  • #31
    Thanks for sharing . Do we need to also put some thought to the wiring?
    since it is not a conventional generator you must store the charge before you discharge the capacitors to the batteries. If the timing is right the batteries charge right up to full.
    Do this energy is the same energy that some people feel around the big wheel?
    "I think he wanted everyone to feel the energy around the machine. It permeated your whole body! My jacket was vibrating!"
    • #32
      Big Bedini Motor
      Jeremy,
      You are correct except your a little off on the outside coils as far as spacing goes.
      But with a little adjustment this will work, past TDC 23 DEG. When adding Iron you cause a resistance/delay in the magnetic field. you can cause non liner action in the field emitted. Good drawing.
      John B
      Originally posted by jerdee View Post
      Hello John,
      First of all, thank you so much for your comments above! You are truly an inspiration to us all!!!
      I have been forcing my mind to think asymmetrical as much as possible here. I have created an image of base coil operation as a start. You should notice that the side conjugate coils are not TDC. It looks to be off by about 3 to 4 inches from what I recall. Only center coil is TDC.
      Right now, my figures show...
      61ohms for the Main Base Coil and
      30.5ohms for the conjugate asymmetrical side coils.
      This will equal the 12.2 ohm total in parallel.
      The side coils are opposed pulsing a weaker south pole to create attraction, while the Main center coil is creating a huge repulsed north field when switch goes on. Very interesting non-linear arrangement to say the least. I do know there is more to learn here.
      At this point I see the half bipolar bedini/cole circuit as the switch across conjugate coils in parallel. The switch sees this as a resistive load and non-inductive when on, but yet you are able to collect the collapsing magnet reactive impulse after disengaged.
      I was looking at your Adams motor arrangement. Using the concept of your half bipolar bedini/cole circuit, I made some slight adjustments. Again, I am only learning here, but I see this as a method for switching the non-linear fields. Schematic parts will of course change accordingly.
      We are all very inspired to test and learn here. Thank you so much!
      Jeremy Burnum
      John Bedini
      www.johnbedini.net
      • #33
        Jeremy,
        John B
        Hey John,
        Since the magnets are spaced at 22.5 degrees (360/16=22.5) 23 degrees is just a tad past TDC. Am I on the right train?
        John K.
        P.S. Looking forward to a drive up the lake in the truck next July!
        http://teslagenx.com
        • #34
          coil placement and potential switch
          They look closer to maybe 2 inch off from the looks of the pics:
          From the center of the coil at the top of the pic to the center of the big
          magnet looks about 2 inches or about 2 of those silver neo magnet widths.
          Is the potential switch identical to page 49 (FEG book) even with the 555 timer
          and opto isolator? Some people were commenting on a zener but I wasn't
          by the wheel when that conversation was happening.
          • #35
            Thank you very much John!
            Aaron,
            The two inches...looks to be much closer to the correct calculation.
            As far as the potential switch from FEG 49. The 32V Zener does it all! Completely free switching here...no 555 at all! This switch is taking advantage of the inverted phase potential. Negative Charging!! Completely out of phase from input circuit. FULL RECOVERY AND COMPLETELY FREE!!
            The 1200uf 75V cap is charged to approximately 72v (approximately 5 x constant) and discharged at potential difference of an inverted phase of 36 volts!! Remember it's much easier to fill it half way!! Step Charge!!!
            Still learning here, but I getting more an more excited about this completely non-linear arrangement!!! VERY VERY interesting.
            Absolutely amazing work John, your best yet!!!
            Jeremy Burnum
            • #36
              Big Bedini Machine
              Sucahyo,
              I can only report what I was told, The women in the room felt relief in pain when standing next to the machine. I guess people do not know anything about Scalar Interferometry in magnetic systems. Also I called a woman to the stage to give you a report on what she saw happen, if the energy is good without harm plants go nuts and grow like mad.
              If the energy that is emitted from the machine is harmful you end up like Floyd Sweet dead all at once, that is why I stay away from that device Floyd built. I worked with him for 2 years know everything about his device and what could happen if your not careful with negative energy, things just explode for no reason. I had that problem when I was first tuning the machine, so a warning be careful with inter active fields.
