Bedini SG
  • Mart, my first SSG was made with neos and worked just fine. I also had problems with the coil, which wanted to jump to the neos and made a hell of a noise. I noticed, that with neos I had la lot more spikes/pulses per magnet on the scope, usually about 8-10. Then my ceramics came and I switched to them
    Jetijs
    • been trying out a few different magnet configurations on the ssg and have come across one that is a bit weird....
      basically I have 6 triple stacks pointing in one direction and 6 single stacks pointing in the opposite direction.
      I tried this set up after I tried just the 6 triple stacks with the north poles going clockwise. The theory being that the north would push harder against the pulse to make the rotor spin faster and would only induce a very brief pulse in the trigger coil.
      That worked pretty well so I tried this modification to concentrate the north pole. Turns out it works really really well. It is spinning faster then ever (anti clockwise). It works clockwise as well but doesn't go quite as fast.
      Now in my head this is what the field should be like:
      EDIT:
      think I might of made an error some where.... will report back in a minute!
      • yep... made an error... the magnets are actually facing in the opposite direction... I have revised the images...
        but that's slightly suprising since as I said before it goes much faster anti clockwise then it does clockwise. I would have thought in this configuration it would go faster clockwise because of the stronger north side...
        But what appears to be happening the coil's pulse is attracting the strong south side more then it repels the north... get what I mean?
        Just been testing the amps and it runs at a steady .55 amps going clockwise. Doesn't accelerate very fast and doesn't reach a very high top speed.
        Going anti clockwise it accelerates much faster, reaches a higher top speed and draws .55 amps as well...
        • Yay Sep! I have been waiting to see someone fiddle with magnet positioning. You should try a pure scalar setup, that is place all your magnets so that the north field is squirting out between two faces. Kinda like your single ones are doing against the first of the tripple stack. There is some info on scalar setups around here somewhere but I dont remember anyone testing them?
          By the way I meant to mention that when you build a multicoil machine that has slave coils I found that if one wants best performance then one should try to get a perfect alignment of magnet to core. Since yours are all firing at the same time it is possible to have a core firing a fraction too late due to minor misalignment and thus hindering performance. Yours looks pretty good by eye, just thought Id mention it as I think your coils are just strapped in?
          I always used to think that the coil fired dead center to a magnet, it wasnt until I did a bit of research and figured out that adjusting the pot effectively adjusts the timing of the pulse after the magnet has passed.
          • your right ren coils are loosly strapped in and the magnet arent as perfectly symetrical as I would like! still playing around with the design but will make a "perfect" one when I know how i want everything to be
            the scalar set up you described sounds like a superpole... John is using that on his big motor and have seen some discussion of it on this forum. But what I found curious about johns big energiser was that, although it could run in both directions, he prefered it going in one particular direction... It makes me wonder if his magnets or coils are at an angle. There is definatly some assymetry going on...
            I've tried the superpole as well and found that you need to use more magnets for it to be effective... ie. if you normally use a double stack you may need to make a quadruple stack superpole. Other then that it works well.
            Another curious thing was when I put the magnets on their sides (so that the north of one magnet faces the south of the next) it worked pretty much just as well as a standard monopole set up...
            still playing around but this "assymetrical superpole" seems pretty good. I would be curious to hear anybody elses experiences of magnet positioning...
            • The Secret to the SG Magnet Positioning
              Hi Everyone,
              For almost 4 years, we have had the "next step" optimum magnet configuration figured out and it is why Kevin's SG was so efficient...probably more than anyone else posting SG results on the entire internet. There was one other aspect to his motor, which I may discuss very soon but for now, the magnet configuration part is powerful enough for now. For something bigger, just plant the seed in your subconscious mind that there IS an "Ultimate Evolution" of the Bedini battery charging technology.
              Please do not think I do not believe in sharing results and helping to advance these technologies because I do and with my limited knowledge and experience with electronics, I have put some tremendous efforts in the last 8 years to simply doing my part in raising awareness on these technologies. When you have a chance to personally learn from John Bedini, Peter Lindemann, Kevin Pirolo and others like them, which are EXTREMELY rare in my opinion, it is life changing and you can't help but to spread the word.
              If everyone were standing at least partly behind the scenes with Project1World and the renewable energy project, everyone would see that there is profoundly strong effort being projected into the collective unconscious to help stimulate thinking on these exact technologies and because it worked and you are about to inevitably stumble upon it, we have decided to release it.
              Most of the experimenters and engineers that I see posting in this forum are some of the most open-minded that I have seen on any forum in my 8-9 years or so of learning about John Bedini's technologies... I understand that you have to be very open-minded to even look at John's energizers and what I'm going to tell you may be a stretch for some but nevertheless, it is just how it is and people can take it or leave it.
