Water by slow drip via Wicking/Capillary
  • Water by slow drip via Wicking/Capillary
    This is about as CHEAP and easy as it can get.
    I think this probably would be a slower drip system than this one
    but I was thinking this would be best if used outside.
    No holes are made in the soda bottle and the bottle stands up right.
    Works by wicking or Capillary action see link.
    The water will wick upwards out of the top of the bottle, along a tube
    and then downward dripping into the tube and then onto the soil.
    I've done two tests so far:
    1) a toilet paper test where water wicked up the side of a glass jar to the
    height of about 7" if I remember correctly. I did that tests a few months ago.
    2) a toilet paper test inside a 1/2" O.D. hose/tubing (details below)
    3) I have NOT tested how high the wicking will go inside a tube.
    Unknown is if not fighting off evaporation would allow the water to
    climb a little higher.
    The tubing was stuck into the 1 liter soda bottle about 6". The water level
    was 3" below the top of the bottle. It wicks and drips water out the end of the hose.
    Sticking the tube into the bottle until it hits the bottom will work better.
    For my initial test I wanted most of the tube outside the bottle.
    You don't have to do anything to the cap .. keep it.
    How did I get toilet paper of 2 feet of toilet paper into that 1/2" tube?
    I used a thick gauge wire. Stuck it through the tube. Folded the bare copper
    wire over the end of the twisted up toilet paper and twisted as I pulled it
    through the tube.
    TRY USING PAPER TOWEL.. toilet paper is a pain to twist and isn't very
    strong. You'll have to cut the paper towel down to about a 2" in width or
    smaller for a smaller tube.
    I don't know, it might work with twine rope also.
    This ends up being kinda nice. You can stick the tube into the ground or
    pot and leave it there. Take the bottle to be filled up with water. If you
    leave the caps unmodified and tied to each bottle, then you can gather up
    you bottles with caps on, not wasting any water, top them all off and
    wheel barrel or wagon all those full of water bottles back to the hoses.
    And if need be you still have totally unmodified soda bottles with caps
    for other uses during non-growing months.
    For that matter you still have hoses/tubes too.
    This could probably save time watering plants. It works for extended
    leaves away from being able to water them.
    This is in case your water hose breaks, your water hose is too short or
    you do not want to use a water hose do to the waste of water.
    Or if you have planted far away from any water source, a secret garden, for example.
    Or you found some wild blue berries or something you would like to make
    sure has plenty of water. Wild critters might like a drink also .. so think
    about that part too.
    Plastic wrap/bag and wire would seal up around the neck of the bottle
    and tube to prevent water loss, if that becomes a factor.
    Have fun.
    Randy
    Remember if have waste/trash, you are not thinking.
    It's a resource, a surplus that needs a place where it can be put to use.
    Last edited by Vortex; 06-29-2009, 12:45 PM. Reason: added link to other slow drip system
    Kool idea
      Confirmed
      Confirmed: 1/4" O.D. tubing works with twine.
      This is less expensive than my first prototype.
      The twine can be run through using copper wire to pull it through the tubing.
      Yep even the twine that smells like some kind of petroleum product is on it.
      The 1/4" O.D. tubing can be pretty stiff. Shorter pieces do not wish to say in
      place. Another piece of twine can be used to tie the tubing into place, rap it
      a couple times around the tubing then tie if off around the bottle.
