Crystal Set Initiative & Hendershot Generator
dR-Green,
Crystal Set Initiative:
Occurred to me to test all of my Extra Coils for Inductance after reading your material and results as follows:
Coil #1 56 turn 14 awg (Accidental and best)
379.5 uH
Coil #2 124 turn 21 awg (Erics and doesn't work)
1.997 mH
Coil #3 56 turn 11 awg test - not as good as #1
321.6 uH
Coil #4 53 turn 20 awg test - OK
380.8 uH
All the coils are tapped at the 50 turn point as being the best excepting Eric's which I still see as being of the incorrect length.
Notice where I am working compared to Erics.
My frequency is 1557 Khz and calculates out with a 30 pF capacitor.
Have added the other 2" silver round plates of the neutralising capacitor receiver setup and find an increase in signal results.
It has occurred to me that you could have a million receptors around this coil and if all fed into one you would most probably have a considerable gain that would be capable of powering something.
Not bad for a passive device.
Have some work to do on the TMT power supply and have an opportunity to power up shortly.
Sad that Eric has had to discard the CIG attempt but there is still one being built with his assistance and looking forward to the results of that as well as my own.
Hendershot Generator:
Fully built and in the process of testing irrespective of the video being a scam as the basketweave coil detail was pretty close to the actual and had already made plans to build as I felt I knew what was manifesting in the basketweave coils.
Have replaced the Magnet and bell ringer coils with a small 4 volt split-reed Multivibrator which works well and now looking for a suitable transformer to work into.
Idea here is to find out where the energy manifests from and work from there - pretty obvious that voltage amplification is a key here and with either the buzzer or vibrator, should be able to go OU like Eric's PP-18/AR.
Feel the idea here is to grab the energy in the circuit before current flows and have it working with voltage only that can oscillate within the coils gaining more ambient energy.
Does this sound like Tesla?
May have to build a stainless steel sheet capacitor to lay inside the coil windings as the video cap sitting in the centre just made the video device look easier to build and working on that now.
Smokey
dR-Green,
379.5 uH
1.997 mH
321.6 uH
380.8 uH
Smokey
