Limotor's Light Multiplier
HELP !!. I am so Aggravated . I cannot get the magnets to spin .I bought the same Coil from the same guy Lidmotor . It has the same resistance as your now but it will not spin any magnets at all . The only thing different is i have tried a 2n3904 and 2n2222a and an mps 05 . they all light the light when i spin the diametric but the magnet stops just as there is no magnetic field there at all ?? I have tried My Cylinder magnet with the ball for the bearing and i have tried the 1 inch ball magnets and i have tried the ball magnets with little Saturn magnets on the pols of the ball ? What is wrong ? It's driving me Mad . I am tempted to send it to you Lidmotor and see if it spins at your house
Is there anything you can think of to help ?
fusionchip
Is there anything you can think of to help ?fusionchip
The way that I first tried this way back when, was I laid one of my rotors on it's side on the mirror then tapped the coil with 1.5 volts. It moved the magnet. It rolled it. From that I figured that maybe just maybe the centertaped coil might be configured to make a pulse circuit spinner. If the "moving the magnet" test works (and it should if you are using the same coil), then it has to be something in your circuit that is wrong. Also the magnet has to be pretty close to the coil to trigger it. Be sure and put a spinner shaft on the magnet and give it a good spin. It should run just like a spinning top. The Saturn magnet idea probably won't work on this. Too slow.
The reason that I use them is that I am a little careless and burn em up by the handfulls.
Back spikes, cap zaps, wrong battery, you know the drill.
