Hi Savvypro.
I used a cream separator to filter the water out from the algae, something like this:
You just pour in the algae medium in the upper hopper and the centrifuge inside separetes the water and solids. Water comes out theough one outlet and a cream like algae substance comes out the other outlet. Works very well, water comes out crystal clear. Only you need a large enough amount of algae medium for it to cole out as cream like substance, because if you have only a small ammount of total algae percentage, it wont even fill the centrifuge. I tried putting through 3 liters of algae water and the algae just barely filled the centrifuge and was not flowing over the edge through the outlet. Raw milk has high fat content, up to 20% and that gives a good cream yield, so the algae also must be in high concentrations in the water for the separator to work properly.
In a week or so I will upgrade to 1000L container with 60w LED floodlights.
My previous setup did not turn out to work well, even with several layers of epoxy, the water got to the contacts and some serious galvanic corrosion started. So don't make the same mistake. The floodlights on the other hand will be completely waterproof and will be able to give light and heat to the algae as well
Jetijs
Jetijs
