I finally found some time to work on free energy theories again. I updated my article over at Pes with some literature and quotes, most notably Eric Dollard.
I have read quite some literature on Tesla technology, but most of them just don't cut it, one way or the other. Eric Dollard's stuff does. And he's alive:
Interestingly, Prof. Turtur tells us there is an energy exchange between the propagating electric field and the active vacuum, or medium, or lumeniferous ether:
Article:Free Electric Energy in Theory and Practice - PESWiki
More posts by Eric:
I took the liberty of posting Eric's documents on my website, without explicit permission (see my article). However, I think we just need this stuff. We cannot allow these documents to dissapear into oblivion because of some copyright rules.
You know, Eric is a real genious. And he has been badly treated. I don't know how or what, but he had some hard times, that's for sure. Anyway, his work has not been accepted by main stream science. THAT is a mistake, a mistake we have to fix. And the only way to do that, is to study his work. It is a very solid theoretic foundation along the lines of none less than Nikola Tesla.
So, let's see what comes up.
The Einsteinian Lie has succeeded in instilling a mind virus in most everyone and also in confusing Main Stream “Scientists”, who today waste billions of dollars of funding each year, only to chase their own tails in a canonic sequence.
Chris Carson Built the Rotary Electrostatic Converter. His design was based entirely on my electrical theory and math. It was designed to demonstrate and validate the concept of Synchronous Parameter Variation and the Four Quadrant Theory of Electricity. The device worked well. It had to spin up to around 10,000 RPM. This unit took Chris months to complete; to get all of the parts together, and to get it perfectly balanced and operational. Chris determined that it was starting to exhibit the effects of synthesis of electrical energy from the electrostatic field. This is a result of the variation of capacitance (C in Farrads) with respect to time (T in seconds) which results in a negative conductance G (in Siemens). Hence the generation of electric energy. Then, disinformants, whom I refer to as the “Montauk Crowd” swooped in on him after he completed this device, and he was never the same again, - he died of Brain Cancer a year or two later…
There was also the Rotary Electromagnetic Converter, constructed by Michael Knots and Peter Lindemann with the help of Chris Carson. This unit exhibited the property of materializing and dematerializing electric energy without regard for the Law of Conservation of Energy. This is another example of synchronous parameter variation. In this case inductance (L in Henrys) time (T in seconds) gave rise to positive resistance (R in Ohms), hence the unaccounted for destruction of electric energy. It must be just as illegal to destroy energy as it is to create it – don’t you think? E is NOT equal to MC squared. There is no Matter to Energy equivalency – this is: The Great White Lie…
The answer to these questions can be found in the paper Conversion of the Vacuum-energy of electromagnetic zero point oscillations into Classical Mechanical Energy by the German Professor Claus Turtur. In the chapter "A circulation of energy of the electrostatic field" (pages 10-14) he makes a straightforward calculation of the energy density of the static electric field surrounding a point charge using nothing more than Coulombs law and the known propagation speed of the electric field, the speed of light, and shows that there must be some kind of energy circulation between the vacuum and charge carriers:
If electrostatic fields propagate with the speed of light, they transport energy, because they have a certain energy density. It should be possible to trace this transport of energy if is really existing. That this is really the case can be seen even with a simple example regarding a point charge, as will be done on the following pages. When we trace this energy, we come to situation, which looks paradox at the very first glance, but the paradox can be dissolved, introducing a circulation of energy. This is also demonstrated on the following pages.
The first aspect of the mentioned paradox regards the emission of energy at all. If a point charge (for instance an elementary charge) exists since a given moment in time, it emits electric field and field’s energy from the time of its birth without any alteration of its mass. The volume of the space filled with this field increases permanently during time and with it the total energy of the field. But from where does this “new energy” originate? For the charged particle does not alter its mass (and thus its energy), the “new energy” can not originate from the particle itself. This means: The charged particle has to be permanently supplied with energy from somewhere. The situation is also possible for particles, which are in contact with nothing else but only with the vacuum. The consequence is obvious: The particle can be supplied with energy only from the vacuum. This sounds paradox, so it can be regarded as the first aspect of the mentioned paradox. But it is logically consequent, and so we will have to solve it later.
Important is the conclusion, which can be found with logical consequence:
On the one hand the vacuum (= the space) permanently supplies the charge with energy (first paradox aspect), which the charge (as the field source) converts into field energy and emits it in the shape of a field. On the other hand the vacuum (= the space) permanently takes energy away from the propagating field, this means, that space gets back its energy from field during the propagation of the field. This indicates that there should be some energy inside the “empty” space, which we now can understand as a part of the vacuum-energy. In section 3, we will understand this energy more detailed.
But even now, we can come to the statement:
During time, the field of every electric charge (field source) increases. Nevertheless the space (in the present work the expressions “space” and “vacuum” are use as synonyms) causes a permanent circulation of energy, supplying charges with energy and taking back this energy during the propagation of the fields. This is the circulation of energy, which gave the title for present section 2.2.
This leads us to a new aspect of vacuum-energy:
The circulating energy (of the electric field) is at least a part of the vacuum-energy. We found its existence and its conversion as well as its flow. On the basis of this understanding it should be possible to extract at least a part of this circulating energy from the vacuum – in section 4 a description is given of a possible method how to extract such energy from the vacuum.
