This is a sticky topic.
  • possible substitution for IRFPG50
    FWIW, I wonder if the IRF842 would work. I happen to have a couple in my spare parts bin. They are repetitive avalanche rated.
    IRF842 Datasheet pdf - N-CHANNEL ENHANCEMENT-MODE SILICON GATE TMOS POWER FIELD EFFECT TRANSISTOR - Motorola
    "http://www.datasheetcatalog.com/datasheets_pdf/I/R/F/8/IRF842.shtml"
    I'm no expert on reading the datasheets, but the only significant difference I can see is the PG50 is rated for 1000v and Rds@2ohm, and the the 842 is rated for 500v and Rds is 1.1ohm.
    I know I could simply plug it in and try it, but alas, I have no oscilloscope and I wouldn't be able to confirm it anyway. (sigh)
    -kent
    • Hi Kent - you could check the heat on the load and the battery draw down? But Fuzzy - we need your expertise here.
      EDIT Thanks Fuzzy. Yet again. much appreciated.
      • Originally posted by kent_elyue View Post
        -kent
        Hi Kent,
        I cant see on the PDF any information on Single Pulse Avalanche Energy or Repetitive Avalanche Energy these are two very important Mosfet specifications for these "replications".
        The IRFPG50 is the standard profile and anything very close to these parameters may work ....
        International Rectifier IRFPG50
        Single Pulse Avalanche Energy - 800 mJ
        Repetitive Avalanche Energy - 19 mJ
        Here are some more possible examples ....
        Fairchild Semiconductor - FQH8N100C
        Fairchild Semiconductor - FQAF11N90C
        ST Microelectronics - STW9N150
        Hope this helps, Thanks for your parcipitation in this venture !!
        Glen
        EDIT- I found a International Rectifier Data Sheet for your IRF842 ......
        International Rectifier - IRF842
        Single Pulse Avalanche Energy - 610 mJ
        Repetitive Avalanche Energy - 13 mJ
        The Single Pulse Avalanche Energy is low but it may work, but without a scope it would be hard to know.
        Open Source Experimentalist
        • Oh well
            Poynt
            Also you are ok with using the flyback output to charge a totally separate battery correct? And it is one of your claims that battery recharging does occur with or without the flyback diode present?
            Yes
            Use a transformer and full wave bridge off the load coil to convert the AC voltage across it to a filtered DC voltage.
            Not sure what a 'filtered' DC means. Presumably just that the AC changed to DC? I know from personal experience on AC tests that there's a marginal loss through those diodes on the bridge rectifier. Doesn't matter much on high voltages but not sure of the effect on lower values.
            We would use a transformer so that the DC output voltage may again be referenced to the source battery ground. Then this output will be applied to the source battery in the hopes that it will gain charge?
            Not sure why you need a transformer if the inductor itself generates the required.
            This of course means placing the transformer primary in parallel with the load coil.
            Ok. We've tested this variation but the current flow was quite extreme.
            The use of a transformer may make things a bit lossy (depending on your slant here), but if COP>17, this slight loss should be more than compensated for to keep the circuit alive and running indefinately.
            Poynt - are you proposing this circuit to be simulated or actually built? Quite frankly I'm having difficulty understanding the rectifier arrangement and where you'll return the energy - another battery? - the source? Whatever. Can you give us a schematic? And why do I get the impression you've done this? Indeed I'd be interested in the results. I'm a sucker for punishment.
            But I would very much appreciate the data from Aaron's last test and from the published experiment posted here for easy reference. Please oblige.
            The proposed circuit add-on could be built. The AC that feeds the transformer primary would come off directly across the load resistor. This would then feed a diode bride off the secondary and this filtered output could be used to recharge the source battery. If COP>17, then this should allow the circuit to run itself indefinitely. If most of the excess energy manifests as voltage/current across the load resistor then this should work. If you claim the the excess energy manifests elsewhere, then it might not work as proposed.
            .99
              Sorry Poynt - I missed this. Many thanks. Ok. Can you firstly do a repeat of the published circuit. Presumably it may require those amendments to the switch? Or do you even need a switch on a sim? Then at 3% ON - waveforms over the shunt, wavforms over the load resistor, waveforms over the battery. And some quick reference to their average values and the wattage levels of energy dissipated/delivered.
              Then the same on Aarons new circuit.
              Many thanks
              Not sure what amendments to the switch you are referring to. The diode? I can do the published circuit, with our without the 555 (I would prefer without as it won't achieve 3.7% as published), but I'm not so sure I can do Aaron's. I will have to take a close look. I would also doubt that I can obtain the crazy circuit operation. Unfortunately, with this version of SPICE, one can not tweak the pot values in real time to see the effects. It could take days to try all settings and combinations and even then there is no guarantee that the thing will break into the funky oscillation mode.
              You have stated that the circuit will exhibit overunity without the funky oscillation, and with or without the flyback diode. This is what I would prefer to simulate.
              May I ask what it is that you are expecting or hoping to see with your requested wave forms?
              • May I ask what it is that you are expecting or hoping to see with your requested wave forms?poynt
                I'm sort of expecting something like Aaron's shown us? But I've no idea. Sorry you can't replicate Aaron's test. But I'd still like to see the published test.
                Poynt - that circuit configuration you proposed with the bridge rectifier and the inductor - please give us a schematic. I take it you'll be using a functions generator.
                  This is not helpful to me. First from Aaron, I can't recall seeing anything conclusive or remotely what I would call "informative" wave forms taken from your original published circuit. Second, if you are asking me but have no idea what you are going to compare it to or why, then it would be time wasted, and I feel it is not fair to ask.
                  I think many of us (on this side of the fence) are still trying to figure out exactly what Aaron's test was all about. At such low currents it's difficult to get reliable readings. I was hoping you'd have something concrete that you could relay to me as to what you expect to see. Saying "something similar to Aaron's results" just doesn't give me a heck of a lot of incentive.
                  I'll draw up the proposed add-on. I am certain that if Aaron (or Harvey in proxy) sees this he will devise some reason as to why it is going to "kill the effect", but since you're curious, I'll post it anyway.
                  .99
                  • COP test?
                    A proposed COP test. Rosemary asked for the schematic.
                    HF capable transformer.
                    Capacitor filtering on output would be optional, but not necessary. With COP>1.5 or so, should work in theory, if excess COP appears as usable V and I in the load to obtain real power output.
                    • Originally posted by poynt99 View Post
                      .99
                      Ok. I take it that this is a circuit designed with the intention to defeat unity. Let's see the results.
                      And regarding your penultimate post. Poynt you're an obsessive compulsive. I know this. I have to read it through again and again and again. I'll skip it if you don't mind. Let's just see the outcome of this one.
                        -kent
                          .99
                          You may wish to revisit the bridge connections
                            Indeed. Shouldn't draw when so tired.
                            Thanks for the pickup. Diagram is updated.
                            .99
                              I drew back once in answering your posts, but obliged lately in hopes of making a connection. No Go. I simply can't communicate effectively with you. I am also growing rather loathsome of the insults, labels, and consistent and flamboyant convolution of my posts and their intended messages.
                              Adieu.
                              .99
                              • "Amy Pond, there is something you need to understand, and someday your life may depend on it: I am definitely a madman with a box." ~The Doctor
