Bedini-Cole Window Motor Electric motor runs without draining batteries!!!
  • #61
    Collecting the Data
    Originally posted by Aaron
    here it is from: http://www.energeticforum.com/john-b...tteries-2.html
    @all, this is what I posted way back on Energetic Forum in Feb 22, 2007:
    Hi everyone,
    One of my passions is studying and building "free energy" technologies.
    There are many misconceptions about this field and it is attacked by
    people claiming anyone doing anything in this field are a bunch of
    perpetual motion nuts.
    The truth is that these technologies are very real and they also have
    absolutely nothing to do with perpetual motion! I'm not getting into
    the specifics in this message about the distinctions because this topic
    is too important to focus on the misconceptions. Instead, lets shine some
    light on an amazing recent release.
    John Bedini is a world famous electrical engineer and is considered a
    "Mozart" with electronics and especially in the field of audio components
    because he builds he highest quality most crisp sounding audio amplifiers
    known to man.
    Besides the audio field, he also happens to be one of leading super
    geniuses in the field of electromagnetic energizers and "radiant energy"
    in general.
    For over 11 years, he had many plans posted on his website for many
    different versions of his motors and the "School Girl" motor is probably
    the most popular and there are thousands around the world building
    this motor achieving very exciting results that are supposed to be
    impossible.
    Besides this motor, there is one version called a "Bedini-Cole Window Motor"
    This is what it looks like:
    The plans have been given out to the world on this website:
    MOTOR DIAGRAMS AND LAB NOTES
    The schematics for this motor are here:
    Watch a demo video: The page cannot be found this is 12MB's long
    so be patient or right click on the link and SAVE TARGET AS
    You can visit John's homepage here: Welcome to John Bedini
    Be careful not to miss any links because they are scattered and
    hidded all over his websites. There are many.
    One time at John's shop, he hooked up a little battery to this motor
    and it was so efficient it almost didn't register any amperage on the
    meter while it was running. Also, I grabbed the shaft with my hand
    and I couldn't even stop it!! It produces more torque for the least amount
    of power out of any motor that I think has ever been released.
    Anyway, Mike, an experimenter who did a small modification to the original
    plans wound up with a more efficient Window Motor that runs itself and
    keeps charging a capacitor charging up!
    Here is what his looks like:
    Here are the schematics / plans with the small modification:
    Watch this video:
    YouTube
    How does it power itself???
    That will be another discussion...but pass the link to this forum to your friends so we can
    get the word out. I'm not just someone excited about this...I have built many, many Bedini
    circuits and they all work as long as I build them according to his plans and not how I think
    they should be built. I'll post a thread later with a very simple motor that beginners can get
    their feet wet with..very simple stuff...a 10 year old girl built one so you can too!
    • #62
      Past data collecting, sweet deal Thanks Aaron.
      Analysis by John Bedini PART 2
      Now read the story this way now in red, You will see how everything gets confused by all the posts in between. This is something I learned in the military, how to get the answers. I did change the Neo magnets out in my motor and it does make a big difference, "so no neos" in this one please. Get the facts straight and you will build this motor. Focus on what Mike said or "Fail" . Do not assume anything , Mike is thinking out of the box, Neo Magnets suck in this motor, trigger circuit now works fine in my set up, Next the SS solid state switch.
