the alternator capacitor doesn't have to drain more current which would require the alternator to put out more current and thus slow down when having to charge the alternator capacitor more.
This is where I am at this point in my work. Any and all comments would be greatly appreciated.
Bizzy
Bizzy
