Bedini's Kromrey Converter
  • @Dllbare,
    Always they are limitations. Limitations in the longer coils has to do with magnetic flux strenth. Longer coils will perform poorly in open air inductor configuration. (one end to magnet the other open air).
    For our relative small setups, and in case you want to achieve high inductunces - i do not meant your 130 turns of wire - but for some 3-4000 turns it is always advantageous to have a longer coil so to minimize wire distancing from core -thus better efficiency at passive power generation. (for a given ohmage wire - Core losses are another issue)
    Have in mind that the coil's power generation ability is "formulated" by the magnetic field which is intercepted by coil's turns at the surface of iron and drops at square of distance while its core flux goes "un-exploited".
    Also, have in mind that crosssection of a circle grows exponentialy to the radius while surface proportionally to length.
    Bottom line, if you have a closed loop magnetic flux - that means - flux weakens only a little by distance from your magnets - you can better increase performance of a coil by elongating it, thus increasing surface and reducing layer thickness (distance from core) rather than packing too many layers on a short core or even widen the core.
    edit: When widen the core, the magnetic field (if flux density steady) epxands also and projects further. But suitability and core losses matters arise
    To give you an roughly idea, perhaps erroneous one in terms of accuracy, in my setups that i am after inductunce with the minimum wire by having a coil 90mm long filled with 50ohms 24awg (1kgr+ of wire!) is almost 20-30% better (my guesswork here judging by output) by having same wire in (45mm core)
    Am i understood? I think yes.
    Baroutologos
    ps: we are comparing same core diameters
    ps2: It works either way. As electromagnet or in passive generation mode
    ps3: Its an issue only for lots of wire
    • I'm not assuming anything
      Matthew,
      I have been involved in Bedini studying for over 7yrs and in that time I have yet to see or hear on anybody who has achieved a front to back COP of more than about 35-40%.
      I have built several SG's in this time including a replica 6 coiler. I think you would have to agree that 1350Ahr battery banks are large by any standard. Thus I have followed all the 'recipes' as offered up by the Bedini camp.
      You would appear to be the only person I know of who is seriously claiming a COP>1. I take it you would have no problem with my visiting you to witness this for myself as your are truly unique to my knowledge.
      Rick has yet to show a device with a true COP>1.
      Richard
      • Input current decreased
        Hi All,
        I'm trying to build up the Kromrey Converter based on instructions in John Bedini's ETV DVD10.
        I set up only two poles magnets for now and tested its run for trial.
        My machine ran 2500RPM free run on 1.1A/24V input and 2500RPM with two poles(NS) on 1.68A/24V.
        When I shorted out its output terminals, Input current decreased to 1.52A/24V without its speed decrease.
        I rather saw its speed increased with very little rates.
        I don't know I'm on the right track.
        This weekend I will setup full of four poles magnets and try again.
        Thanks.
        JANG, YOUNGDEUK
        • @Jangyd
          Can you share your coil specs pls?
          Baroutologos
          • Coil specs
            Originally posted by baroutologos View Post
            @Jangyd
            Baroutologos
            Hi Baroutologos,
            18AWG 125turns for each poles as John Bedini recommended 18AWG 130T.
            According to today' experiment my machine decreased its input current with 33% at AC shorted and 17% at DC shorted without its speed decrease.
            But I can't see that effects on charging battery. When charging battery
            its input current increased. I think it needs more tuning. not easy.
            There I guess is no negative energy in my machine for now.
            thanks
            JANG, YOUNGDEUK
            • Hi Jang,
              You might want to try running tests at different RPMs to get a feel for its characteristics, if possible. According to Mr. Kromrey's patent, it shows different things at different speeds.
              • A different speed
                Originally posted by Shamus View Post
                Hi Jang,
                Hi Shamus,
                Thank you for your advices.
                I think so different things at different speeds. Two days experiment is not enough.
                I use brushless motor rating 150W which speed can be controlled by variable resistor and test 2poles and 4 poles each state.
                Anyway not easy to get this machine tuned correctly.
                Shamus,
                Do you test your own machine like Kromrey converter or G-field generator?
                Thanks again
                JANG, YOUNGDEUK
                • @Jang,
                  I'm still putting it back together but as soon as I do I will be running tests at different RPMs and posting results.
                  • Originally posted by JANGYD View Post
                    JANG, YOUNGDEUK
                    Hi Jang,
                    Can you share anymore about your build ? Pictures ?
                    I'm just the opposite, my current configuration exhibited good battery charging characteristics, but no current decrease. I'd assume that if this does inhibit the counter magnetic fields, then the potential amp reduction should have a limit down near the current draw with no magnetic poles present. ?