      John
      <O
      The hall effect transistor is to activate sw1 I use a solid state relay for sw1 wind as much turns as possible try to get above 6 ohm. The circuit will need a battery for power source.. Their are some modifications needed for acheiving unity, then you can get rid of the battery. Dont worry about that for now just get it to run with a battery<O</O
      Yes feedback, and play with sw1 timing I must tell you I use the third winding on my stator coil as a generator winding to charge the cap up from 0v, then when the transistors begin to pulse the back emf through sw1 brings the voltage on the cap even higher till it levels and the motor is then runing at unity
      <O</O
      <O</O
      I don't Know how long the motor can run for, but I always stop it after a few hours or so.<O</O
      I have come up with a diagram of the modification. and a close call, I had found the motor would not run after a couple wires were swiched around by accident. coil polarity is very important. yes same as Bedini/Cole.All components are the same except for the added parts a hall IC and a ss relay and also third winding. <O</O
      Main winding is connected at the collectors. follow Bedini/Cole cct great work.<O</O
      you must get your window motor running,then we can talk about charge timing and unity<O</O
      When you go to run your motor have a AM radio close to the stator coil you should here two cracks brodcasted for every magnet pair passing. a quick way to tell if you are hooked up correctly.<O</O
      I learned alot from these illustrations, look at the commutator to see the timing <O</O
      I think the third winding is allways charging the cap the ss relay puts the main winding in series with the third winding at the correct time, take into account the rectifier diode in between them. <O</O
      This is not overunity, just a motor that can charge a cap and run off it for a wile. <O</O
      I don't know if all is needed for the circuit.I just know that this is how I got it to run longer. how long I dont know so far maby a couple hours. I belive it is working at or near unity.<O</O
      Oh and the scope shots, the third winding shot scope is set to diffrent scope timing<O</O
      I know that the third winding charges the cap. and I think somthing coming through the ss relay helps this charge.<O</O
      I just want to say that I have never claimed this to be overunity I think it is near unity the third winding charges the cap quickly and the motor runs of this charge for a long time not forever.<O</O
      what I did after getting my motor to run without any mods.<O</O
      I would use it to charge a second battery hopeing I could switch the batteries over and over and it would run for ever, this was not the case, then I found out that if I charged a large cap up with it the motor drew less current from the battery. this was with sw1 between cap+ and bat+,,monitor your input current with diffrent caps to see what works best.<O</O
      -------------------------------------------------<O</O
      Now read it this way.<O</O
      John<O</O
      <O</O
      <O</O
      Yes feedback, and play with sw1 timing I must tell you I use the third winding on my stator coil as a generator winding to charge the cap up from 0v, then when the transistors begin to pulse the back emf through sw1 brings the voltage on the cap even higher till it levels and the motor is then runing at unity<O</O
      I don't Know how long the motor can run for, but I always stop it after a few hours or so.I have come up with a diagram of the modification. and a close call, I had found the motor would not run after a couple wires were swiched around by accident. coil polarity is very important. yes same as Bedini/Cole.All components are the same except for the added parts a hall IC and a ss relay and also third winding. Main winding is connected at the collectors. follow Bedini/Cole cct great work.<O</O
      you must get your window motor running,then we can talk about charge timing and unityWhen you go to run your motor have a AM radio close to the stator coil you should here two cracks brodcasted for every magnet pair passing. a quick way to tell if you are hooked up correctly.<O</O
      I learned alot from these illustrations, I think look at the commutator to see the timing the third winding is allways charging the cap the ss relay puts the main winding in series with the third winding at the correct time, take into account the rectifier diode in between them. This is not overunity, just a motor that can charge a cap and run off it for a wile. <O</O
      I don't know if all is needed for the circuit.I just know that this is how I got it to run longer. how long I dont know so far maby a couple hours. I belive it is working at or near unity.Oh and the scope shots, the third winding shot scope is set to diffrent scope timing.<O</O
      • #63
        Right from the horses mouth
        Thx john you are the greatest. I'll take note.
        Everybody is gonna think I'm butterin you up
        I don't care what people say, your it. Oh and those who
        keep it all going.
        If I could get these other people ta stop
        hagglin over trifles we might get this show on the road.
        Analysis by John Bedini PART 3
        Now read the story this way,
        <o</o
        The hall effect transistor is to activate sw1 I use a solid state relay for sw1 The circuit will need a battery for power source.. Their are some modifications needed for acheiving unity, then you can get rid of the battery Yes feedback, and play with sw1 timing I must tell you I use the third winding on my stator coil as a generator winding to charge the cap up from 0v, then when the transistors begin to pulse the back emf through sw1 brings the voltage on the cap even higher till it levels and the motor is then runing at unity,but I always stop it after a few hours or so. look at the commutator to see the timing ,("""ss relay puts the main winding in series with the third winding at the correct time, take into account the rectifier diode in between them""".) I don't know if all is needed for the circuit.I just know that this is how I got it to run longer. how long I dont know so far maby a couple hours. I belive it is working at or near unity. I know that the third winding charges the cap.("" and I think somthing coming through the ss relay helps this charge"").what I did after getting my motor to run without any mods.<o</o
        I would use it to charge a second battery hopeing I could switch the batteries over and over and it would run for ever, this was not the case, then I found out that if I charged a large cap up with it the motor drew less current from the battery. this was with sw1 between cap+ and bat+,,monitor your input current with diffrent caps to see what works best.<o</o
        Now read the story this way, Do you all get it now.<o</o
        John
        The hall effect transistor is to activate sw1 I use a solid state relay for sw1 Yes feedback, and play with sw1 timing I must tell you I use the third winding on my stator coil as a generator winding to charge the cap up from 0v, then when the transistors begin to pulse the back emf through sw1 brings the voltage on the cap even higher till it levels..ss relay puts the main winding in series with the third winding at the correct time, take into account the rectifier diode in between them. I belive it is working at or near unity.I know that the third winding charges the cap.("" and I think somthing coming through the ss relay helps this charge"").what I did after getting my motor to run without any mods.
