I found some interesting information in another thread here
That 'fluffy' charge is exactly what I'm experiencing. It's probably due to the 250 volt 2uf capacitor. The yellow ones sold with the bedini fan kit is an A/C capacitor right? I've also tried with those 200v 650uf power supply caps and it doesn't seem to make too big of a difference. They just take longer to fill up. I'm starting to think that I do need the 555 timer cap pulser circuit...
Hi all,
You can certainly use higher voltage discharges if you want.
I've done up to 90v from caps triggered by neon bulb triggering a scr.
If voltage is too high with not enough current..example...I was using a
600v cap .1 or .01 uf...so it fills up fast...at high frequency discharge of
voltage like that...it will make the batts rise in voltage, but won't power
much...it is electrostatic voltage charge.
You need at least the bare minimum amount of current to get the lead
ions moving in charging mode to my understanding.
Those caps in the vid are 30,000 60volts...made by Aerovox or something.
Anyway, I got those from ebay about 6 years ago or so for about $5 each.
A neon/scr circuit can replace an entire 555 circuit but again, if the trigger
voltage is high and not enough capacitance to give a good burst, it will be
a very fluffy charge.
If capacitance is too high to get the voltage rise in the caps that you want, then the discharge frequency might be too slow and again, this won't charge a battery very well. I used a bike wheel motor with the 2000 turn trifilar charging 180,000uf to about 2-3 volts over the battery and triggered by mechanical switch on pully and it took about 2 seconds to get to a few volts above the battery...and that works fine as long as the capacitance seems to be high enough. On that example for example, I would charge the batt like a 12v 7ah gel cell for 1-2 hours then I would turn off the circuit. The voltage would continue to climb and climb for up to an hour with no additional input. According to Bearden, that is the momentum of the lead ions still moving and that may or may not be accurate. Either way, the effect is very real.
