conditioning batteries
Hello, i have a question about how you all are conditioning the batteries used in the ssg.
I know that conditioning is charging and discharging.
But at what voltage should one stop discharging the battery and recharging the battery connected to the ssg again ?
Should it discharge all the way to zero all the time before recharging (which is not recommended by most)?
Or should one just discharge till the battery gets to lets say 8volts?
And then recharge?
Bottom line is how are you guys going about conditioning your batteries?
I mean are you doing it different because the ssg can restore the batteries if not physicaly damage?
I ask because my personal experience is that one should not get carried away with this on a regular charger because it will ruin the battery but then again this is not a regular charger which is why I am asking this simple question that apply to a complex yet simple machine (paradox).
Iluminate please.
At least this is what is done to the batteries for the ssg correct?
Or can someone explain the process : short and simple?
And then recharge?
Iluminate please.
.thx in advance.
is why can I see up to 8 different pulsing spots past the 1st coil and before the 2nd coil that are lighting up off the SSG wheel,When I say lighting up I mean I see reflections off my magnets that are 1" long by 1/4" round and they are nickel coated so as to see a reflection and I know how you guys hate to hear this but yes they're neos
.The point is how can I see 8 reflections when I'm only using 2 magnets
.Well I figured my eyes must be playing tricks on me so I took a picture to verify If this could happen at the same TIME and it confirms that in fact it is happening at the same time.I guess the most logical answer is that my eye just cant notice the time change with regard to the speed of the magnets passing by those 8 points of reference and the camera is giving me the same affect as my eye sees.I can only get this affect with an old SSG coil with about 400' of #20 and #23 awg wire and can only get this on the #23 wire at about 1.2 amps.This core has the magnetized magnetite core.If i try normal air cores on the choke on the trigger I only get 1 or 2 pulses.