              And yes I did call everybody up to feel that experience of scalar fields
              The machine was set to emit between 6.85Hz to 7.1Hz The rpm of the machine was between 16.5 to 18 RPM's depending on the solar radiation at the time. You could not possibility learn enough about this machine unless you build one that big.
              In Jeremy's drawing I will tell you the correction, The center coil is 1/2 the pole piece to the right, the left coil is 1/4 past the pole piece, and the right coil is almost TDC the difference is in the straight on pictures that Tony took at the show. The picture is deceiving because of the magnetic holders. How many were standing around when I slammed the magnetic fields backwards and bounced the 300 lb rotor to a dead stop then full force forward.
              Group this is a very tricky machine to build not for the faint hearted, I would estimate the machine at over 3 to 1 The Raytheon boy's said the same thing to me in the hallway.
              JB
              John Bedini
              www.johnbedini.net
              • #37
                Big Bedini Machine
                John K,
                Yes you are very close, set the machine to kick backwards first the timing will be real close then. We will go drink beer when you come up.
                John it's easy to build since you have all the experience of the monopole group, Jeremy is right Free 100% negative switching no loss.
                JB
                John Bedini
                www.johnbedini.net
                • #38
                  Big Bedini Machine
                  John K,
                  NO more Winter Shows, it freezing ass cold here I think it's going to drop into the single digits this week. That is a good test for batteries outside to see what they do when they have a negative charge. It's like someone just sucked all the heat out of here. I want to see what a much bigger machine does now it's intriguing to me too, but I'm not afraid of it in anyway
                  John B
                  John Bedini
                  www.johnbedini.net
                  • #39
                    Sucahyo,
                    Thank you very very much . I am very grateful for this confirmation .
                    I have been using my radiant circuit to help cure insomnia, to promote sleep. It works for my family and confirmed by Godfrey. I do not doubt at all if some lady report relief in pain or if plant grow at wild rate.
                    I am only at the lowest foot step but I am really happy that what I have been suspecting for months now is not just my illusion. I have believe that you also manipulate scalar, not just electricity or magnetism. I think I understand the point about harmful, some circuit in this forum noticed by some people to produce headache. I hope that after reading your post, people who embrance headache can now realize the danger.
                    Thank you again .
                    • #40
                      I am trying to get an understanding of how the 3 coils on the bottom are operating, please correct me if I am wrong.
                      The way I'm seeing this is the center coil is firing a north field and the other 2 coils are firing a south, all magnets have north facing out. The coils are actually firing when the magnet is .5 degrees past TDC of the center coils core. This pushes the magnet away from the center coil while drawing the magnets toward the other 2 coils which are approx. .5 and 1.5 degree before TDC.
                      Am I totally off track here? But the way I see it, to drive the wheel the magnet would have to be just passing the center coils core while the magnets haven't quite reached the outer coils cores.
                      Please help me to understand, I might be more lost here than what I thought.
                      Thanks Mark
                      • #41
                        correct drawing?
                        Jeremy,
                        John B
                        Hopefully this is the correct drawing according to JB's comments.
                        See attached.
                        lanenal
                        • #42
                          Bedini Big Motor
                          Mark,
                          The coils are in phase, for a measured inductance of 12.6 ohms. What everybody is forgetting is the rotor is held in magnetic lock condition by the axial motor/generator as I showed this at the conference when starting the re-gauging motor.
                          Again do not use reed switches on this machine, it uses halls. Peter also pointed this out about the magnetic lock.John
                          John Bedini
                          www.johnbedini.net
                          • #43
                            Big Bedini Motor
                            Jeremy,
                            Move the right coil to almost TDC 1/8 past move the center coil to 1/2 past TDC to the right the you will be very close on your drawing. The axial motor is in-between the rotor magnets so it holds it off center for start condition. That is why the motor goes reverse slams agents the magnetic field and then takes off forward.John
                            John Bedini
                            www.johnbedini.net
                            • #44
                              Bedini Big Motor
                              I'm also going to point out that the capacitor is 16000 Uf at 75 volts 95 surge.
                              John
                              John Bedini
                              www.johnbedini.net
                              • #45
                                Big four wire coil.
                                @John Bedini
                                How does the big 200 pound 4000 turn Quadfilar use impedance to amplify magnet strength?
                                How can I apply your approach to improve my 4 wire Spiral Knot Torus?
