Originally posted by dR-Green
Eric Dollard
This is a sticky topic.
If you take the below high frequencies from Rife and multiply them by 2 you get around the 3,2MHz. From what I read the 3,2 also resonates in the virus that resonates on 1,6 killing it.
Influenza (1918) - 1,674,000
Bacillus X and Y (Cancer) - 1,604,000
Would it be a coincidence that my flu is healed in one day I wonder what others are experiencing with their coils? It is really beyond any reason the way I got cured from the flu. Never had that my whole life.
When you look at these harmonics almost every virus resonates at 3,2MHz.
Dr. Rife's True Original Frequencies
You underestimate their ignorance! They didn't think I had a wire up my sleeve, they thought my woollen sleeve was the conductor! The camera perspective made it look (to them) like I was touching one terminal with the bulb, and my sleeve was touching the other terminal so that was the obvious conductive path. Even though both terminals were in the same bucket of soil and there were no wires leading to the second terminal.
Yeah when I was using HV and holding the insulation on a big clip the whole thing would light up purple under the insulation, potentially more dangerous than just holding the metal. What you describe as conducting through the insulation I think is capacitive coupling to your body, because the bulb will also light at lower voltages without any of the arcing. If you use a metal plate (experiment with size) then you should be able to vary the brightness depending on the distance of your hand from the plate.
If you modulate your carrier signal input then it should work just the same as it does now but with some intelligence. Then it's just a matter of tweaking it to make the signal clean which might not necessarily be optimised for lighting bulbs, but it can be fun and distracting to overdrive it to try and get bulbs up to full brightness!
Is it necessary to measure the wire? If you wind it on the frame then it should end up at the correct length anyway. Either way, I had the same dilemma of wanting to measure some wire so that's what the frame that's currently under my transmitter in the pictures was for. It was designed to have a circumference of 1 metre so 1 turn = 1 metre of wire. With a handle to turn it and a frame to hold it a mechanical counter can then be added to count the number of turns which corresponds directly to the wire length.
Fischer Diathermy
Tesla-Bcn,
Having read your questions fully and note that this is early 1920s and before Vacuum Tubes (VT) were used, your questions are most difficult to answer.
Much deeper research is required and this may help:
The Turn Of The Century Electrotherapy Museum Tesla Library
Could not find the video unit there and admit that my interest was in the use of VTs.
You would really need to have a unit to copy as the engineering is superb and is simply not available today.
The only thing I can suggest is to wade through the blueprints in the URL above and pull out what you require.
Most impressed with the coils and capacitors as that is where we are at with the Tesla Magnifying Transmitter.
Have been trying to buy a unit here but competition is fierce and postage/freight always a problem.
People are after the simple technology that works - try doing solidstate with any of this!
If I come up with anything new, will pass on,
Sorry I can't help further.
Smokey
..........Originally posted by GoetheAll things into one are woven, each in each doth act and dwell
As cosmic forces, rising, falling, charging up this golden bell,
With heaven-scented undulations, piercing Earth from power Sublime.
Harmonious all and all resounding, fill they universe and time!
Amidst life's tides in raging motion, I ebb and flood - waft to and fro!
Birth and grave, eternal ocean, ever-moving, transient flow.
A changing, vibrant animation, the very stuff of life is mine,
Thus at the loom of time I sit and weave this living cloth divine.
From a video titled "Rife Technology - A New Hope" that was once available on google videos but is no more:
Rife's High Frequencies
The following frequencies were found by Dr. Rife and used in his high frequency instruments. They were recorded on his lab notes. Some of these frequencies were used in Dr. Milbank Johnson's 1934 Cancer and Tuberculosis clinic. Many of these frequencies were only made public in the last few years.
The only frequencies shown in this video were Rife's true high frequency M.O.R.s.
All frequencies are listed in cycles per second.
Actinomycosis (Streptothrix) - 192,000 - 678,000 - 186,554
Anthrax - 139,000 - 900,000 - 272,539
Anthrax Symptomatic - 400,000 - 16,655
B. Coli (Rod form) - 417,000 - 683,000 - 317,914
B. Coli (Filterable virus) - 770,000 - 8,581,000 - 11,103,424
Bacillus X and Y (Cancer) - 1,604,000 - 11,780,000 - 17,033,662
Bubonic Plague - 160,000 - 512,466
Catarrh - 1,800,000 - 1,713,100
Cholera Spirillum - 851,000 - 960,873
Contagious Conjunctivitis - 1,206,000 - 2,025,625
Diptheria - 800,000 - 1,090,154
Glanders - 986,000 - 736,591
Gonorrhea - 233,000 - 600,000 - 150,649
Influenza (1918) - 1,674,000 - 1,946,704
Leprosy - 743,000 - 251,926
Pneumonia - 1,200,000 - 381,901
Spinal Meningitis - 427,000 - 927,800 - 1,795,164
Staphylococcus Pyogenes Aureus - 478,000 - 998,740 - 555,171
Staphylococcus Pyogenes Albus - 549,070 - 549,070
Streptococcus Pyogenes - 720,000 - 1,214,000 - 2,111,214
Syphilis - 789,000 - 900,000 - 2,775,856
Tentanus - 234,000 - 700,000 0 15,779
Tuberculosis (Rod form) - 369,000 - 583,000 - 541,142
Tuberculosis (Virus) - 770,000 - 8,518,000 - 11,103,424
Typhoid Fever (Rod form) - 760,000 - 900,000 - 868,964
Typhoid Fever (Filter passing) - 1,445,000 - 9,680,000 - 13,943,835
Hoyland's Audio Frequencies
The following audio frequencies were found by Philip Hoyland and used in the instrument he built for Dr. Rife. Rife didn't know the instrument was not using his high frequencies until the 1939 Beam Ray Corporation trial. These frequencies worked in Hoyland's instrument because of the unique way he built it. Hoyland's instrument worked on harmonics and produced Rife's high frequencies through harmonics. Dr. Rife did not like harmonics and did not approve of Hoyland's design.
Hoyland's frequencies have been mistaken for Rife's frequencies. Though the doctors who used Hoyland's instruments reported very good results, the instruments would drift and not stay on frequency and many were returned. Hoyland's instruments did not work as well as Rife's high frequency instruments.
Actinomycosis (Streptothrix) - 7,870
B. Coli (Rod form) - 8,020
B. Coli (Filterable virus) - 17,220
Bacillus X (Cancer - carcinoma) - 21,275
Bacillus Y (Cancer - sarcoma) - 20,080
Pneumonia - 7,660
Staphylococcus Pyogenes Aureus - 7,270
Streptococcus Pyogenes - 8,450
Syphilis - 6,600
Tentanus - 1,200
Tuberculosis (Rod form) - 8,300
Tuberculosis (Virus) - 16,000
Typhoid Fever (Rod form) - 6,900
Typhoid Fever (Filter passing) - 18,620
Worms - 2,400
Rife, Crane and Marsh 1950's Audio Frequencies
The following audio frequencies were derived by dividing Hoyland's audio frequencies by a factor of ten.
In the 1950's, Rife, Crane and Marsh became business partners. Rife had no schematics for his high frequency instruments. Hoyland built them but never gave a copy of the schematics to Rife. Rife did have an old Hoyland instrument. Rife, Crane and Marsh decided to re-design Hoyland's instrument and see how well it would work. They removed Hoyland's unique design of harmonics and gating. This made it so the instrument didn't produce any beneficial results. Instead of putting back Hoyland's method of producing harmonics they changed the sine wave audio frequencies to square wave to get harmonics. Then they lowered the audio frequencies by about 10 times.
The doctors who used these 1950's instruments began to get very good results but after several years of testing they proved not to work as well as Hoyland's instrument. The changes to Hoyland's instrument were not good changes. Apparently Rife, Crane and Marsh never really understood how Hoyland's instrument worked. For years people have mistakenly believed these lowered audio frequencies were Dr. Rife's true M.O.R frequencies. Because of this confusion almost everything manufactured today is based on Hoyland's low audio frequencies and not Dr. Rife's high frequencies which achieved the results of Dr. Johnson's 1934 clinic.
Actinomycosis (Streptothrix) - 784
B. Coli (Rod form) - 800
B. Coli (Filterable virus) - 1552
Bacillus X (Cancer - carcinoma) - 2128
Bacillus Y (Cancer - sarcoma) - 2008
Gonorrhea - 712
Pneumonia - 776
Staphylococcus Pyogenes Aureus - 727
Streptococcus Pyogenes - 880
Syphilis - 660
Tentanus - 120
Tuberculosis (Rod form) - 803
Tuberculosis (Virus) - 1552
Typhoid Fever (Rod form) - 712
Typhoid Fever (Filter passing) - 1862Last edited by dR-Green; 02-16-2014, 08:59 PM.
