This is a sticky topic.
  • Originally posted by garrettm4 View Post
    For those who would like to know how I constructed my solid-state SPV generator take a glance at the circuit diagram:
    While there are many improvement to make, the basic design does works, although it is a bit complex to control all the switching elements.
    Some insight into how and when the switching should take place consider the diagram below:
    (This diagram was made with Microsoft Mathematics for those who would like to graph the waves under study, I have the worksheet saved if anyone wants it)
    The, 2x frequency, blue square wave shown is one of the control signals for the circuit and for the sake of discourse we will say it controls the MagAMP in the above circuit diagram. The green sine wave is that of voltage and is in a quadrature relationship with the purple sine wave of current and the black, 2x frequency, is that of power, something that will interest you is that the power waveform goes into both the top and bottom half of the graph, this represents reactive power or a surging to and fro of stored and returned energy. Something to take note of, is if, the black waveform is on one side or the other, top or bottom of graph with respect to the x axis, this would mean unilateral transfer of power is taking place, or simply power dissipating into a load. Dependent upon the actions taking place in the circuit, the power waveform can be any place between the two points of top/bottom or in between. Thus you could see in a device that returns more power than it consumes, such as in the circuit above, that the power wave form will be smaller on top and bigger down below where it is situated on the x axis. Thus the source input becomes a load and the load now a source. The understanding that power is a cross product of voltage and current, with phase angle taken into account, and the direction it flows is fundamental in making one of these devices work. Now back to the blue control waveform as seen above, the current pulsed into the control winding of the MagAMP controls its relative saturation or capacity at any one moment in time. Thus you would saturate the core from the zero crossing / rise to peak portion of the purple wave and desaturate at the peak to fall / zero crossing portion. Thus inductance changed from L0, low inductance to L1, high inductance at the proper times. As for the switched capacitor as can be seen in the circuit above, you would have a separate control signal that would be out of phase with the one controlling the inductance. Thus the capacitance would go from CO, large value from zero crossing/ rise to peak and to C1, small value at peak to fall / zero crossing.
    What you will notice is that there will be two resonant frequencies C1 & L0 and L1 & C0. Caused from C1 discharging into L0 and L1 discharging into C0.
    Take into consideration the following equations:
    The first one shows the discharge of C1 into L0 with currentA and voltageB and the other shows L1 discharge into C0 at currentA and voltageA, this caused from the fact that current remained the same during the point of parameter change for inductance but voltage changed because both capacitors are now in parallel. With the law of conservation of energy taken into mind, these equations state, that the maximum energy stored could only be that of the source energy, or L1 for C0 and C1 for L0. Thus excess energy can only come from the parameter change and nothing else.
    Note that if you can get one of these devices to work, they simply self destruct within a few seconds of operation, if you loop the two equations above you will see a exponential rise in oscillatory energy. Thus you need to properly load the circuit to remove the excess energy from the oscillatory system. The concept of positive feedback to build the oscillations and a negative feedback mechanism to control the magnitude of the output comes to mind. The best method would be to alter the phase angles of the control circuits and not their frequency so as to slightly alter where on the curves of the voltage and current you choose to change your parameter. So a microcontroller could, with some hard work, tame the circuit, at least in principle.
    Do you have any test data from the circuit?
    I understand the possibility of using the Magamp to vary the inductance successfully, but do you really think that using two static caps being switched in and out of position will really work as a true capacity parameter variation?
    I have yet to do any extensive analyzing of the numbers, but from all of the math that I've worked with in the "Charge Conserving Capacitive Spring" thread suggests that you actually need to move capacitor plates in order to produce the effect that we are looking for.
    • Graphing of Sine Waves
      To assist anyone who would like to graph these waveforms for further study I copied some of my notes on the graphing of sine wave in radians:
      The above notes are intended to help anyone who didn't know how to graph a wave with dc offset or phase angle relations and are not meant to be a all in one source on the subject.
      I hope someone finds them useful.
      Garrett M
        What is this Special SSR that you speak of?. I hope to find it so that I can replicate your circuit and put up a yotube.