              The enhanced magnetic configuration was discovered with
              Technical Remote Viewing
              I had been working with Kevin long distance on some energy projects and one of them was the SG or SSG. Being one of the top Technical Remote Viewers in the world, he worked some targets with his team. Since I was coaching him on the energizers and much of the data didn't make sense to him ... "fighting against each other" "all mixed up" and very SPECIFIC geometrical specifications along with quite a few other details, I interpreted the data, he made the changes/modifications.... 2 very specific ones... the magnet configuration was one ... and it was VERY EFFICIENT!
              I'm not saying OU either way as Peter pointed out earlier that it shows up in the batteries in certain conditions and John has even said that in the past so it hasn't really been a secret...just not many people pay attention to those small details.
              THERE HAVE BEEN MANY, MANY SMALL DETAILS that both Peter and John have shared with people over the years.
              Anyway, I'm making a video right now to put on youtube explaining it perfectly and I would recommend you tell all the SG groups online to come read this thread RIGHT NOW so they can enhance everything they're doing with the SG and all other variations using a rotor (non solid state).
              I may yank it as fast as I put it up and YES, I am interested in growing membership at this forum...why wouldn't I be? It is an incredible forum that gives great value to people's lives. I may post a message that only registered members can see so if you're just a guest reading this, go sign up with a real email so you can see it too.
              Anyway, I'm off to the video project...
              • I'm on the edge of my seat and will not be budging
                Thanks in advance!
                • Extremely Eager to Hear
                  Hi Everyone,
                  Aaron,
                  You have certainly made me get excited about this. I want to rebuild my exploded! rotor as the more efficient way, and also I am actually onto teaching these stuff to some school children, so I would be glad if you could share them ASAP.
                  This year is going to be a very exciting year for Free Energy ...
                  Thank you everyone
                  Elias
                  http://blog.hexaheart.org
                  • Bring it on guys! I love the vibes this forum has, I look forward to logging on everyday! I have to say that learning and replicating simple Bedini devices has been one of the most inspirational moments in my life. Looking back I was so lost in my direction and motives in life. Johns dedication to his work and his desire for others to continue it inspired me and gave me new direction and motives.
                    I feel like I need to tell everyone the news! Half crazy scientist, half crazy preacher! Lol.
                    Aaron I hope you go ahead and release info on this stuff, most of us here are good souls who love to learn and build.
                    Good job to all here at this forum, all your work and positive thinking is making a difference in peoples lives!
                    • more sg!
                      I currently have a 9 wire coil SG, 8 power 1 trigger wire. magnets are scalar north. charges great only pulling 50 milliamps. I have another rotor with no magnets mounted, cannot wait for the info!
                      http://www.teslagenx.com
                      • magnet configuration update
                        Hi Everyone,
                        I made my little video showing it. Of course I could post one simple pic that shows the whole thing but I'd also like to put a small video demo if possible. If time permits today, I may be able to include that.
                        Anyway, the video should be posted tonight. So far it is 4 minutes...well, 3:30 without my little advertisements and credits at the end.
                        • Cant wait to see it Aaron
                          Hi Guys,
                          I cant wait for the latest video Aaron .I'd like to start by saying thanks for letting me post in these forums as I find them very informative and enjoy watching the progress being made by many of the members here .I espescially like watching the progress of Jetijs with the guidance of Peter as I've been intrigued over the past couple years of alot of Peter's research.Well, Heres my own LOW BUDGET SETUP , But hey, I had to start somewhere.YouTube - Bedini SSG Motor.
                          Thx again for all the tips and suggestions from ALL members .
                          -Gary
                          • I Seph!!!
                            I'm new to these new energy manipulations,and,it blow my mind away that you guys seems to understand that with good ease.
                            Anyway!! I don't want to interfere with the discussion here before knowing more about the principal of the hole thing...
                            Still!!I have a question for you??
                            I saw youre setup,and,someting hit me with youre configuration...
                            Due to youre setup,i think that,if you take youre rotor running outside of youre coil,(MAYBE),you could extract more from youre setup!!!!!!!
                            You don't have to change the circuit..But just by let the rotor turning outside the coil,and,with the same number of magnets,with the south polarity
                            pointing toward the coils,i think you could extract more torque from the rotor..
                            Maybe you already think about that....If so ....Ignore this message....
                            From an exited member!!!!!
                            peper10
                            Hope die last!!!
                            • Hi peper10! Welcome on board!
                              Not sure if I understand what you have in mind... like have a ring with magnets mounted on with the coils inside the ring?
                              • Thank's for peply me seph!!!!!
                                I think you understand my point!!!!
                                You don't change anything to you're wiring....You just take off you're rotor
                                and make a rotor running outside you're coils...
                                I think this way you coul'd extract (centrifugal forces)from you're rotor..
                                By my calculations you gonna have 3to1 ratio from you're actual setup..
                                The only thing different is gonna be the rotor running outside thecoils,and ,
                                the magnets gonna be south facing towards the coils ...
                                Thank's for reply me...
                                By the way,pretty interesting setup you have...
                                Just sorry that i don't have you're skills and knoledges..
                                Peper10
                                Hope die last!!!
