At this time I am engaged in the study of details for the continuation of Inductance and Capacitance series of writings. The established dimensional relations are N.F.G., even in the writings of C.P. Steinmetz. Too many canceled dimensions thru unit values, and lots of missing versors in space. For example, in Inductance calculations the radius of a circle is a line, the circumference of a circle is a circle. Here we have two distinct co-ordinate systems, or vector expressions, a kind of space quadrature. Thus
c = 2(pi)r Centimeters
is not vectorally complete, it is
c = 2(pi)kr Centimeters
where k is a versor operator. Hence it is that c and 2πr are not interchangeable. Here is an important complication in the dimensional relations for Inductance and Capacitance.
Hi Eric,
First of all, thanks for your reply and input. I am quite busy at work at the moment, because I have only 4 days left before I have vacation and I have to finish some stuff now.
Anyway, I have been studying your "Symbolic Representation of the Generalized Electric Wave" recently and I am beginning to see what you are talking about with your dimensional relations, but I still can't get to the bottom of it.
You definately have a point here, but until I can paint a picture in my head about what is going on, I can't get this stuff straight.
In mathematics, the quaternions are a number system that extends the complex numbers. They were first described by Irish mathematician Sir William Rowan Hamilton in 1843 and applied to mechanics in three-dimensional space. A feature of quaternions is that the product of two quaternions is noncommutative. Hamilton defined a quaternion as the quotient of two directed lines in a three-dimensional space[1] or equivalently as the quotient of two vectors.[2] Quaternions can also be represented as the sum of a scalar and a vector.
This appears to be very similar to what you do in your "Symbolic Representation of the Generalized Electric Wave".
About the scalar part:
Scalar and vector parts
A number of the form a + 0i + 0j + 0k, where a is a real number, is called real, and a number of the form 0 + bi + cj + dk, where b, c, and d are real numbers, is called pure imaginary. If a + bi + cj + dk is any quaternion, then a is called its scalar part and bi + cj + dk is called its vector part. The scalar part of a quaternion is always real, and the vector part is always pure imaginary. Even though every quaternion is a vector in a four-dimensional vector space, it is common to define a vector to mean a pure imaginary quaternion. With this convention, a vector is the same as an element of the vector space R3.
Hamilton called pure imaginary quaternions right quaternions[9][10] and real numbers (considered as quaternions with zero vector part) scalar quaternions.
So, here we have a definition of "scalar" that differs from your definition:
So, in quaternion notation, the whole term "(RG + XB)" is called "scalar". Clearly, with such a definition, you can have "scalar quaternion waves" consisting of the longitudinal XB component.....
In mathematics, more specifically in abstract algebra, the Frobenius theorem, proved by Ferdinand Georg Frobenius in 1877, characterizes the finite-dimensional associative division algebras over the real numbers. According to the theorem, every such algebra is isomorphic to one of the following:
R (the real numbers)
C (the complex numbers)
H (the quaternions).
These algebras have dimensions 1, 2, and 4, respectively. Of these three algebras, the real and complex numbers are commutative, but the quaternions are not.
This theorem is closely related to Hurwitz's theorem, which states that the only normed division algebras over the real numbers are R, C, H, and the (non-associative) algebra O of octonions.
Isomorphisms are studied in mathematics in order to extend insights from one phenomenon to others: if two objects are isomorphic, then any property that is preserved by an isomorphism and that is true of one of the objects, is also true of the other. If an isomorphism can be found from a relatively unknown part of mathematics into some well studied division of mathematics, where many theorems are already proved, and many methods are already available to find answers, then the function can be used to map whole problems out of unfamiliar territory over to "solid ground" where the problem is easier to understand and work with.
So, this quaternion stuff seems to be well worth studying. It appears to be very similar to what you do in your "Symbolic Representation of the Generalized Electric Wave", while at the same time it appears to be even more general and may even be capable of being extended to the dimension of time, because this is a 4 dimensional algebra...
BTW, did you note that the Russian paper he referred to about parameter variation has recently been translated into English?
