VIDEO: Dielectric induction of flowing oil in Alaska Pipleline due to magnetosphere?
  • VIDEO: Dielectric induction of flowing oil in Alaska Pipleline due to magnetosphere?
    Ok, so this is a PRO VIDEO, I remembered seeing it.
    I copied this video clip and uploaded it
    Question would be, is the flow of oil in the alaska pipeline receiving dielectric capacitance by flowing in the earth magnetosphere, and thereby causing magnetization of the pipe itself.
    at END OF VIDEO, the expert on the Oil pipeline said it would be impossible to weld and replace worn segments of the pipe without a counter-field in place during the welding.
    Question is, is the flowing oil in the magnetosphere causing the pipe magnetization? It would seemingly HAVE TO BE the case, since such pipes of other varieties dont exhibit this.
    Fascinating.
    If this is a new pipe segment then no oil has flowed through it. To me this actually proves Leedskalnin's work with magnetism.
      ive already figured that out about the pipeline..
      Ive read Leedskalnins "book" on magnetism, its pure blathering filth and fecal matter.
      he sure could move rocks, but he didnt know jack about magnetism.
      Doesnt need oil THRU it, its still connected to the ENTIRE LINE in which the oil IS, which is dielectrically charged in capacitance. (read Dollard)
      answer from myself:
      Its has long been a mystery as to why the N-S running Alaska oil pipeline is magnetized as the vast amounts of oil running thru the steel pipe churn down the line, however the explanation is simple, the pipeline is being inducted by the movement of the dielectrically charged oil as it passes thru the vortex torrent of the earths magnetosphere, which in turn like the magnet thru the copper pipe demonstrates the Lenz law, is causing magnetic induction of the pipeline from dielectric induction of the moving oil thru the earths field vortex.
