Bedini Earth Light
  • #31
    Earth Light
    Freezer, I'm Going to post everything I find out about this cell on some pages you can go to as soon as I have some free time. if lidmotor wants to post the diagram it's ok with me.I'm out of space here on the group. If Lasersaber would join in on this discussion it would be very helpful as we build these circuits as he has been running little motors for days with these type devices. I'm not here to disprove anything he did but to find out what the failures are going to be with different materials.
    John B
    John Bedini
    www.johnbedini.net
    • #32
      Sorry for asking
      Sorry off subject of Joules for a moment....
      John K,
      Some very Interesting things have happened to the rock battery, Transmutation has taken place with the magnesium, the magnesium will no longer burn, as it is not magnesium it looks like it.
      The funny thing I think it's now silver as it seem to reacts the same way. What ever was in the Pyrite has now changed the magnesium, it's a soft material like gold or silver not lead. The rock is no longer Pyrite either, the Pyrite has a silver luster to it and no longer works as Iron pyrite.
      Tom Bearden has said this before and I have done the experiments on minerals to prove that. It's that little spike that science refuses to look at. I have seen this happen in batteries when they had clear cases you could see the plates change and watch the plating take place. Hell your whole nervous system works on that little spike before the energy in EM appears.This is a real head scratchier. And Iron Pyrite is a mysterious rock. More experiments to find out what it is.
      John B
      Sorry for asking, I know you are very busy John, any idea yet as to what the
      magnesium turned into ? Any updates would be appreciated. Thanks
      George
      • #33
        Earth
        FRC,
        I have sent it off to Ron Case to see what happened to it. it will probably get to him by Wednesday. Something very inserting Chuck and
        I were able to get some of it to burn, but it took allot of heat to do it.
        The other thing that I'm seeing is a build up of what looks like calcium, just from the water supply here. when using just distilled water nothing happens.
        The other experiment is just placing magnesium in water causes it's own galvanic action, air is far worse when it starts to oxidize and turns white. The only failures I had were reed switches they just wear out from fatigue. So what I found out no matter what metal you use it will eventually destroy itself in any condition.
        I also found that to work with currents this small the circuits must be very efficient. I have an Amplifier circuit that works good with the earth cells, so you can power things like radios or play music, I will youtube that when I'm done. My ground is frozen here so I cant test to see what happens in the ground yet, but I will soon. I will report everything I do for test here.
        John B
        John Bedini
        www.johnbedini.net
        • #34
          Earth Light
          FRC,
          I have sent it off to Ron Case to see what happened to it. it will probably get to him by Wednesday. Something very intresting Chuck and
          I also found that to work with currents this small the circuits must be very efficient. I have an Amplifier circuit that works good with the earth cells, so you can power things like radios or play music, I will youtube that when I'm done. My ground is frozen here so I can't test to see what happens in the ground yet, but I will soon. I will report everything I do for test here. Oh forgot to say I have one in a pot out back the light is still going day and night.
          John B
          John Bedini
          www.johnbedini.net
          • #35
            John B
            Thanks, much appreciated. Would make a great garden light if we could stick these cells in the ground, and not have the regular galvanic decay.
            • #36
              Thanks John
              FRC,
              The only failures I had were reed switches they just wear out from fatigue. So what I found out no matter what metal you use it will eventually destroy itself in any condition. John B
              Thanks John, About reed switches, everyone complains about them wearing out.
              Could there be some way that a mercury switch could be used instead ? Tilting
              it or something. Matthew Jones used automotive points for his "Simple motor" .
              They seemed to work well except for the sparking.There must be a better way !
              George
              • #37
                @FRC
                Points are metal too.... LOL.
                Matt
                • #38
                  Hi Freezer, I agree, i have almost finished a kind of a long term earth battery just ouside the hut, I haven't filled the hole's in yet and already I get .98 volts. It's just a test setup to try some things. I might try some magnesium sulfate solution around the battery pole's and between them, later on if necessary. For a garden light it would be nice to simplify it down to a twin stake setup and circuit. Just push into the ground and hey presto, light.
                  I'm going to try building Johns light circuit tonight and try it even before i've finshed the battery. With the reflector setup from an old garden light maybe some good lighting can be had. Thanks for the circuit John.
