Bedini Earth Light/ Crystal Cells
Lidmotor,
You will find some trouble getting Selenium as the cost is very expensive. I have posted the chemical house some posts back. The copper bowls come from New York I will get the link for you as soon as I can. The bowls are about 14 to 18 dollars each.
Rochelle salt Takes time to make My first batch is still growing crystals. I got two big ones but that is not enough. I have ordered Cream of Tartar through a spice house to get the correct tactic acid. Do not expect a cell that will give allot of power when you first make them. To get the crystal batteries even better it takes again very expensive pure chemicals. The Selenium I have from many years ago when I was making Ionic Amplifiers, I never used it in the mix as I found out I did not need it.
I also found a trick to the Sodium Silicate as it acts as a semiconductor layer, like doped glass. It's not used as a glue at all. Chuck and I will soon post another video of the Star cell in reverse with the magnesium.
You all can do simple tests with the metals to find out what metals work the best. This is done by making the mix that John H gave into a small square block and making a test stand using metal plates., you want the highest voltage.
Here is the Chemical house if you want the good stuff.
Alfa Aesar - A Johnson Matthey Company
"WARNING TO ALL USING SELENIUM YOU DO AT YOUR OWN RISK"I would not suggest anybody using Selenium because of the risk, I would use Galena first. Selenium power is not available in the US.
I'm looking for other doping right now that will do the same thing. I'm not in a big hurry here because it must be done exact. I found out you just cant pop these out.
John B
Lidmotor,
John B
maybe if we add water or a couple more cells in parallel. we have started on other projects until the lights go out, if ever :-)
