First off I do not have an electronics background. Alright that out of the way I will give a little background and then mention what it is I would like help with. From my understanding, if you simplify things as much as possible, all that is really needed in the Bedini circiut is the electromagnet the two batteries wired up and a diode to direct the, whatever you want to call it, back emf, radiant energy, inductive spike, ringing etc. There is actually a good video by "the Daftman" school boy project (TheDaftman) - YouTube which he has called the "schoolboy project" demonstrating this while this goes along with the work that "Imhoptep" has done with automotive relays. Seeing as this is what is essentially needed why not look for ways to try and better quantify things and observe what adjusting different varaibles does? More specifically I would like to create a test bed to test various coil types and parameters while also being able to adjust voltage, watts and most importantly pulse rate.
Let me mention first how I don't want to do this. I don't want the magnetic wheel timer set-up. Yes you could measure rotations and determine pulses/time however 1) it would be a more complex machine and 2) that magnet flying past the iron core and electromganetic field at varying speeds, with the tangential movement and different possible magnet strengths likely does something. I did note skimming Bedini's patent that he mentions the magnet is not involved in energy production, though this might have been said for the sake of the patent and while certainly the majority of the production is coming from the electromagnet (hence solid state set-ups), the flying magnets are likely doing something and also creating a very complex variable. Did see a video of someone spinning a turned off Bedini and capturing inductive spikes on an oscilloscope so who knows maybe the magnets do contribute to energy production. Besides what does that Bedini cat know about this anyway? Has he ever done one single experiment in his entire life? Sheeez.
Alright, anyways I want it solidstate. Now I know the next reply would be, build a timing circiut with a 555 chip. Did I mention the part about not having an electronics background. I might be able to do this, I understand it involves a couple capacitors and potentiometers, but even if I were successful I would still have no way of quantifying how fast the pulses are occuring. Isn't there a pre-made package to do this? Yes with a variable DC power supply I could alter voltage and watts now I just need something to turn the darn thing on and off at defined rates and tell me how fast it is going. I wonder whether a function generator would do this, but I am getting in over my head there with wave forms and whatnot. Can a function generator do or mimic pulsed DC? That's probably the core of my question. And if it can't is there some sort of pre-packaged way to do pulsed DC and quantify the pulse rate? Any thoughts?
Once you had a set-up like this you could likely gather some good data. For instance on various electromagnet types (different windings, gauge, core type, size, wire material) look what it does at different voltages, amperage and pulse rates. I know there are textbook equations to predict some of this, then again they don't predict anything about charging with negative energy so it is likely worthwhile to try to gather some quantitative data. As it may be unclear the best way to measure the radiant energy produced, likely the benchmark for such a system would be to charge a capacitor of given specifications to a defined voltage and then measure how fast it took to accomplish this in various set-ups. That's it, any ideas/guidance much appreciated.
I am willing to bet there has never been anyone, ever, on this planet, that has EVER done a proper test. But you see... many of these individuals are not looking for a calorimetry based test result, they are looking for small changes and modifications, or alternatives to producing better results, because they are already convinced of the benefit... so they aren't interested in people like you (and me not so long ago) *****ing about the lack of credibility in test methodology. In short, their time and money is better spent elsewhere.
