This idea of course comes from the DWFTTW:
Here it is
The rotor's propulsion by the magnets will act as the wind or treadmill input to the system turning the gears. That turns the prop which pushes air and gives a counter push in the SAME rotation direction, which should give a speed assist to the wheel that would be faster than without the prop in this configuration.
That prop/gear pic I cannibalized form Spork33's picture.
Of course we don't want to overspin the wheel for the circuit, BUT, output CAN be put back to the input with various ways. If there was a generator coil assisting the harvesting of energy into a cap that is fed back to the front in one of several novel ways, the propeller very well could overcome the drag of the generator! I believe it will and if this is so, then this will be totally self running.
Of course the propeller and everything would have to be scaled appropriately for the wheel weight, size, etc...
Veljko Milkovic's mechanical oscillator does not have an opposing force on the swing back, it gives help in the SAME direction.
This is what the prop does on the DWFTTW on the little wheeled propeller cart models. The spinnign propeller doesn't work against it, the spin helps to push the gears in the SAME direction.
Anyway, I'm just posting this for food for thought. If that prop/wheel job really works like shown on the treadmill, then my idea proposed above should work.
Take off the propeller, RPM should slow. Add it back on and it should speed a bit. That simple test will tell the truth.
Here it is
