Bedini SG
  • just looked at joul theif
    my coil ossilates at very high frequincies if i increase the resistance to base of tran . It also changes depending on wire length between resistors i can make it strong enough to phisically feel the ocillations everything starts to vibrate with it I did think of making the moter operate with ocilation and many coils but first I want keep things realy simple and then build from ground up the sg moter seems to be more than first meets the eye
    Is this the right area to ask questions on all parts of this moter
    • Right area
      I guess this would be the right place, if anyone has info to cross reference, they will. Threads here at energeticforum.com tend to have just the right amount of slack when it comes to staying on topic.
      I agree with your keeping it simple preference. Otherwise it gets away from you.
      • thanks for the hint
        it just clicked no nead for comutater though but yes dump charge back between firings
        • Between firings
          Yep, that's what I was doing with bedini setup pushing a pendulum :-)
          • bedini
            I hope this is the correct place to post
            I just built the school girl motor, 600 turns 2 wires, approx 2000 rpms, correct transistor/diode, POT is adjusted for correct impedance etc. But the one battery (9v) is draining. The motor stops at about 6V. Any ideas?? Thanks!
            • superconductors
              any one tried winding coil with a superconductor or even silver wire
              anyone tried super inductors
              anyone tried ferrite "soft" as a core
              if amp turns = magnetic flux and you have the windings made from a superconductor you could have huge amps very small volts huge gause ? ???
              power = volts *amps what am i missing here??? any help with formulars
              • docbob
                perhaps swap the batteries around again and again etc
                • Originally posted by docbob View Post
                  hi doc. the input battery is supposed to drain gradually over time. But I have a few questions about your system.
                  What type of 9v batteries are you using?
                  Did you clean and relubricate your bearings with a light weight lubricant? Have you tried experimenting with the pot to see if you get a faster charge on your output batteryon another setting.
                  You may need to add a flywheel to the system.
                  • Extra coils on a bedini idea
                    Ok, so there's the drive coil in a bedini system, and the radiant event at coil collapse is sent off to a charge battery.
                    While debating how to harvest additional energy from a bedini wheel, I've realised that one end of the coil connected to earth or source battery negative, the other to a neon to charge battery positive (with charge battery having grounded negative is better) will also only harvest the radiant event; no back EMF, no Lenz's drag. No current until magnetic field collapses and generates the spike, which jumps thru the neon and is put in the battery.
                    There's still magnetic drag from the core, but could be minimized by using hollow tubes as a core.
                    No need to get correct timing with reed switches etc......
                      So what you are saying is to put an earth ground on the common pole between the batteries and a neon in series with you charging output?
                      sounds like a winner to me because it's only the hv spike we want flowing anyway...and this way you have the indicator that the system is still charging as well. But i would run a minimum of two neon's in parallel with no resistors. That way if one of them flakes out you still have the other one.
                      one thing that I have thought about is putting ignition coils in series with the charging line and doing a single wire charge circuit for caps on the front end. I tried it briefly at one time for cfl's they lit but I didn't really like the output i got from them on my home made coil from reclaimed wire. I actually got better light output by putting one fowards and one backwards in series with a common neg post and just running a normal circuit. that got rid of the bright at one end and dim at the other problem too.
                      But i'm kinda like you i gotta have more output from my motor before i'm gonna sit back and say i've reached the holy grail of free energy: a prime mover motor that generates more power than it consumes. Though i'm a long way away from the prime moving part I think Jonny Davro has the right idea as far as charging goes, use a hybrid setup...Ultra light rotors and assisting LV motors to get them to high speed then you just adjust for the best charging rate.
                      Matt
                      • sg motor
                        Hey redeagle, Thanks for the quick reply. I'm using hard drive guts - very smooth. Tried most 9v's, lithium seems the best. I only have 4 magnets, maybe need more, and maybe they are too big or too strong?? I have the pot dead on - I think. Do I need to ground this thing? Has anybody had their batteries turn to crystals??
                        Thanks!! BOB
                        • Ground wire
                          @ Redeagle - The ground wire I was thinking would only go to charge battery negative - the two batteries would not be connected. I had thought that attaching source battery to same ground would drain the battery? But after your comment I'm not so sure. Good idea about two neons in parallel. Also I must admit, I'm driving a relay with the output from transistor; which is also connected to one end of the normally open switch contact, so while I should probably put a diode from the transistor, the hard off of the relay means I don't need a recovery diode there, just the neon.
                          When switch goes off, the magnetic field collapses which is an aetheric Stressfield; the aether re-stabilizes in an inrush which pulls electrons at high voltage from the charge battery positive, and to charge battery negative from ground.
                          For better explanation see bodkins primary state of matter thread page 3 and 4
                          see my schematic here:
                          Deep thoughts
                          It's got a delayed on mechanism because I'm pushing a pendulum at it's apex.
                          see the pic of bedini / veljko hybrid below the schematic - the 3 coils under the bike wheel will be wired one end to ground, other end to neon to charge battery positive. That's it... No complicated circuits for the pickup on those coils.
                          The principle could be the same for a bedini wheel. Extra coils don't have to drive the wheel.
                          Love and light
                          • Hi All,
                            Just a quick heads up. I know many of you already know this, but it totally slipped my mind until today.
                            If you are after CHEAP batteries in good condition, simply go to your nearest auto wreckers. The cars are totaled but the batteries are still good. Here in Oz most of them are reselling the batteries for between $30 & $60. Some of the small trucks or SUV's have some pretty decent batteries and these are a great substitute for propper deep cycle batteries during testing.
                            Cheers,
                            Steve
                            You can view my vids here
                            http://www.youtube.com/SJohnM81
                            • bedini spin
                              Does anybody think when the poles switch this will help reduce induced currents in the coil wires: http://www.overunity.com/index.php?P...0;attach=20655
                              and
                              I hope I can post links
                              • bedini said in one of his vids...
                                He said all of his batteries turned to crystals over night (overcharged with negative energy maybe?) Crystals have a nice property of generating energy all by themselves - has anybody read this puppy: http://www.nuenergy.org/pdf/electrinium.pdf or maybe John Hutchison batteries: hutchisoneffect.ca/Crystal Battery.html
                                Thanks guys... Later.