                    My testing wasn't controlled at all, I was just playing and trying a couple things the night before I had to leave town. It's killing me not to be able to test some more. I'll be back in the barn next week and will try some more controlled tests.
                    Thanks for posting your results,
                    Timm
                    • Hello guys,
                      I have not seen the EFTV 10, and do not know specifics about the Kromrey converter apart from the Muller report.
                      Anyknow knows how:
                      - much amperage outputs the machine?
                      - much voltage (free spin)?
                      Baroutologos
                      • I have been experimenting with a setup of mine (semi-closed magnetic flux), and by having achieved the accelaration effect i was pondering how to exploit it.
                        I re-confirmed that if you apply a ohmic load to the output of my machine, same case for Kromrey's converter then above a certain load - say 10 ohms - you vanish the accelaration / lower input effect and you create some drag. (as normal genies do)
                        Bedini and his low impedance persistance
                        Mr Bedini reapetedly has stressed that the Konverter must have minimum possible impedance. Impedance is a function of ohmic resistance and reactance. (induction x frequency)
                        So we must have on the one hand sufficient turns to exploit the changing magnetic field and produce some electricity and on the other hand not too many to increase inductunce considerably. (since it is depended on adjacent turns squared)
                        Perhaps, this is the reason why Bedini, Kromrey, Muller as well as too many others split their inductors into many and series connecting them????
                        As Milehigh pointed out, e.g if we wish 1000 turns in our setup, for achieving minimum inductunce, its best to split 250 turns to 4 inductors rather than to wound 1000 turns on a single coil. (for simplicity's shake we consider each layer of same diameter)
                        so total inductunce of inductors I1 + I2 + I3 + I4 < I
                        I 1,2,3,4 are wound with 250 turns
                        I is wound with 1000 turns
                        @Milehigh,
                        In order to consider each inductor a separate one, what conditions must be met? Windings to be physically spaced or not to share same core also??
                        Anyway, Your views pls
                        Baroutologos
                        • Might be a bit off topic, but maybe it's not.
                          Regarding my magnetized steel bar example (@Milehigh)
                          I was schocked to learn hall sensors are nothing more but a electrical current devices.
                          !duh!
                          No exitic lattice electron shield deflection;
                          No rare mineral's electric propery alternation;
                          just plain old current in act:
                          a current cross-deflection is measured on a special semiconductor (Wikipedia)
                          This all sheds a novel light to the flux lines, force lines et al...
                          We still don't know much about fundamental forces of our entire technology.
                          Yet is overhelming, how much we do, wit this little knowledge we do posses ;-)
                          best regards,
                          Stevan C.
                          P.S.
                          JangYD, I congratulate Your successfull build. Back to the saddle again?
                          • I saw yesterday, EFTV 10 DVD. I late i know. This was quite informative DVD.
                            Even though no mention on the technical specs to replicate that unit.
                            what i conluded is that:
                            1) Converter creates some unharmful voltage. Means somewhere 40-60 volts? No 100 or more for sure.
                            2) Converter heats-up its cores while cools down its magnets. Heat, as Bedini says, comes from current circulating coils and not hysteresis/edddies, so creates some serious amperage.
                            IMO, Bedini contradicts his sayings by supporting it is creating negative energy for use. How it heats-up cores/windings with normal electricity and outputs negative energy?
                            3) Resistance of coils is around 0.4 ohms each at triffilar setup. He is employing parallel wound windings so as to keep number of turns high and keeping impedance down.
                            Mechanical observations
                            The motor is far from efficient as far i could tell. It sucks some 10+ amps of 12volts when free running. This is 120 + watts. In order to achieve OU at 180% as Bedini says it must output 150+ at charging mode. So for this little device we are talking about creating some serious work.
                            No miliwatts or watts. Hundreds watts.
                            Also these machines require intense tuning to the load via RPM control. It is not auto-tuned. Again, IMO Mr Bedini was little concerned about making an facts & figures presentation of this machine, rather than oto inspire the average tinkerer to get a grasp of this device.
                            That's my understanding so far.
                            Baroutologos
                            • It's actualy running on 24V. The two batteries are in series. So the motor is about 360 watts.
                              Cheers,
                              Steve
                              You can view my vids here
                              http://www.youtube.com/SJohnM81
                              • I try to be moderate Dambit.
                                if i do not know for sure anything, i make some possitive estimations.
                                10+ amps on 24 volts or 360 watts as you say is just HUGE.
                                Perhaps, This is a concept machine of no real value the model Mr Bedini had?
                                Judging by his FEG book, he persistently stated that you must keep your input low. He prescribed using 12 watts for keeping an 1200 rpm rotation for FEG.
                                Using 300 watts for spinning kromrey's little converter at some 2000 or below RPM, is just too much...
                                Baroutologos