        The answer.
        ss relay puts the main winding in series with the third winding at the correct time, take into account the rectifier diode in between them. I belive it is working at or near unity.I know that the third winding charges the cap.("" and I think somthing coming through the ss relay helps this charge)<o</o
        • #64
          Compilation data collection so we can build this motor
          once and for all. Peter, when are you going to do a zero
          motor? Oops off topic. We'll gitcha later
          Originally posted by Peter Lindemann
          Comments by Peter Lindemann
          COMMENT BY PETER LINDEMANN of www.free-energy.ws<o></o>
          OK Everybody,<o></o>
          <o></o>
          John has explained the method Mike used to get his unit working, in Mike?s own words. Also, he has run the experiment and determined that the Ceramic Magnets work better. So, that?s it!<o></o>
          <o></o>
          It?s time to get serious about this project and standardize a design. These group verifications cannot be done properly with a ?hobby budget? mentality, where everybody just uses what they can afford or acquire easily. Get a list of components together that everybody can get. Decide on a wire size and the number of turns for each coil, so everybody can build the same thing. On this note, the biggest challenge may be finding a suitable replacement for the SS Relay. The part number that Mike calls for is no longer available.<o></o>
          <o></o>
          So, if Mike wants to come back and give all the specs on his model, that would be a good place to start. If this doesn?t happen right away, I suggest that John?s current model be the basis for this ?standardized design?. He has all the specs for it, the number of turns on the coils, the transistors, the magnets, the rotor hub size, etc. <o></o>
          <o></o>
          So from this point on, if you can actually get all of the parts for the standardized design and commit to the replication, then you can participate. If you can?t get the parts, don?t want to build a model right now, or don?t want to do it the way the group is proceeding, then please just watch quietly in the background and let the builders work it out!<o></o>
          <o></o>
          In keeping with this advice, since I am not building one right now, this is my last post.<o></o>
          <o></o>
          Good luck!!!<o></o>
          <o></o>
          Peter<o></o>
          • #65
            All of the nuts and bolts to do the job.
            • #66
              A recent replication of a window motor running on less
              than one volt.
              WINDOW MOTOR-GENERATOR
              [VIDEO]https://www.youtube.com/watch?v=vtp1zUk15Ws[/VIDEO]
              • #67
                Window Motor Circuit Board Repair
                Hello,
                Is anyone located in California, or near Northern California?
                I have two window motors both of which are not working as they were damaged in transportation. I attempted to repair them by replacing the opto isolator but it was not successful. Should be a simple fix, but I am no engineer/technician as I am new to the hands on aspects.
                LOOKING FOR AN EXPERIENCED INDIVIDUAL FOR HELP, THIS WILL LEAD TO CONSISTENT WORK IF YOU DESIRE.
                THANK YOU!
                [email protected]
                "Rebellion to tyrants is obedience to God." - Benjamin Franklin + Thomas Jefferson
                • #68
                  Found Plans
                  Hi everyone,
                  known to man.
                  in general.
                  impossible.
                  404 Not Found
                  Watch a demo video: 404 Not Found this is 12MB's long
                  You can visit John's homepage here: 404 Not Found
                  Watch this video:
                  YouTube
                  I found the plans in the way back machine:
                  VIDBID
                  • #69
                    Few schemes and figures
                    • #70
                      Here is a link to more of those Ron Cole and John Bedini notes...John Bedini's Magnetic Model
                      Dave Wing
                      • #71
                        More pictures
