Eric Dollard
This is a sticky topic.
  • Eric Dollard Landers Facility
    Talked to Eric today - here is an updated description on the 4 hour Lander's video technical tour...
    User this link - 70% of the sale will go to Eric Dollard & EPD Labs
    The Extraluminal Transmission Systems of Tesla and Alexanderson by Eric Dollard
    In 2007, the San Francisco Tesla Society visited me at my research facility in Landers, California. I insisted that we film a documentary covering the technology because it was about to be taken from me.
    This was to include my research into earthquake detection and the general monitoring of longitudinal, electro-static signals emanating from the earth. This video tour documents the facility and the scientific achievement it represented.
    This facility represents almost three generations of work starting with George Van Tassel at the Integretron, which is located next to this Landers Facility. The land owner Walter J. Deroche had commissioned me after the Integretron was taken from me and I needed another place to continue the work. So this began on Walter's property roughly 1000 feet from the Integretron.
    Walter's idea was to build our own Naval Communications facility based on the materials that were moved from the RCA Station in Bolinas, California to Landers. This was a dream that we had both shared. At that point, I continued the research of the Radio Corporation of America (RCA) on Walt's property.
    Ample assistance of materials were provided by Walt's friends and associates who worked in the aerospace and telecom companies in the Southern California area. And much of the equipment was hand made by me from surplus gathered in the Los Angeles area.
    Based on my knowledge that I gained from the Navy and Bell Telephone, I was able to build this equipment exactly to their specifications as can be seen in the photographs. The parts inventory that I gathered was massive. This derived from my 20 years of working in the surplus business in Los Angeles. (One part of the lifelong effort.)
    Over a course of time, one of the biggest communications research installations in private hands grew out of this effort.
    Under suspicious circumstances, Walt died but in the course of his passing had willed the installation to myself and the telephone line foreman who helped me build the place.
    Unbeknownst to me, efforts were made behind the scenes to tamper with the paperwork and the will. Eventually, the property wound up in the hands of an Olen Bales at which point a $250,000 ransom was demanded or he would destroy the station.
    When the money was not forthcoming, Owen declared me a squatter and had the legal system remove me from my own installation and the facility was looted of all of my property, possessions and equipment at which point I became destitute in Lone Pine.
    Considering that the installation was the most advanced "listening station" ever built outside of the control of the military, its loss was catastrophic and irreplaceable.
    So, what was there? This film is a complete tour of the facility with me explaining the scientific significance of each and every component filmed. This includes the "antenna farm" which held Broadband High Frequency Antennas, Broadband Low Frequency Antennas, a Marconi Antenna, a Rhombic Antenna, an Earth Signal Antenna consisting of a Beverage Antenna and an Alexanderson Antenna in tandem.
    It also had a stereo broadcast and receiving antenna for the entire high frequency band with worldwide range of reception. It allowed for the determination of the directional origin of the signals, which were heard in stereo. In effect, the Earth became a concert hall of enormous proportions. Unfortunately, before much of this could be recorded, the station was lost.
    And then there was the Lightning Indicator system which measured the voltage gradient between the local sky and the ground, and set off an alarm when lightning was about to strike nearby.
    For listening to signals in the earth, there was a series of sensitive microphones buried around the property, as well as the Alexanderson Antenna that consisted of a loaded pair of "above ground" and "below ground" lines that were compensated to eliminate speed of light propagation rate limitations. Each of these antennas is shown and explained out in the field, so you can see for yourself the physical structures used to accomplish these technologies.
    All of these antennas produced their characteristic signals, all of which were routed back to a central signal processing area after going through an initial "lightning arrestor" filter. Then, each signal could be selected for individual monitoring. Most of these signals were entering this area in the micro-volt range. These signals were then filtered to eliminate noise and interference, and then amplified back up to their original levels. Further amplification stages carefully brought the signals up to the kilovolt power levels.
    After this, the signals could be amplified to be listened to through headphones, or through loud speakers, they could be viewed on oscilloscopes, or used to activate chart recorders, or even close relays to sound alarms. They could also be piped into a telephone line to be played to anyone else who was listening. And all of these output systems were completely compensated so they did not load the initial signal from the antennas in any way.