Lamare, this was a point I brought up a couple pages ago and was soundly trounced for it. Eric has mentioned his concern over the loss of proper dimensions, I understand his concern and feel that quaternions hold the key. Hopefully you get a better response, I was chastised for the suggestion.
It has been repeatedly observed in the previous writings that any given dimensional relation, say Volt, Ampere, and etc always exist in a dual relation. This is known since it is e, in volts and E, in volts. The geometric archetype of the electric phenomena is four polar. This polar quadrantal form is well expressed in Native American art forms. These serve as their "Versor Diagrams" for the four polar seasons and lunar positions. These are important for those that "live outside". See "When Stars Look Down" for a good popular, not technical, description of this topic. The quadra-polar concept in the mind of Nikola Tesla resulted in the polyphase motors and generators of todays AC technology.
It is likewise, Inductance and Capacitance are a pair of co-efficients representing a pair of fields, and in turn each representative co-efficient in itself exists as a pair, hence giving the four co-efficients total.
Steinmetz first noticed this quadrature pair of inductances in his study of the AC power transformer. This inductance now exists as a pair of inductances: the Leakage Inductance, L, and the Mutual Inductance, M. The lines of induction for L are at right angles (Space Quadrature) to the lines of induction for M. So it is L and M do not "see each other". Alexanderson utilized this is his magnetic amplifier. Here the saturation flux must be in space quadrature with the power flux. It is then that the two are separated but in the same core. In a metallic-dielectric form it is given as a torroidal magnetic circuit, wound with a pair of metallic circuits, one in winding around the core cross sectional area, the other winding at right angles to the torroidal windings, this being circumferal around the core. (See Alexanderson Patents). Here derived is a "Quadrapolar Inductance Coil". This quadrapolar inductance, LM, serves as a first step towards understanding tesla type transformers. Needless to say P.E.E.E. Pupin rudely declared Steinmetz as un-Maxwell. So Here we go again.
With regard to parameter variation only the first step has been taken. For example:
Henry per 1, or Henry
Henry per 1 second
That is to say
Henry per second, or Ohm
But what about Henry per second square, or what?
Hueristic (see Guillimen) dimensional relations will be utilized as before.
To quote Maxwell "Electricity and Magnetism" volume 1, page 2;
"A knowledge of the dimensions of the units furnishes a test which ought to be applied to the equations resulting from any lengthened investigation. The dimensions of every term of such an equation, with respect to the three fundamental units must be the same. If not, the equation is absurd, and contains some error, as its interpretation would be different according to the arbitrary system of units which we adopt."
I would like to ask some questions about the presentation "The Eagle Has Landed" because there are particularly critical points that need to be examined and I would like to fully understand what Eric is presenting. I think his ideas are important to properly understand electricity.
One point which is crucial to this is Fourier's principle of Homogenity, which simply states that the dimensions must match. This is so crucial that I mention that even James Clerk Maxwell's 1864 paper, or subsequent revisions as done by Heaviside and Gibbs and others suffer from this problem, but I don't wish to deter from the course of the present discussion.
Eric writes, quoting
Three dimensions form the primary basis for subsequent relations:
(1) Q, Total Electrification, Planck,
(2) t, Time, Second,
(3) l, Space, Centimeter.
end quote (abridged)
Let's assume this for the moment and keep homogenity intact. I feel it is important to point out that Q is of the dimensions energy-seconds, a quanta of energy * seconds. Now these are nit-picks, but can we divorce Q of the dependency upon seconds, and keep it pure energy? Also can we keep length as dimension 1, knowing that space is of dimension 3? I trust we can agree on a Cartesian 3d definition at the moment for space. (I am trying to stay mathematically precise here, not be critical of what is written, and I fear that my comments will be mistaken.
It is important to lay a foundation of definitions.
At this moment, I do not understand how Total Electrification applies to energy, but I set that aside.
Eric continues...
quoting
Subsequently established has been a series of dimensions and dimensional relationships, save yet Inductance, Capacitance, and the Electric Force. Two primary substantial dimensions were established by divorce from Q.
(1) ?, Total Dielectric Induction, Coulomb,
(2) F, Total Magnetic Induction, Weber.
