I wont argue that convention is the version you posted, I was talking substantially. Hence we are both correct.
In any case I am happy to see that you rephrased it to -t I presume referenced to t0, rather than "going backwards in time" since the time you decided to look backwards in time is in fact several intervals forward in time from point t0.
I am not sure how anyone has determined that you proved faster light longitudinal because if you did I must have missed it and so far I watched 3 videos you did with brown et al the bolinas, sbarc, and this 2007 video and seen nothing that I can credit to you on that matter, outside naked theory.
You did demonstrate the distinction however, at least as far as my knowledge base can tell between dimagnetic and dielectric.
In each video you made claims beyond that but as of yet I have not seen it demonstrated by you or anyone "building stuff".
The one that stopped me cold was how you came to believe current can flow without creating a magnetic field.
Now if you hit me up with TEM00 yeh ok I can buy that, but then we are still at the speed of light.
The next problem is how faster than the speed of light occurs because presumably [insert whatever label you want here] somehow jumps past the coil presumably via a capacitive manner and that it does so faster than any other capacitor. It simply does not compute and you have not offered anything as to how you came to that conclusion.
So we just need a few more things clarified with regard to your theories.
~fragment X
~fragment X
I asked my physics lecturer about this situation because I wanted to make sure that I wasn't talking gibberish about a principal which is pretty elementary and something he should be able to understand easily. My physics lecturer had no problem in understanding what I was saying here and he didn't need to stop me once and get me to clarify anything. He said aslong as I'm not claiming excess energy from this setup then my analysis of what is going on is correct. There will be an increased amount of power applied in a time which is the reciprocal to the change in power achieved.