        • Swithced Capacitor
          In my view, which to some may seen crazy, it is the method of the implementation of any one thing that makes it useful, or in other words, it is how you use it and in what context. The two capacitors in series/charge, and parallel/discharge, is only used to lower the voltage of the design and raise the current of the variable inductor, but needs to be matched to the proper natural impedance or natural admittance of the circuit so as to be able to transfer the excess work of the variable inductance.
          On a side note, the method of two capacitors, parallel/charge series/discharge, isn't very useful for charging batteries from my experience, although I have seen some strange effects, the battery will charge extremely fast after having been completely discharged in a sudo-"Tesla Switch" oscillator (described by "Bill & Ray" on one of Bill Jenkins radio broadcasts), as opposed to being discharged normally in a resistive load and then charged. So the thoughts of a battery as a giant electrolytic capacitor come to my mind and lines of dielectric force to describe why that the above use or method is quite a poor implementation. In my view, dielectric lines of force want to "move" into something like an inductor and thus a translation of energy takes place. John Bedini's battery charging method comes to mind although it is used in a different context, the thought can be retained of impedance matching and the use of one type of energy to generate another type, dielectric to magnetic and vice versa (if the idea of a battery as a giant electrolytic capacitor is used).
          The point being, the circuit I gave was in a unique situation where there is a resonant tank shuttling energy across one storage element to another fed by a unique source (switched battery bank) that is able to absorb and store excess energy, if present. If the parametric variation is disabled or turned off the the LC tank will still build a high resonant current and voltage across its-self (but to the source seem as an infinite resistance, if it has a high Q), and if you modulate the right parameter at the right time, it is theoretically possible to get excess work but that doesn't mean the resistive load you hook up will use it properly. So the difference in my implementation is use of the switched capacitor merely as a means of translating the excess work of the variable inductor to match a single resonant frequency as opposed to two resonant frequencies from one value of capacity. The use of the unique transistor configuration (known as a solid state relay) is from the fact that a single transistor transfers power uni-directionally and not bidirectionally as would be required to transfer the excess energy back to the source, if present.
          Now, I can say that I do think it is possible, under the right context of use, to use a switched capacitor and have a successful result. With out belaboring the issue, you will only know if you try, theory helps but doesn't dictate reality, and sometimes reality is quite harsh.
          Please read "Correction on Design and Use of a Switched Capacitor" I posted below for a update to this general Idea
          Garrett M
          • I understand your method. My bad on the confusion.
            I'm sick of trying to tame high voltages for parameter variation using a Joseph Hiddink capacity changer. Magnetism is the next step...
            Have you determined a good start for a core material?
            • SUPPORT ERIC DOLLARD'S WORK AT EPD LABORATORIES, INC.
              • Originally posted by T-rex View Post
                DE N6KPH
                Hi Eric!
                Keep it coming!
                Here is one of your Classic Borderland Research videos that I just found today!
                Free Energy Research with Eric Dollard, Peter Lindemann and Thomas Brown on Vimeo
                Classic borderland labs video from 1987.
                Eric Dollard gives a demonstration of the two sides of electricity, the decaying electromagnetic side and the growing dielectric side, and shows his singing Tesla coil burning Golden Ratio patterns into wood.
                Peter Lindemann demonstrates his Rotating Parametric Transformer operating at 108% efficiency. Shows an Alternating Current N-Machine provciding the researcher with AC waveforms directly extracted from space.
                Amazing science from the golden days of borderland research!
                The Alternating Current N-Machine looked promising, was it ever developed or found to be over-unity?
                Cheers Mike
                • @Garrett M
                  Many pages back in this thread, we demonstrated a rotary inductive parameter change device and found that it clearly worked as described in the Russian article. As with their device, we found that the drive motor was being loaded consistent with the increase in output power. It was very obvious that one could create power without any form of rotating magnetic field, but it was also obvious that wasn't going to exceed unity.
                  That pushed us toward considering other designs that might alter inductance or capacitance in such a way as to not require a mechanical force. We had a number of ideas, but had largely lost confidence in the concept and did not pursue them further.
                  Admittedly I have not studied your design in detail yet, but something you said caught my eye. Yes, these things do ramp up rather quickly, and when not properly regulated, they will summarily eat themselves. In the case of what we did, the regulation came in the form of loading the motor down, so nothing ever ramped to destruction. If one ever did find the real OU solution, regulation would be a must, and yes it would take a micro to handle it.