Derived then are four secondary, or compound, dimensional relations:
(1) I, Displacement Current, Ampere,
(2) E, Electro-Motive Force, Volt,
The laws of induction; and,
(3) e, Electro-static Potential, Volt,
(4) i, Magneto-Motive Force, Ampere,
end quote
Okay, I admit that I am now confused. We have the Coulomb and Weber introduced, then the Ampere and Volt is introduced subsequently and in pairs. I do not have the actual dimension units of energy/time/length connected in anyway to these 4 or 6 terms. I would prefer to use 6 terms, not 4 to avoid the possible confusion later on.
First question:
Can we define the Coulomb and Weber and Ampere and Volt in terms of our 3 fundamental units?
Eric continues...
quoting
The laws of proportion.
Hereby it is we have two Volts and two Amperes:
Volt; Weber per second, E,
Volt; Coulomb per Farad, e,
And
Ampere; Coulomb per second, I,
Ampere; Weber per Henry, i.
end quote
Now two new terms are introduced, Farad and Henry.
Second question:
Can we get a formal definition of Farad and Henry?
Eric mentions that energy is Planks per second, but that means that the Plank unit has dimension of energy*seconds. I want to argue that we divorce energy from seconds, and keep it strictly energy units (following Fourier's homogenity principle)
It is mentioned that energy is Plank/second and Power is thought of energy expressed per second or Plank/second^2 so I agree with the definitions as they are dimensionally sound.
Eric mentions the need to cleanse the system of units and dimensions. Might I first introduce the SI base units, so we can make sure that we are not missing or omitting anything?
Randall, forgive me for assuming, but your reference to this last post by Mr. Dollard as "a" or "the" presentation gives me the impression that you are not aware of the rest of it. I, unfortunately, cannot answer your questions myself, and my experience with math only goes one imaginary layer deep, so I would just ask you whether you have read though the compilation here, and the references cited as "necessary."
Hopefully, we can all help each other to understand this work. I'm still waiting to see who gets the gold star for the Magnetic/Dielectric field ratio question.
"The first peace, which is the most important, is that which comes within the souls of people when they realize their relationship, their oneness, with the universe and all its powers, and when they realize that at the center of the universe dwells Wakan-Taka (the Great Spirit), and that this center is really everywhere, it is within each of us."
Eric does not define Q in energy-seconds. Q (Planck) is weber-coulomb. The product of psi and phi.
Rewind to the post entitled "Energy Defined", wherein Eric discusses the difference between his Q and the "Einsteinischen dimensions of the Planck" (energy-time).
Rewind to "Continuing with Variation of a Dimension with Respect to Time".
I would like to forward to you a work that I believe you will recognize, so how can I do that?
Quarterpole:
Your point is well taken, the search engine brought me in around page 21 or so, so thanks for asking me to back up and reread. There are dozens of questions I could ask, but I had to start somewhere, and thought when Eric was laying a foundation that we could move forward from there.
Unfortunately as a mathematician, there has to be a consensus on terms, and so this is a difficulty that Eric will face, if he wishes to use his definition of Planck. I already referenced the conventional understanding, because I was trying to ferret out the problem with dimensional homogenuity which exists. If we are going to have a discussion with the conventional scientists in an attempt to get them to change their minds (and following the math will do it) then we do need to have the mathematical definitions nailed down.
Pault:
Thanks for causing me to back up to previous posts, the product is indeed Planks/cm^4 as Eric states. However there is something that I need to ask, if (quoting) "The total electrification Q in Plancks is a resultant of the union, of PRODUCT, of a pair of inductions, the total dielectric induction, Psi and the total magnetic induction, Phi", are we not assuming that the orientations are parallel? In examining the terms, we find flux is measured as some type of quantity per area element. If we take a direct product, are we not assuming that the two area elements are parallel? I would appreciate some clarification here on just what exactly union means. Once again, the math will provide the crucial distinctions.
These would be the lines of force. Magnetic and dielectric field lines.
So, I think, Psi, Phi, and Q are all just "numbers" that exist at right angles to each other. Maybe we can use Planck's constant and the existing definitions to work backward and see just how many lines are in a Coulomb?
