The Electrical Experimenter
Wish to express my gratitude in having a resource as this Forum which, to me, represents Layne Meade's BSRF (Borderlands Science Research Foundation) which in reality, no longer exists apart from the dissemination of stored data, ongoing slowly but surely.
Will be getting back to the CSI/CRI, CRD, RMR and TTPG shortly.
(Crystal Set/Radio Incentive, Cosmic Ray Detector, Regenerative Magnifying Receiver and Tesla Transformer Pulse Generator)
Uploaded with ImageShack.us
Hendershot Generator:
Have finished the construction including the home-made capacitors (7800pF) which work well and are able to be tuned and currently working on his 'Resonator' using bell-ringer coils and iron bar/magnet as this is the unknown (mine - at least) and investigating optional means of generating the 'buzz'.
However, can see this as an ongoing project that does not, at this stage, show promise and will be putting aside as one that we can get back to as we develop new ideas and incentives.
Eric is probably correct in these types of projects as deviations away from the real focus but have learnt a great deal as is usual with any challenge and the time was not wasted while your end was sorting itself out.
Two phenomena were experienced with this device as follows:
1. 11,000 volts AC detected in a loose connection where a spark/arc/plasma event occurred and this was an option attempt at the 'resonator' using a 4 volt split-reed multivibrator.
See what can happen in a 'Disruptive Discharge' or 'Impulse Discharge' event?
2. Ferro Resonance or NMR (Nuclear Magnetic Resonance) achieved at the bellringer coils with iron bar across their faces where some 220 volts AC was developed through two identical opposed bifilar coils placed over the bell ringer types.
See bottom left corner.
This is a Meyer-Mace type event and worthy of further study and was actually my very first OU attempt some 7 years ago.
Michel Meyer -- isotope transmutation electric generator
Aaron, Eric,
Many thanks for the latest video as you express reality there in a different manner and was able to extract much information and particularly with respect to the CSI/CRI, CRD and RMR Tube devices which we have built waiting operation.
Scalar now makes more sense and is the 'there' thing and not the 'here' thing if that makes any sense.
Understand more now on the Tube projects and will be getting those powered up.
Eric's effort in this direction was most appreciated and will not be lost.
John Polakowski,
Cudos to you John for your excellent devotion and focus to a project and succeeding with the CIG.
Waiting now to see results of this device in operation - again.
Eric was talking about a HF receiver he would like and would guess that this would need to get down to 1860 hertz for the Telluric experiments.
The HF one I have here is a Transceiver Yaesu FT-901D and this gets down to 1600hertz and the reason why I purchased as most start at 3mhz.
However, this is 50/50 modular solid state and Tubes (2 x 6146B) but is a beautiful machine.
Full Tube machines here are hard to come by.
GLOM:
Picked up a 1350 hertz Philamon Tuning Fork and several Delay Lines (DL) (4 by Admiral and 2 by AD-YU, 12 position with fine tune) which nobody else wanted and these are a lesson in pulse design but not able to glean much information from the NET on the DLs and would like to know their construction.
If anybody here can assist in schematic recognition it would be greatly appreciated.
Have also secured a NOS 12 volt split-reed multivibrator (OAK/MSP AV5948R) for the PP-18/AR and now have all the bits to build but later on that one.
Top: Multivibrator (MV) 6v Non-Synch, MV 4v Split-Reed which gave the 11kV spark, MV 12v Split-Reed for PP-18/AR, MV 32v Van Ruytken 50 hertz'.
Bottom: Hendershot Cavity Resonator with magnet, brass with coping saw blade attached (soldered) as the 'resonator', old power drill laminated body with a 24awg full coil inside and two magnets with South in.
This from his Patent Application and more a proof of concept device.
Crystal Set that was a disappointment as Eric's and my twin 1N34 probe does a much better job without coils nor variable capacitors and is good for both TEM and LMD.
Was looking for a 'front end' for Moray and a new one at the bench.
If a Magnet is a Force device and contains no energy then it may be able to be used as a detector as shown in the experiment above.
This was an attempt at another resonator but any oscillation eventually died down.
If an outside and unseen Force is at work then this with a light line of UV detectors could be used to chart any phenomena.
Is this another candidate for detecting Earthquakes or Cosmic events and will probably be an easy sensor build that can be charted on a Computer?
Beauty of this simple device is that one moving small magnet has influence over the others and reminds me of the Chinese 'Zhang Heng Seismograph' which could detect an Earthquake before the event and also show from which direction it would come from.
The use of moral mechanisms for prevention of cataclysmic earthquakes (in English)
Those of you here still Posting and working at the bench, your efforts have not been ignored and most appreciated.
All the best with your experiments.
Smokey
Aaron, Eric,
John Polakowski,
GLOM:
Smokey
