Originally posted by LetsReplicate
You must use Morton's salt substitute, it has something in it besides the chloride that makes the cells do what they do. You must use the Morton's to fully understand what I'm saying, trust me.
The glue acts to protect the cell inner metals from the air and it works well when you have the right ingredients. I have built the "water evaporating" cells like John makes and others have made. I have built a true literal crystal battery where its only a crystal layer around the electrodes shown here. Polycrystalline Literal Crystal Battery - YouTube
There's a reason why I don't make these cells anymore and its mostly to do with the water needed to grow the crystal. I could never use a magnesium electrode because magnesium would fizz right away when place in the water mix. The fizzing and bubbling of magnesium in water is not it developing a oxide layer but instead its releasing gasses and corroding away.
I do the things I do for a reason. I use Notebook paper instead of copper cup or a cup like container because notebook paper doesn't trap water like a cup would. The paper wicks away the excess water and allows the cell to dry faster. I use the glue because it protects the inner metals from the outside air. I use Thin Magnesium ribbon and small 18 gauge copper wire because they will show corrosion faster than a bigger versions of them and when done right the glue cell doesn't show corrosion on the inside of the metals. I coat the cells with plastic or paint to protect it from the air and any water. Once my cells are made they don't need any water, ever, to run so that is why I coat them. The use of no needed water and coating them makes the cells electrodes last longer.
I could make my cells just like Bedini's Alum battery, Where I use a copper bowl and a huge piece of Magnesium that is separated by Epsom salt and salt substitute and water mix. I have done this but the thing is when the salts dry out I still have voltage but to bring amps back I can do what they do and add a drop of water and then i'm back to using water as the median of transport. The good news is that I would be using huge electrodes that won't corrode as quick as smaller electrodes. Bedini says to use the big magnesium electrode because its more pure than magnesium ribbon. Its not that the magnesium ribbon is less pure (it 99.98% pure) it just that the bigger magnesium bedini uses is just bigger so it takes longer to see any side effects of corrosion.