    The entire facility was operated on battery supplies that were 100% isolated from the local utility. The signal processing was all done in the native, analog modem to preserve the fundamental character of the signals. There were no digital computers involved in the signal processing; only analog computers were used.
    Many considered the design to be beyond brilliant, and much of the facility was operational. The last section includes over 20 minutes of listening to signals from the Alexanderson Antenna while watching them on an oscilloscope.
    If you have understood the scientific significance of my presentation The Extraluminal Transmission Systems of Tesla and Alexanderson, then here is your only chance to see a fully functioning system in action with a full technical description. My book about the Wireless Giant of the Pacific tells about how this technology works, but this film shows one of these systems actually working!
    It's hard to understand how historically important this film is, because it is the only detailed record of this facility ever made. Technically, the film has some weaknesses, like during the tour of the Antenna Field, the wind came up a bit and played havoc with the microphones. Even through this, my periodic comments reveal priceless details of the structures and their operation. Over all, the film may leave you breathless once you comprehend the scope and magnitude of the facility and what it represents. What you will see is the scope and function of the Landers Facility, which at the time was the culmination of my life's work!
    • Eric Dollard & John Polakowski photos from energy conference
      Photos of Eric Dollard at the last conference: Eric Dollard 2014 | 2015 Energy Science & Technology Conference
      Photos of John Polakowski at the last conference:
      John Polakowski 2014 | 2015 Energy Science & Technology Conference
      • Eric Dollard
        Latest Eric Dollard updates: Eric Dollard Interview 2014-11-21 with Aaron Murakami | Eric P. Dollard – Official Homepage
        • John Polakowski
          John Polakowski to present more Eric Dollard technology...
          John Polakowski to present another Eric Dollard technology | 2015 Energy Science & Technology Conference
          • Hi Aaron
            It says page not found?
            http://energyscienceconference.com/2...rd-technology/
            • John Polakowski
              Hi Aaron
              WOW, I just pasted the link and it left out a 1 in the month - not sure how that happened. I edited the post - here it is: John Polakowski to present another Eric Dollard technology | 2015 Energy Science & Technology Conference
              • Now Working
                Good man, it works well
                Mike
                  Great that John is going to present again. I thought his original presentation was very good and well explained.
                  I’ve been wondering what’s going on with him, he’s been mainly QRT on the forum here since his last conference presentation? Eric in his recent interview says that John’s still working on his projects…
                  So if you’re out there John Polakowski, how about an update with what you’ve been up to lately? It would be awesome to hear from you!
                  My own TMT/CIG has again been operational of recent times, trying different coupling arrangements, configurations and further refinements. The Cosmic Ray detector is also being tested. –This after a period of hibernation due to various and complicated reasons.
                  For the CIG Mk-2 project the +1kW? this will be the next major project. I have acquired a suitable frame to mount the whole thing on / in, which will include an isolated ground-plain bench top, where the power supply and oscillator will be mounted below. There are two or three more Intercoupled Plasma Mass Spectrometers (ICPMS) which are going to be decommissioned at work soon, (they are mainly beyond repair) where their power supplies (which still work) are perfect for a high power CIG device. I’ll be hovering overhead like a turkey buzzard waiting to extract the power supply components. A suitable modulation transformer (plate) is the hard part though. But with such a scale and level of engineering, this will take a long time to complete, likely ongoing on and off for years.
                  It will be likely that I will be shifting house sometime in 2015, [so there will be some disruption and the domestic chores will be relentless]. The good part though, is that I’ll have for myself a brand new workshop facility. There is a much larger space, with some already existing equipment and 3 phase power.
                  • Spheres...
                    The Music of the Spheres:
                    http://www.mmisi.org/ir/37_01/reilly.pdf
                    The Music of the Spheres: by Jamie James
                    (I can’t find this (title) by an author going by the name of Jamison)?
                    The Music of the Spheres: Music, Science, and the Natural Order of the Universe - Jamie James - Google Books
                    Complex Plastics Inc.
                    BALLS PLASTIC BALLS FROM COMPLEX PLASTICS 1-888-PLASTIK 1-800-363-2870 SUPPLIERS OF INDUSTRIAL PLASTICS
                    • He Guys from the last video and the question of drGreen I think I got it. Eric said that the extra coil was in fact the impedance adjustment.