I don't think you need to be apologizing. Nobody else seems to have stood up and said, "I totally understand!" So it can be nothing but helpful if people can ask the right questions.
Peace.
I failed to edit my post, so I just need to point out that "apologize" is not a appropriate word, in response to "I appreciate everyone's patience."
The appreciation is mutual.
The biggest problem that I have is while we have excellent mathematical information, being an old antenna builder myself, I still do not grasp what is going on with the tesla MT (antenna) to the point to be able to simply sit down and design one from scratch with any kind of confidence it will perform as expected.
There are 3 maybe 4 coils and I am sure that each one has a very specific function and relationship to one another to operate in a system to become a LMD transmitter.
So I know what we want to accomplish as the end result but I do not know how to obtain it without intimately understanding the exact purposes and how each element within the transmitter is supposed to operate because for me at least it is not obvious in the math. That is to say that I have the cement, sand, and rock, but do not know that I need to mix 1 of each to obtain the proper mix.
Eric has done a wonderful job in his videos explaining much of this that has helped tremendously its when I try to visualize the circuit, standing waves, resonance, impulse response and how that can occur from the physical picture of the tower design escapes me.
It seems it has to be done the pancake style and no tight wound coils and operate in a nonradiative mode?
Its not really obvious how to maximize for simultaneous maxim decibel and resonance tuning at the same time either to get this individualization tesla talked about. I am left with the impression that maximum impulse would be obtained by maximizing series capacitance.
It sounds like we are supposed to be winding coils that do not radiate, where the first coil is a broadband input that requires large surface area to maximize the transfer of the pulse, then the second coil to impedance match and contain the ring around finally the tall one to self oscillate or be near self oscillation to keep the whole system alive and act sort of like a self priming pump.
Its all guesses for me probably because I have been so well indoctrinated and brain washed by the stiner system. Then again maybe some important distinction(s) slipped past me. Um ok didnt see Erics last post, looks pretty intense BRB.
Hi guys. This is some great discussion going on, I'm glad to see others attempting to do the math and compare and contrast with "consensus reality" (which isn't so real)
I'd just like to point out that Eric is actually posting to the forum by writing hand-written letters and sending them by mail to someone who does transcriptions onto the computer. This is his preferred method of communication, being from a different generation than many of us. As such, he is not likely to reply directly to the forum. As Eric is proposing a consistent system of units and algebra for manipulating them, we will just have to keep following up on all the posts and reference material so that we may each come to our own intuitive understanding of what he is trying to say.
I am hoping that at some point in the near future we will get to designing actual experiments which we can perhaps calculate and measure using the new units being proposed. Basic, physical experiments which can be used to gain hands on experience with the behavior of the phenomena which are being described. Perhaps we will need new measurement tools as well, or at least we will need to use the "adapter" functions to convert from conventional units into Eric's form.
Was Oliver Heaviside right? Independent Verification from Neural Science
It appears that he may have been right all along. This fascinating paper on how nerves conducts signals seems to vindicate Heaviside as being correct, as using the conventional theory shows empirical failure.
Hi 7imix,
This was how the thread has been progressing so far- hand written letters that were mailed. However now I've been able to get Eric internet access so he can see your guys' responses in real time.
Just a few quick things that Eric would like to see you guys start doing(from Eric):
1. Stop using the notion of charge and Q. Use dielectric induction and the greek letter psi. Start using the units he derived. It makes him frustrated to have derived all the units- and then nobody uses them, reinforcing their misunderstanding. Forget everything you know and start over. Start using big E or little e for volts, depending on the context. Use the system of units he derived- there was a reason for him doing 40+ transmissions doing this.
2. Eric is very new to computers. He hates seeing links to things. So if you are going to reference other material, pictures, etc. try to post those things directly in the thread so people don't have to follow a link to see the material. When possible if the link referenced isn't too lengthy. If it's too lengthy try to take some kind of excerpt. It will be easier for him to see things that way, and you are more likely to get some kind of response from him. If there is a link to something you can pretty much assume Eric won't read it. For instance he is pleased with what Kokomojo did in post # 633