                  I would certainly love to hear more about your test experience.
                  • Correction on Design and Use of a Switched Capacitor
                    I would like to add a correction to my approach in the design of a synchronous parametric generator. The concept of charging in parallel and discharge in series is an interesting topic which can be debated in many ways, the concept I have come to see as being the most useful, is the exact opposite of the above, or charging in series and discharge in parallel. As many have pointed out, if you do the math on a switched capacitor you will see that the energy in terms of work is equal any way you do it, series/charge parallel/discharge or parallel/charge series/discharge. This fact comes from the inability to change the total value of capacitance to such a value that will be useful, i.e. if two 30uf are used, you will have 60uf in parallel and 15uf in series, both will yield equivalent "work". A rotary or spring type or even one akin to a MagAmp, if it existed, as others have described and debated, would be able to have a capacity change that would actually be useful.
                    With that said, I have come to realize the flaw in my current understanding, and would like to describe, what I believe, a useful situation a switched capacitance can provide. In a parametric oscillator, if you have an inductance that can change to two values that are not in the relationship of La=(Lb/2), it is possible to get one resonant frequency in the parametric oscillator with a switched capacitor (something not possible with a static capacitor). If for instance the switched capacitor has the values of Ca=60uf parallel/discharge, Cb=15uf series/charge (from two separate 30uf caps) and we have variable inductor values of La=0.1173h charge and Lb=0.4691h, discharge, and the oscillatory frequency of the system is 60 cycles per second, you will find that the discharge of Lb into Cb and Ca into La are of the same resonant frequency whereby the impedance of both dynamic values of L & C are matched and current into the inductor will rise exponentially as a result of the capacitors translating the excess energy of the MagAMP from a voltage E (EMF) to a current I (Displacement Current).
                    On their own, switched capacitors aren't terribly useful, but, when used in an appropriate system to match the RESONANT FREQUENCY of both storage components, you can facilitate the energy translation, here given, it can be a useful tool.
                    Garrett M
                    • Originally posted by Web000x View Post
                      You'd be after a core material with a very steep B/H curve so a mag-amp core would be the most ideal. From what I've seen they are pretty expensive though. Here is a link to one; MAGAMP - Square Loop Cores
                      Good to hear from you again Eric. I've got nothing to really add to the discussion yet, I'm busily reading Man or Matter and I highly recommend it. Electromagnetic Induction is next on my list.
                      All, I've added some more documents to my references list (http://www.energeticforum.com/renewa...xcitation.html) including Electromagnetic Induction.
                      Raui
                      Scribd account; http://www.scribd.com/raui
                      • Few questions
                        Thankyou for continuing the internet tranmissions from where you have previously left off.
                        Questions:
                        If total eletrification Q = Psi . Phi
                        Or the total eletrification Q = Total Dielectric induction, times the Total Magnetic induction.
                        The more dielectric induction (capacitance), the more Counterspace.
                        The more magnetic induction (inductance) the more Space.
                        So then of the four primary dimensions of Electrical induction Q, we have the two primary physical dimensions. One of Dielectricity (more Counterspace) and the other physical dimension of magnitism (more Space). But there is only one dimension of Space?
                        Of the other two primary metrical dimensions Space and Time, it follows then if there is space and counterspace, then is there then time and counter-time? But then there is only one dimension of time?
                        The more magnetic induction, the more Space, the more time? - (Makes sense to me, the bigger the inductance the lower the frequency).
                        The more dielectric induction, the more Counterspace, the more Countertime?
                        Thank you DE N6KPH for your electrical engineering, mustard seed planting, internet transmissions. Wonderful!
                          Hello again!
                          That is exactly why I started down the magnetic amplifier road.
                            Continuing then it has been given that the total electrification Q is the union, or product, of the total dielectric induction Psi and the total magnetic induction Phi, Psi times Phi equals Q. In other words, the dimensional relationship Q, the total electrification, is the product of the dimension of total dielectric induction Psi, and the dimension of total magnetic induction Phi.
                            DE N6KPH
                            Eric,
                            1. In Sinusoidal A/C, are the Psi and Phi always opposite in phase, 180 degrees apart.?.
                            2. Is BEMF, the expense product of Psi due to partial resonance?.