                      Do I understand right that the extra coil will change the impedance of the whole coil network to something that matches the tubes?
                      Still a simple impedance adjustment with a cap and a coil is not that difficult to tune but tuning an extra coil might be smarter.
                      • Twin Flat Spiral Coil Experiments
                        Transmit mode: One Spiral Tesla coil powered, the mirror image coil receives via one wire. Not shown is the output from the receiving primary tank circuit. (Show here with the receiving primary tank disconnected). More work on this is needed, with an impedance matching device for the load. Still the bulb lights however. Transmission mediums & distance experiments are currently underway.
                        CIG mode: Primary coils are in parallel, both powered. Inductance of primaries in parallel equal around 4.8uH.Tank capacitance is adjustable, (640pF – 2500pF)
                        Other coils and setups yet to be reviled, includes extra coils and a whole new set of non-flat spiral coils. Other things are in also in the works.
                        All filament bulbs in this video are 240volt, 25 watts.
                        Also holding both Telluric Outputs, without light bulbs as a load, one’s body then becomes the load. All I can say is that a kind of ‘warmth’ is felt. It feels like it sweeps through your fingers, hands, arms and body. The warmth feels somewhat on the outside or surrounding your skin, like an extension of one’s aura, might be one way to describe it. - I have not experienced any negative effects from this as yet, although I’m sure you could ‘over-do it’. (Video later).
                        Credit at the end goes to Eric Dollard and the members of the Energetic Forum who have offered me some help or advice in getting me this far.. - Humbly & sincerely, Thank you.
                        Twin Spiral Coil Experiments: Eric Dollard inspired Twin Spiral Coil Experiments - YouTube
                        More to come later...
                        Sputins.
                        • Use Print Friendly for downloading webpages ....
                          Originally posted by David G Dawson View Post
                          Solar Radiant Energy and the Electrinium Battery:
                          Solar radiant energy and the Electrinium battery - Nu Energy â„¢
                          This is also available at the Public Chest which now appears to be asking for a donation before you can download.
                          You can only go just so far and then you will meet staunch opposition and that's where you are at, at this time.
                          ....snip
                          Smokey
                          Use Print Friendly to download webpages and convert them into PDF or TXT or email it to yourself...
                          For example, the request for the above page's link after entering it's URL into the request form will generate this link...
                          PrintFriendly.com: Print web pages, create PDFs
                          Happy downloading!
                          • Union Features
                            Union Features:
                            Is Eric Dollard Tesla 2.0?
                            https://www.youtube.com/watch?v=EBSqvQwqIsk
                            Great interview
                            • Telsa 2.0 interview
                              Originally posted by Sputins View Post
                              Yep - been waiting for the right time to announce it.
                              • 2 updates for Eric Dollard
                                FREE CONFERENCE ADMISSION FOR 5 LUCKY STUDENTS
                                A Long Time Fan of our conferences, speakers, books, etc... has recently offered to gift 5 lucky young Electrical Engineering students with conference admission, hotel rooms and food for 3 days. Make sure to share this on Facebook, etc. so that everyone will be able to get in on this. We'll be posting details on how to qualify for this soon - read more: http://energyscienceconference.com/2014/12/27/free-admission-for-5-lucky-electrical-engineering-students/
                                If you're not a young EE student but want to come to the conference, make sure to register right away because 30% of the seats are already taken!
                                TESLA 2.0 INTERVIEW
                                Union Features is a professional film production team from the U.K. that goes around the world interviewing interesting people. This interview is a MUST SEE - they traveled all the way to Eric Dollard's lab to film him. It is already many months old, but the Union Features team have only just recently posted it.
                                It was actually some ANONYMOUS hacktivists in California that turned them onto Eric Dollard's work - so thank you ANONYMOUS for your support in getting the truth out!
                                Please make sure to give a THUMBS UP for this video to show Eric Dollard your support. Eric is in the hospital right now recovering from surgery so let's wish him a speedy recovery in the comments of the Youtube Video!
                                Aether Farce members are trolling that site since Eric speaks the truth in the interview about Ray Savant "Techzombie" "Mohamed Youssef". He is posting under different user names, one of his addictions - all the youtube accounts that are mysteriously 1 day old, Looks like it is time for more exposes to come out on this troublemaker.