                  • #39
                    If you have a moment take a look at Magnesium molecule :
                    page 7 of this book is an illustration of unalloyed magnesium, it is hexagon shaped,
                    Magnesium and magnesium alloys - Google Books
                    The Carbon /Mg fuel cell (battery) is working. If there is any chance to have a real maintenance free battery that would be worth the effort. It does not have to compete with anything as it is a concept model. There should be a work around for the squeeze but it does'nt appear to be that big a deal I thought at first I might get a carbon hand print but its just water.
                    I share a passion for fuel cells as do most here. If we focus only at the cell as having a membrane or electron transport mechanism we may fail to see that H2 itself can be the cathode or that the Carbon was not consumed and just regular water was used and the LED lit nicely. It works ! A replica of the earth light will give more information why it keeps running and how that can help future Carbon/Mg fuel cell builders .
                    Look forward to see more earth lights.
                    • #40
                      vacuum tube
                      J.BThe other thing that I'm seeing is a build up of what looks like calcium, just from the water supply here. when using just distilled water nothing happens.
                      Just wondering if enclosing cell in vacuum would slow down deterioration process but not affect operation? Any mineral particles/deposits in the water will cause galvanic reaction and destroy magnesium by creating salts. Purity of water seems to be important. I did replicate John experiment, able to spin rotor with slightly over 0.4V at 5mA. I have only 3 neos. Waiting for other supplies. I found large 6"x6"x1 - 2" thick carbon/graphite blocks. Wonder if drilling holes and multiple magnesium rods could perform better?
                      This is very interesting thread. Unable to work on it while over the road but reading and watching. Also, I found this page - Mineral Gallery - the Silicate Class. I hope it may be useful.
                      Vtech
                      General D.Eisenhower
                      http://www.nvtronics.org
                      • #41
                        magnesium and oxygen atom
                        I would guess that magnesium reacts with water creating what use to be called "magnesia alba" or magnesium oxide. (MgO + H2O → Mg(OH)2). this is reversible process (heat). There maybe additional compounds from minerals in the water or air. Curious if there will be difference between de ionized and de mineralized distilled water?
                        Vtech
                        • #42
                          They seem to be very dependent of temperatureYouTube - Capacitors are Heat and Piezo energy collectors
                          And here are some of work with the water captret battery aka similar metal water battery.
                          YouTube - How to make a Water Captret Battery.MP4
                          YouTube - Water Captret increase power over time when given a load
                          YouTube - Water Captret can be hooked in series
                          I saw some colorations between my work and Bedini's and thought i could share what learn so far.
                          • #43
                            Earth Light
                            Ibpointless2
                            Sorry for not answering right away but I was consumed in some other work on these cells.
                            I think I have found the answer to the magnesium and the carbon. Your cell, I have noticed the same thing you have about two different size metals of the same type.
                            When you use the same metal and you have a size difference you form a gradient between the two pieces of metal that is in potential charge. Have you tried two pieces of copper, or two different size carbon rods? Good work.
                            John B
                            John Bedini
                            www.johnbedini.net
                            • #44
                              Ibpointless2
                              John B
                              Yes most, but not all metals work such as copper and bronze. A normal cell at room temp will be around 100mV, but when i use boiling hot water i get close to 500mV. So i'm seeing radiant temperature of the water or plates will increase the voltage and plate size increases amps. I was also surprised when in your video you talked about gas being trapped and squeezing the cell brought more power out of it. I see the same thing with my cells, at first i thought it just water and the capillary action, but squeezing the plate only gas came out.
                              The two carbon rods sounds like a good idea but i have not tried it. Its been awhile but if i do remember right not all metals will work, i think zinc didn't work at all. But the metals that do work do amazing job, I leave the cells shorted out much like a electret because if you don't they seem to get weaker. My biggest problems now has to do with nature. I can't stop evaporating water and any metal left in the environment will sooner or later decay. Tap water may not be the best either, i see what looks like calcium build up on the cups.
                              I look forward to your next video about the cells. Keep up the good work!
                              • #45
                                Ibpointless2, What kind of current are you seeing with the water cell? The voltage could be dealt with but the current would be important for powering small items.
                                ________
                                BeautifullNightmare
