Bedini and Rife technology
  • #31
    House grounding wire as a small scale antenna for immediate use...
    Originally posted by Vinyasi View Post
    Since the Schumann resonance is a good referencing tone below ten cycles per second, and since these pathogenic tones are above the dividing line between relaxation frequencies below ten cycles per second and heightened alertness (and stress inducing) frequencies above ten cycles per second, it may be a good idea to broadcast 7.83Hz most of the time and sporadically interject a pathogenic frequency for very short duration.
    And since nobody necessarily wants to erect an aerial and 'stick out' in his/her neighborhood, maybe it could be possible to utilize trees as broadcast antennas along the lines of direct coupling via Major-General George Owen Squier's receiver antennas? Or else, along the lines of loose coupling via ...
    A Tree Antenna for the 600 Meter Band
    Since LessEMF.com has a product that shoots a frequency into the grounding line of the house wiring...
    EARTHSAFE WHOLE HOUSE
    ...and you can even ask them to calibrate and mark the tuning knob to help locate its 7.83Hz output using their "Tuning Service" on the same page as that linked above, it's immediately apparent that the grounding wire of the house wiring is another possibility for emitting Rife Frequencies to heal everyone in the same building as yourself alternating with the Schumann tone as the predominant tone without resorting to attempting to implement the technically difficult "Ray Tubes" of Rife's bygone era as the emitting device of choice.
    But if Eric Dollard's description of our low voltage neutral grounding wire within our buildings is truly being shorted with the high voltage neutral on the utility side of the power company's transformer outside our building,...
    ... and since our building's grounding wire is linked to our neutral line at the bus bar in our breaker panel where our power enters our building from this transformer short at the utility pole, maybe using our building's grounding wire as our choice for broadcasting Rife and Schumann Frequencies may have a mild chance of propagating down the entire power line despite the huge voltage occurring on the utility side of the transformer, and thus heal everyone else in our local community within a limited range?
    At the very least, any possibility of impact is better than doing nothing about this...
    There must be a way to modify the audio signal output from our audio system to be able to drive the single wire of either an antenna or our building's grounding wire just as the EARTHSAFE WHOLE HOUSE device accomplishes? Then, a simple recording of these frequencies could be piped into any style of antenna.
    And if our building has a metal roof, in all likelihood this too is grounded and thus connected to our building's grounding wire making it an excellent output as an aerial.
    Since 7.83Hz, 2008Hz, and 2127Hz (+/- 1-2Hz) are well below radio broadcast frequencies because of their distinct audio range, this is not an FCC issue - right?
    • #32
      Does anyone know of any kind of handbook or instructional materials that went along with the original Rife device that provided instructions for tuning it? If someone were to happen across on of the original devices that sure would come in handy. Hint, Hint.
      • #33
        The video May 2014 Steven Ross lecture on Rife shows pictures of the microscope and how it worked. Some of the claims are large. Energy medicine is the main focus
        but the method of viewing the colors in the micro world is another mystery about energies that are less understood.
        It was a unique method to heterodyne light which identified a color corresponding to a frequency that was lethal to that specific organism.
        This made possible an analysis of light energy related to micro organisms using this unusual light microscope.
        The specific frequencies where documented for many viruses.
        Also note there was an anomaly at a specific frequency that did strange things:
