Eric Dollard
This is a sticky topic.
another way of looking at things
1)The lab was left in the hands of E.D. to continue or not, but the generous benefactors who set it all up have walked away after getting no cooperation, so Eric has to do the fund raising, but apparently that is too much work...Originally posted by David G Dawson View PostHello Adam,
So the promised Lab is no more and believe it terminates at the end of the year.
=======edit
Thankyou for the plug with respect the CRD as that is ongoing and I only stopped because of all the interference happening and had no idea of where that was taking us all plus I was short of HV caps for the Tests.
========edit
Mention of the 'Tesla Cosmic Rays' and '50 times the speed of light' certainly adds flavour to the CRD project and will continue here to a conclusion and will assist others that may follow.
=========edit
I/we appreciate the work that Eric has put into these projects but it is the outside interference that mars the entire organisation and nobody feels secure and are hurting for Eric's salvation.
I repeat - how do we help?
Smokey
Have you noticed the lack of appeals to continue the lab?
2)I wasn't sure what he was trying to prove with the CRD, either.
3) Tesla himself never claimed FTL.
4)There was no "organization" until Eric's benefactors created one. Now that it has been left up to Eric, there will no longer be an "organization" as before.
Eric is not an "organization" kind of guy. He wants to be left alone in his beloved "bush country" to research, dream and pontificate.
5)How can you help? Send Eric money, lots of it, he likes that. However, don't ask what he's doing with it, just send more.
Don't get me wrong. I really appreciate Eric's historic research talks, I think that is his strength. He should stay with that instead of pretending that he wants a lab venture that he does not want to do.
Let's face it, he hasn't built anything new in 20 years!
An investigation into the series bulbs phenomena
After further experimentation I believe I have discovered the reason why bulbs in series don't act as "normal", and what's more they can behave as if they are connected in parallel.
The observable effect is that by adding more bulbs in series, they don't get progressively dimmer through the normal voltage drop in the series as one might expect, but rather the entire set increases or decreases in brightness EQUALLY along the whole line.
Also if two bulbs are in series as an example, the one nearest to earth is inclined to be brighter than the one nearest to the power source, which is the opposite effect to how bulbs are "supposed" to behave when connected in series.
However, the voltage measured across each bulb in the series appears to be approximately correct according to what it "should" be, that is, there is a measured voltage drop, but this doesn't seem to mean much/anything at all to the bulbs.
The cause of this appears to be the capacitance on the other terminal of the bulb, or in other words the capacitance that's AFTER the filament. The bulb closest to earth has a direct path to this capacitance, whereas the first bulb in the series has the next bulb as a resistance, and as such doesn't have a direct path to the capacitance, and is consequently dimmer. The brightness of each bulb in the series can be independently controlled through adjusting the capacitance that's after the filament of any one bulb in question.
2x 28V bulbs in series. The one on the right is closest to earth, the one on the left closest to the secondary coil output
2x 28V bulbs in series as above, my finger making contact between the two bulbs
8x grain of wheat/grain of rice bulbs in series before 2x 28V bulbs. The last but one bulb in the series of 8 small bulbs is dimly lit. This bulb has the capacitance of the metal in the terminal block on the "output" side of the filament, whereas the last bulb in the series of 8 does not. The bulb on the lower left is the last in the whole series
Same configuration as above, my finger making contact between the two 28V bulbs. The increase in capacitance that's BEFORE the final bulb in the series now causes more of the small bulbs to light up
8x grain of wheat/grain of rice bulbs with 1x 28V bulb in series. The 28V bulb is the last in the series
8x grain of wheat/grain of rice bulbs in series. No apparent dimming towards the end of the series
8 bulbs as above
4x grain of wheat/grain of rice bulbs in series. No apparent dimming towards the end of the series again
4 bulbs as above
helping Eric and Glom
There will be another campaign specifically for the lab to generate as much as we can to save the building.Originally posted by David G Dawson View PostHow do we help?
Is Mark McKay a holding area for Eric's GLOM?
Mark McKay's warehouses right now are only holding glom that he was going to give Eric personally.Sincerely,
Misinformation
That is nothing but pure misinformation. Whether intentional or simply because you are obviously unaware of the facts is unknown by me, but it is pure misinformation nonetheless.Originally posted by cyborg View Post1)The lab was left in the hands of E.D. to continue or not, but the generous benefactors who set it all up have walked away after getting no cooperation, so Eric has to do the fund raising, but apparently that is too much work...
1. Several people involved already had plans to boot Eric out of his own organization - this is a documented fact by someone that was a party to the conversations so the lab wasn't "left in the hands of" Eric. Wittekind even admits that was said but claims there was a misunderstanding in communication about it. Hmmm. Two of the trouble makers are gone and Wittekind will resign in January - was Wittekind really a trouble maker behind the scenes? I'd like to know. There are two other people that are on the board that have been there all along that almost nobody mentions. One is the Secretary now and one is the Director. Not getting cooperation? What was Eric supposed to build? After they sunk most of the money into the building, which increased the equity of EPD Laboratories, Inc. $0.00 since that equity is owned by the landlord, there were some parts, etc. but the building isn't even properly wired from the power line pole. In in almost every interview with Eric over the last several months, he has mentioned needing money to continue his work at the lab quite a few times. In EVERY promotion of Eric's books/videos it is very clear that proceeds are going to the non-profit to help pay for parts, operating expenses, etc. Mysteriously, you leave out the facts and make up your own.
2. Irrelevant.
3. It is self evident from the results of his work.
4. FALSE. It was Justin Miller "the cowboy" who had the idea to create an organization to develop the work that he and Eric were involved in and Eric has known him for years. Eric's organization was always him and his associates that actually did the real work. This was way before any "helpers" showed up and put the organization on paper. Yes, the organization is a valuable tool for Eric's work - there is no denying that. The organization isn't left up to Eric as you falsely claim. There are a team of people he is working with and two are official board members besides Wittekind. The organization is VERY important to Eric and is more important to him than the building - this is irrefutable. You don't know what he wants so please don't spread this ignorance here.
5. Pure condescending BS. Even in Eric's latest interview he was very clear that the recent money was put into making a successful CIG with John Polakowski, etc. You sound like a representative of the dark side. Eric is the most outspoken person out of them all that wants transparency on where the money went so people know it went to a good cause.
Don't have to get you wrong at all. I think it is fairly impossible for anyone with common sense to not be able to clearly see that you are completely full of BS willfully or just out of ignorance. Those are the only two obvious possibilities and it is disrespectful to someone that contributes more in one paper to this field that you probably have in your entire life combined. In other words, you have no room to talk.
You have no idea about the multiple TANGIBLE projects he is working on and you have just guaranteed that it will most likely stay that way for YOU.Sincerely,
Cyborg = either Jimm or Kokomojo. He made this clear in his first post under the new alias to Smokey, I just can't be bothered to go back through the pages to find out which one of them it is. Assuming Jimm = not Kokomojo.
I'm still waiting for a solid state circuit design from him, I wasn't being sarcastic when I asked because I have uses for it. But he doesn't want to talk to me
Instead he seems to be promoting a discouragement campaign in an effort to get people not to bother doing anything. But he's only wasting his own time with all that nonsense. Those who would believe it would be useless anyway, he's inadvertently doing the job of weeding them out. Nature's way.
"Cyborg"Originally posted by dR-Green View PostCyborg ... seems to be promoting a discouragement campaign in an effort to get people not to bother doing anything.
"Techzombie"
Didn't Eric say something about computers being bad for you? I'm sensing a trend here. Watch out for people who identify too closely with technology, perhaps. "worshipers at the altar of the destruction of energy"...?
Thank you very much for this insightful post. Much appreciated. I am trying to learn all of this material and read it with attention...how ever I stumble when there are abbreviations like A.T.T or similar...
Is it possible to post a legend with all such abbreviations. I know many of the readers have been following your posts from day one and probably know the meaning of all the abrivations.
Unfortunately I am new to your work. I would really appreciate it. Thanks again for your contribution.
Doc,Originally posted by dR-Green View PostCyborg = either Jimm or Kokomojo. He made this clear in his first post under the new alias to Smokey, I just can't be bothered to go back through the pages to find out which one of them it is. Assuming Jimm = not Kokomojo.
Don't know where you get the "discouragement campaign" from. I am just questioning why all the focus on *very* old tube tech. I'm surprised that you aren't trying to use the "double and triple digit" tubes from the 20's. Those are even closer to the "founders'" time.
I posted a little bit of info about the solid state stuff on the other forum, but found that there was very little interest in it. I answered the one question that I got.
Unlike some people, I do not claim to have "special secrets" that I may or may not share with the world,etc, just some modern era engineering using modern components which anyone can apply and it will work. If you think about it, tubes are also 'modern technology" when applied to TCs, so why not leap ahead another 60 years and use parts that are readily available?
So, Doc, what do you need to know? You never asked before...
I think the CRD initiative was an attempt to include what Eric calls "NGs" because he thinks he has to dumb things down to the extreme or even the absurd.
I am truly interested if the "instantaneous transmission" is possible. Note that instantaneous is different than FTL which is a velocity.
Tesla coils are not FTL, and Tesla never claimed that they were.
Logic and physics tells us that when light, electrons, rockets and meteorites will slow down when moving in anything but a straight line in a vaccuum . Electrons do not go faster in a coil!! Period!
I'm saying that some of the concepts espoused here have gone off the rails.
Sometimes this forum seems more about a cult of personality than any real scientific pursuit. Please! Prove me wrong!
Things to Add about Faster than Light & CRD
Evidently as it has been covered by Eric before many times in many different publications and presentations that Wheatstone himself invented an apparatus that involved a 4 mile long transmission line segmented so that a spark might pass between it's centre, and an accurate timing mechanism might trigger at point A start of the transmission line segment, simultaneously to a second identical timing mechanism at point B at the middle of the transmission line segment. Upon spark gap electrostatic discharge leaving point B and arcing to point C in the transmission line to traverse the other 2 miles an average velocity is obtainable in the simple high school equation velocity = distance / time. The velocity wheatstone found it to be with pi / 2 times greater than light, or approximately 1.57 or 157% greater than light.
Further, the point of a Cosmic Ray Detector as I have conceived the meaning of it's implement to be is to directly engage in the recreation of the apparatus of Nikola Tesla for firstly detecting what was referred to as a faster than light Cosmic Ray, such as the one detected by Tesla from Antarus at 50 times the speed of light by his apparatus. The apparatus that Eric Dollard has shared appears to be a full schematic for the device. What David Dawson has put together appears to be a functional CRD. So therefore with the addition of a second CRD and and with the considerations of identifying and tuning and individual Cosmic Ray source to each electrical apparatus, the same identical segmentation, differential and therefore distance and time of detection can be known, and provide a velocity. This would therefore prove once and for all if there was a faster than light possibility in the conception of the CRD. But then comes the inventive and inductive proofs of what the CRD is really detecting and other interference factors, and of course the ability to individualise or tune the Cosmic Ray Detector to the particular cosmic entity one wishes to observe.
I believe with two of the devices that david has one working already, that it may be able to obtain this theoretical velocity and thus forward the onward expansion of the discussion on travelling electrical waves as Eric puts it that 'dont have a velocity'. For many this may be familiar to the audacious and explosive claims that tesla made when he said he could transmit power and communications "regardless of distance". Regardless implying precisely the very same claim as illustrated and described by Eric. In my opinion I believe we are merely following the research of Nikola Tesla and at least attempting to create apparatus that show the transverse electromagnetic wave, or the ohmic or kircchoffian value of the faraday equation is NOT the whole story to the transformers electrical activity. For instance in power lines and large transformers of sufficient density and size considerations about the earth. I believe that the earth is inextricably connected with the transformer that I have worked with. Many of the things we cannot see about electricity could be revealed by this counterspace discharge, as it is now seen potentially arriving at a terminal BEFORE the switch has been closed, repeat arriving at terminal BEFORE the switch is closed, and it is a seriously interesting situation worthy of research. What we are now discussing is the possibility or at least concept of one being able to potentially turn a switch on which causes a boxing glove to punch you before you have switched the device. Enter the paradox. And so, the importance of following this road seems clear. It is only explained by "einsteins paradox", and here and now is the very real opportunity of detecting electrical waves travelling in forward and backwards time converging to create the friend we call the electromagnetic field. Is it not the enemy? Is not the real goal to separate the divided particles into their most primary form? Has this been done and is this understood? These are all important questions in my opinion that relate to this research and asking the question of "FTL" as it has been put.
Tesla suggests that the density of matter, and a wire plays a part in the brightness of a bulb, and the decay of dense or unstable radioactive matter. Such as radium. Tesla even suggests that radioactivity isn't caused by mass, but could be caused by an external source. Which in other words completely contradicts everything we know about nuclear physics today, the dense matter is supposed to decay on it's own, and it is supposed to be unstable because of it's atomic arrangement as determined by the theory of periodicity of elements. In the case that radioactivity could have an external cause as tesla suggests with radium "If completely shielded from cosmic rays ceases to be radioactive altogether" the very foundation of electrical and atomic sciences becomes to fall apart, as, many of them rely on a fixed form. But now considerations of the planet and the transformers on the planet must be considered, as well as planetary activity. Or in other words - an external force responsible for radio interference, which implies power, and even suggests the possibility that the motive electron has an external cause. For instance a chemical battery ceases to operate if it is cooled to much, for instance if the sun was absent no chemical batteries would work in my calculations and estimations. I think it is proof enough that motive transport, and the motion of the electrons responsible in the chemical periodic elements for chemical reactions could be based by an external cause in the same way as radium. And so that is another extremely important reason to pursue the CRD. As it will allow further research into nuclear physics to probe the claim that was indeed made by tesla many times, of faster than light and externally caused atomic and radioactive activity, determined by density. The highlight here in my opinion is that the sun, or our local star is a great influence on the valent activity of metals, and so already establishes what is well known as the "open system". IS this not just a reluctant way of saying that the state and activity, in atoms electrically is determined by an external thing? In the case of space weather and earth weather, it is all caused externally.
The Niagara falls keeps turning round and round, and the scientists and physicists tell you it is the force of water and gravity turning that turbine. When evidently and truthfully if you were to eradicate our sun altogether and remove it but for a day or two, the water would rapidly freeze on this earth, and the evaporation of our ocean and rivers into clouds would cease, and therefore there would be no rainfall anymore in the mountains to condense and fall by gravity to form a river down hill to then drive the turbine. As we can see the specific and inventive scientists can explain the force which drives the turbine admirably, but it is describing those secondary and tertiary things and it is ignoring the primary wireless force. So to say something like Niagara falls is caused by gravity is a hilarious thing, because if that was so all you would need to do is remove the sun, and then you would see there was no water for the gravity to take down the hill. We therefore must assume that the external influence of the sun and the ability for the changing atomic density represents the best and most interesting study of the formation of electricity in a generator. We can look at the electron or the unstable matter of radium, but if we are not properly identifying the primary force , the primary wireless force responsible for the secondary manifestations we see, then we are really continuing to believe a science based on mass, when it seems that mass is consisting of some unknown wave or dimensional attributes which are not mass, but converge in some way to form it. And the CRD, and CIG I believe are at the centre of that controversy and so represent in my opinion the best and most satisfying way to engage in this experimentation.
I have performed few experiments myself and am not trained in the same manner as many other people but as may be noted am not without my own opinions and researches, nonetheless, i defer to the more experienced people. I merely came to respond to the inquiry of faster than light waves and the reasoning as to the importance and meaning of producing a CRD apparatus,
Best Wishes,
ALast edited by 7redorbs; 12-06-2013, 05:58 PM.
perception
It's funny how two people can witness an event and describe it differently.Originally posted by Aaron View PostThat is nothing but pure misinformation. Whether intentional or simply because you are obviously unaware of the facts is unknown by me, but it is pure misinformation nonetheless.
2. Irrelevant.
Ok you have actual "face time" but I have some non public background info as well.
All I can say is that I was appalled when I saw that video of Eric ranting and raving about a very minor thing, verbally abusing everyone who were only there to help. THERE IS NO EXCUSE FOR THIS BEHAVIOR.
Are you trying to say that it didn't happen?
This was insight into why he "lost" all of those labs.
Eric is an interesting guy, but he has to learn how to play well with others if he is ever to have an "organization" going forward.
That being said, does he intend to continue the lab? He was left with that option...
misinformation and deception
Am I saying that Eric didn't go off on someone? This is snake talk. You are attempting to manipulate anyone reading this by trying to distract the attention to something that has absolutely nothing to do with your previous false claims or the facts I pointed out that debunked your claims.Originally posted by cyborg View PostAll I can say is that I was appalled when I saw that video of Eric ranting and raving about a very minor thing, verbally abusing everyone who were only there to help. THERE IS NO EXCUSE FOR THIS BEHAVIOR.
THERE IS NO EXCUSE FOR THIS BEHAVIOR it is completely disingenuous an inauthentic.
Eric going off on someone has nothing to do with your false claims that the lab was left to him to continue by himself because of his lack of cooperation, which is completely false. You are ignoring the facts of his multiple statements about needing funds to continue the work at the lab in his interviews, etc. When your false claims are clearly debunked based on facts, you don't concede to the reality of this, you attempt to direct the attention to something else of irrelevance that takes focus off the fact that you have been exposed as someone that is spreading misinformation.
Play well with others? I have been around Eric personally in multiple situations and meetings with his other associates that are involved with the non-profit and haven't witnessed any of that with these other people who have been around him for a LONG TIME - YEARS. This was insight into why he had a different relationship with some of the others that were there to "help". Hmmmm - geee I wonder why that is?
Here is another fact - those that claim to be wanting to help Eric ALREADY knew how he was - a feral human - the one that got away. It's common sense by looking at all his posts for the last 3 years here and his NFG's. Anyone that claims they didn't know is a liar.
If you go out to the desert and bring a coyote into your home and you get bit, you blame YOURSELF! It's common sense. Whether you find it unacceptable or not is irrelevant and it doesn't change the fact that those that were trying to "help" Eric were also imposing their will on him and trying to manage him instead of leaving him alone to do what he wants. They wanted him to do what they wanted instead of supporting Eric to do the work Eric wants to do. That is what was promised to Eric by the "benefactors" that he would have a place to do his thing, but in reality, it was so they could get him to do their thing.
Does he intend to continue the lab?
Thank you - you have proven clearly that you are absolutely here to misinform and deceive people because of nefarious intents or because you simply are incapable of comprehending really simple English.
Please keep your lies out of this thread and out of this forum, your deceptions are not welcome. If you can't acknowledge what was ALREADY said like a decent human being, then don't post anymore.Sincerely,
the reason I avoid the use of solid state is to keep a pure and clean plasma source as possible, I'm doing research work with plasma so naturally that's the draw.Originally posted by cyborg View PostDoc,
your right that the electrons don't travel faster in the coil, the limit is within our 3 dimensional universe. electrons are not particles or 'things' it's an energy probability collapse from what I'll call counter space. now if a coil arrangement can induce a potential field that is independent of the magnetic field then it can be observed in our reference frame to have exceeded the velocity of light.
Why are solid state drivers undesirable for plasma?Originally posted by madhatter View Postthe reason I avoid the use of solid state is to keep a pure and clean plasma source as possible, I'm doing research work with plasma so naturally that's the draw.
Are you referring to possible damage due to sudden impedance changes?