By the way Rife used 3,2MHz and harmonics for his cancer therapy? I'm still reading this. Rife ended up using tubes with electrostatic fields at certain frequencies. Light did not work. In fact he was using Tesla technology.
Tesla:
Thus, everything that exists, organic or inorganic, animated or inert, is susceptible to stimulus from the outside. There is no gap between, no break of continuity, no special and distinguishing vital agent. The same law governs all matter, all the universe is alive. The momentous question of Spencer, "What is it that causes inorganic matter to run into organic forms!" has been answered. It is the sun's heat and light. Wherever they are there is life. Only in the boundless wastes of interstellar space, in the eternal darkness and cold, is animation suspended, and, possibly, at the temperature of absolute zero all matter may die.
Close to 3,1 MHz but I'm feeding it square waves now so probable there are harmonics too. I had a good feeling with this coil because Lakhovsky used 30cm rings around plants and my topring is something like 25cm. I guess that if I'm generating frequencies they are close to the frequencies that Lakhovsky found out to originate from the sun. So I guess we should aim at this 30cm end ring and build the rest from there? We are of cause being from the sun. Tesla wrote everything is filled with living aether but the sun wakes the aether into biological live.Originally posted by James Barker View Postorgonaut, what frequency were you using?
Congratulations!
Unbelievable! Congratulations to all the campaign donors and organisers! It brings a happy tear to ones eyes..Originally posted by James Barker View PostPlus, congratulations to Eric Dollard & his team for hitting the $25,000 goal on the crowdfunding effort!
Sputins.
One small scientific result with my secondary Tesla coil. I had the flue this week it was very serious. Normally it would take me two weeks at least to recover. Well this time in front of the longitudional oscillating Tesla/Dollard coil I needed one day! Part of the day I was asleep, a few hours in front of the coil where enough. The next day I was feeling well again and I didn't needed tissues anymore. I needed a lot of them during the day. Now I'm still recovering but I call this a scientific proof that this coil in the right oscillating mode is killing viruses pretty damn sure
Side note. We do not use pulses and not even high voltages. The electrostatic mode is also clearly not screened through the water in my body. This coil is making aether waves that penetrate me like solar aether. The viruses can't stand these frequencies that why they parasite on me to get energy. My body gets stronger with these frequencies.
Hi Tesla_Bcn, I had nothing to do with that so I can't answer your questions I'm afraid, hopefully Smokey can help you out, or maybe Spokane1 if he's around.Originally posted by Tesla_Bcn View PostDear Aaron, Dr-Green and specially T-Rex.
In Spain we are planning to replicate Eric's famous vintage experiment, that was replicated in the Summer 2013 Conference. Our main goal is to achieve a source of truly Longitudinal Electricity.
Our first step should be to replicate the Fischer Diathermy Machine (we can not afford to buy one), but in the schema that we see in this linkThe guy in the video said 2,5Kv
Hello tgraca,
"My favorite living rooms until now have had pool tables in them... I am now convinced that coils in my living room is the way to go! Thanks for posting!"
Thankyou for posting that back up.
Actually this is the Granny Flat where My Wife's Parents resided before passing on.
I now have control of the area (I built it) and this is the first annexe (full of Vacuum Tubes) and the verandah is the second.
The main room, the bedroom, is chokkers full of similar equipment including all the GLOM and a sight to behold and contains the actual workshop.
Have been absent here on rainmaking duties and will be back soon with pics of the new devices - these are both 'BIG GUNS' after Reich and Foley and are better representative of my challenge with rainmaking in that I am not mobile and my earlier devices needed mobility (possibly) to be active during severe conditions as we are now facing.
I would never encourage anybody that is married to take over the lounge room for experiments like these, unless, of course!
Actually, Mum just offered me the Lounge Room in the BIG house which we don't really use but I graciously declined.
Tesla Bcn,
Don't think you will get a reply from Eric but will help best I can as I am also into Diathermy, research at least.
Give me time to catch up with your questions and will respond shortly.
Recording the video now and have a similar setup in my files - excellent video.
See the violet blue - that's cold Female.
Good stuff!
Smokey
