Originally posted by P~0
Eric Dollard
This is a sticky topic.
The more the merrier
These were literally the first experiments of this kind, and it was raining at the time so no that was not done. The main purpose of this is to demonstrate that the energy is transmitted through the earth through keeping the coils at the same distance apart, and changing the location of the earth points. So everything else has to stay in exactly the same place which would not be possible with shorter leads. I wanted a certain distance between the coils because I already know what the sceptics would say if they were closer, so a certain wire length is inevitable in this case.Originally posted by brusers View Post@ dR-Green I'm curious, if you were to take the coils over into the grass area, and set them directly over the copper grounds you have there. Meaning, no ground lead, so there is no extra resistance or inductance etc.. along the ground path.. what kind of distance can you get with those? And how would it effect the tuning, etc? Not sure if that is possible for you, to get the transmitter outside.. but I thought I would ask.http://www.teslascientific.com/
The experiment has been improved because I was not happy with the quality of the receiving earth rods (dirty rusty old metal) and it was difficult to make good contact, perceivable things were not fully realisable. 20-22mm diameter copper pipes are now used instead. Details will follow. The transmitter has the original earth rod (clean) with the addition of a 20cm or so and 37cm lengths of copper pipe. All sections of pipe were cleaned with wire wool before use. Also this time there is an oscilloscope employed at the receiving end.
Video: Nikola Tesla Telluric Transmission Of Energy - Mk. 2 - YouTubeTransmission distance = 0.13 metres
Transmission distance = 0.37 metres
Transmission distance = 0.72 metres
Transmission distance = 0.97 metres
Transmission distance = 1.47 metres
Transmission distance = 1.98 metres (doesn't count)
Transmission distance = 3.46 metres (not in video)
Notes:
Many effects observed confirm that a bucket of soil accurately simulates a Telluric transmission situation, within obvious reason. Receiver is seen to respond even when standing on the ground around the transmitter earth terminal when holding a wire leading to the receiver in hand (and touching metal), and transmission will equally pass through human body when holding the wire to receiver in one hand and touching the transmitter earth terminal with the other hand. Laying the wire leading to the receiver on the ground around transmitter earth terminal also allows for reception of signal. This was to be filmed but the rains came again and this time the receiver was not sheltered so I was forced to abort.Last edited by dR-Green; 07-29-2013, 05:34 PM.http://www.teslascientific.com/
@ dR-Green, ok.. I remembered Eric saying grounding needs to be 1/3 wide as it is long, that is why I asked. Getting some on and off showers here in Finland too.. so I would be hesitant to take any equipment outside as well. Very nice videos btw, I think I forgot to mention that last time.
Marcel
I wonder if there's a way guy's like Eric Dollard and other Senior members could have a private thread room only viewable and available to themselves and by invite only, once they log in.They could vote additional members in or out of there room as they wish.Would take some additional security..... people could keep there study and work moving forward without intentional interuption.
just a thought,
Dan
Eric Dollard
Dan,Originally posted by teslasmyhero View PostI wonder if there's a way guy's like Eric Dollard and other Senior members could have a private thread room only viewable and available to themselves and by invite only, once they log in.They could vote additional members in or out of there room as they wish.Would take some additional security..... people could keep there study and work moving forward without intentional interuption.
just a thought,
Dan
That is certainly possible, but overall, there aren't a whole lot of disruptions in this particular thread. There will be some things coming to make it easier to study Eric's work - stay tuned.Sincerely,
Thanks Marcel. Yes I remember that too but I don't see how it's practical to do it without digging up floors and tunnels under walls or by building new buildings. The best I'll be able to do is put a star radial in the garden and drill a hole through the wall to run a (thick) cable through it to the centre rod. A wooden shed to house the coil in the middle of the garden would be the ideal thing. The earth cable I'm using now already radiates a signal, in fact the whole ground around the earth terminal radiates the signal, so I don't know whether the cable through the wall will be sufficient. I suppose it will have to be at the beginning at least.Originally posted by brusers View Post@ dR-Green, ok.. I remembered Eric saying grounding needs to be 1/3 wide as it is long, that is why I asked. Getting some on and off showers here in Finland too.. so I would be hesitant to take any equipment outside as well. Very nice videos btw, I think I forgot to mention that last time.
Marcelhttp://www.teslascientific.com/
T-Rex post recovered
This is the recovered post that David Webster deleted under pressure from Ray Savant - Techzombie. It contains Eric Dollard's response to finding out that Techzombie registered ericdollard.com without his knowledge or consent. The site was saying very wild things that could get Eric in trouble:
Ray requested that this post be deleted because Ray told him it would damage fund raising efforts. So, David deleted it.
As everyone knows, Techz Ray Savant is also posting in Facebook under Eric's name without his knowledge or consent - he is basically guilty of identity theft.
Eric is hopping mad and will say something soon about all these perpetrators.Last edited by Aaron; 07-30-2013, 04:05 PM.Sincerely,
Eric Dollard Live
Eric Dollard's live video interview starts at 11am Pacific time zone this morning. In 1.5 hours!
Thank you for your interested in the Eric P. Dollard LIVE video broadcast.
Below are the instructions on how to login - we recommend that you login at 1050AM Pacific Standard Time to reserve your seat. To see the LIVE video interview with Eric Dollard, it is limited to 100 people. If there are more people that than, we will give a phone number and pin code so you can hear it live on a phone conference call.
1. Please join my Webinar.
2. You will be connected to audio using your computer's microphone and speakers (VoIP). A headset is recommended.
Or, you may select "Use Telephone" after joining the Webinar.
Dial +1 (909) 259-0023
Access Code: 839-942-045
Audio PIN: Shown after joining the webinar
Webinar ID: 154-692-027
Thank you,
Eric P. Dollard - Official HomepageSincerely,
Eric P. Dollard interview recording
Audio coming - if anyone recorded audio or video, feel free to post it on youtube, etc...Originally posted by AMcG View PostFor those of us who could not login to the webinar. Is there a transcript or audio recording please?Sincerely,
Too bad there wasn't enough time for live questions. Oh well...maybe next time.Originally posted by Aaron View PostEric Dollard's live video interview starts at 11am Pacific time zone this morning. In 1.5 hours!
Thank you,
V'Get it all on record now - get the films - get the witnesses -because somewhere down the road of history some bastard will get up and say that this never happened'
General D.Eisenhower
http://www.nvtronics.org
Analog computer build
Great interview, and I appreciate taking my question. I understand Eric isn't equipped to make kits or anything like that right now and it's probably better all around for him and others to simply provide the information people can use to make their own from the ground up. I'd be interested in specific advice on how to do this for building dielectric lighting circuits and other applications, with the least cost in materials and complexity possible.
Thanks in advance for any advice anyone can provide as far as parts and wiring. I'd like to use a CCFL inverter producing approx. 1kV 30kHz AC from two serial 9V batteries as my input power source and transform or rectify from that as appropriate.
In the meantime I've got the Four Quadrant videos now to watch.
Thanks for the education!
