More about coils design
Hi guys ;I am interested too in building an Watson Machine;or some improved variant of this
I am working on my version of Ossie Callanan radiant energy circuit, with big red switch that I made my self ....no need big fly well like in jim watson unit, no need energizer;The power coils in conjunction with red switch will oscillate
like in Ossie Callanan circuit and so, will vary the impedance very many times per second and this will bring radiant energy in circuit to be collected more efficient...also, at the shaft you can put an auxiliary energizer or lenz less generator like in totalyamped site ...this will be in the same time an flywheel
if you want. http://www.totallyamped.net/adams/ SkyWatcher had mentioned this already .
at page 10 ;simple coil design lenz less drag , with explanations... practical stuff not just theoretical ;seems this guy had tried all this and the coils design
is working...
Instead an second battery to be charged, I am using an capacitor (1000 microfarad at 200 volts to be timed and dumped back in primary battery like in Jim Watson unit,using an relay at 12 volts ...
My problem is:my relay contacts will weld when that cap is discharged across my 45 amp our 12 v car battery (the battery is disconnected from the circuit in that moment)
I am not fully charging the cap;just at around 100 volts...
My relay what I have is double pole double throw with 2 moving arms with 2 contacts each arm (like common double pole double throw relay ).So we have 4 moving contacts on 2 moving arms( 2+2).So is a many contacts relay or an DOUBLE double pole double throw so to speak...
I connected these contacts in parallel to have bigger surface area to dissipate the condenser energy (4 mm diameter each contact ,in parallel will have 8 mm diameter surface to reducing the charge on every contact .The no moving contacts are connected the same in parallel.
The relay is activated ,at every 4-5 second to dump the charge...
How I say , in spite of the bigger surface area of the contacts one or other will weld....
What Kind of relay Jim Watson was used ?
How to eliminate this problem?In what kind of industry must search to find the proper relay to be resistant and not weld...
Mike
is working...
Mike
