My First Window Motor Replication
  • My First Window Motor Replication
    Hey. This is my first Window Motor Replication. I wanted to make it simple. So I hollowed a 2 X 4 and used that as my base. It is about 4.5"s in length. The rotor is made with six 1" X 2" X.5" neo magnets on it. They were taken off of another project. The shaft is .5" aluminum and the bearings are basic steel bearings I got for $5 each at VXB. I cleaned the heavy grease out of them. The wire is trifilar wound with 650 turns of 30ga x2 and 28ga x1. The battery is a Craftsman 19.2V NiCad that generally charges conventionally to 22.5 Volts.
    I am running it on a basic SSG circuit for know, but plan on putting together a half bipolar Bedini/Cole circuit to see what that can do. I have estimated the shaft to be turning between 450-500 rpm's. The amp draw is at 90ma.
    I just wanted to give an update. I stepped up to the bedini/cole half bipolar circuit using two of the windings for power and one winding for trigger. This bumped the rpm's up from around 450 to around 600.
    Next I used a reed switch to trigger the circuit. I've got small neo's at every 60 degrees to activate the reed switch. I am using all three windings for power. Wish I had a tach meter. I'm estimating that it is turning somewhere in the neighborhood of 1500 rpm's.
    I don't know what sort of spike's it is producing. The battery seems to be draining slowly. I have the bridge rectifier connected permanently. I may try switching that with a reed to see if that makes any difference.
    After I play with this for a while it will be on the full circuit and then maybe a generator on the front end.
    One more thing here that I may be missing, that could make a huge difference, is adding in a earth ground to the system. I read somewhere that people often miss this step in replicating this circuit. Does anyone have any input on this?
    dmann
      This is my 4th version of the window motor. It is switched with a commutator. I am able to get 1000+ HV if I put pressure on the contacts. It has very good torque. I am sure you could get some good practical use out of the mechanical side of this motor.
      dmann
        This is with the 1000+ HV commutator spikes
