Hi to all, new to this thread i am in Australia. A reply to Jes, your system does work if followed and people should read the article fully you wrote, instead of just skipping through it. Great work on your behalf. Also they should look at exactly what NikolaTesla said. I once read that you have to decifier his writings also for hidden clues.
One clue all aparratus of aerial collector should be vertically inline, my understanding is that the collector, antenna lead and ground should be directly vertical to one another as the radiant energy travels down from the collector and radially down the wire in a straight line. Chapter 5 page 140 PJK BOOK FREE ENERGY DEVICES. I suugest reading this book so you get more of an understanding of how it all works.
Another thing i would like to stress is that electricity kills very easy. For those who are connecting their earth from there modules to an earth socket in their house you are playing with fire. The earth connection in your house is connected to the neutral wire so your safety switchs take fault currents to ground. If your house earth connection is leaky there is potential that a fault current from a faulty appliance can be feed back through your earth connection on the radiant energy device on your bench using your earth connection as a ground. Here in Australia that is 240 volts which can be fatal. Please donot connect any part of this to your house electrical supply including the earth. Keep completly seperate.
If you connect to house wall socket earth and you get a voltage rise your house earth is leaking and not working correctly. If you have a dink of water from tap directly and get a tingle feeling your earth to ground for your house is faulty.
Tesla experiments where designed to be stand alone units that created electricity on their own without out side influence (FREE ENERGY) self explanatory.
To think back in the 1800's they found the ANSWERS without all the technology today and here we are today struggling to find the most basic of answers. Just imagine if Tesla had a 555 chip, but then again he didnot need it nor did all the others. Sometimes modern electronic components just cannot cut it, that is why they still use the old valves in really high quality amplifiers and high output electronics.
Thanks Cloud9 for your info. Regarding collector it should be sprayed too for insulation or can be left polished aluminium?
Thanks.
Made this setup with a 60cm squared collector and it seems to charge a 12v battery with two modules. Going to increase modules and see results.
Thanks Jes.
Did you spray with insulation, can you give us some details on your replication?
No I did not spray the collector. Collector is a sheet of aluminium about 50cm to 60cm squared attached on a piece of wood but insulated to the wood too. It's about one meter higher above a two storey building. My earth is in the basement another storey down. First tried it on one module and saw a little improvement on a small 12v battery. Then I added another module and more charge was coming.
Now I will add more and try the exact setup as Ascanius with two grounds and see.
... It's about one meter higher above a two story building. My earth is in the basement another story down. ...
Does your antenna wire go straight from the collector to the ground? Or is there a break in it, so there is no direct short circuit from Aerial to Earth?
If it is a direct short to Earth, through your house plumbing, I strongly suggest you read my message #70 on page 3 of this topic. I fear you just might suddenly get a surprise of more power than you want. Hopefully, that will be the worse you get. (You might consider doing some advanced packing of your household goods, assuming you aren't too physically close to the setup when the flash and thunder occur at the same moment.)
Rick
There's a break in it now but I will try it straight to ground too.
It is to a ground copper rod. Hope not about thunders
But I think if a thunder strike first it strike my tv aerial which is much higher than the collector
Thanks anyway about your attention to this.
is there any circuitry involved, or you just have a aluminum plate connected to one terminal of the battery and the other terminal connected to the ground?
What size was the battery? What was it's voltage before connecting, after 1 day, 2 days, etc?
It would be useful if you could try and measure the charge.
Yes circuitry is in Patrick Kelly Doc on Areal devices by Jes Ascanius.
Battery was small a motorbike battery. It's voltage was about 10.80v and when I measured it last was about 11.20v in 2days. This was with two module only.
Thanks.
I stumbled upon the PJK book and I want to actually build one of the devices described in the book. I am Electric Engineer and before College I was a TV repair man.
Now I have some free time and I want to use it building a "Free Energy Device" too see with my own eyes that such technology would work. And then to use it of course!
My first choice is this "Jes Ascanius Radiant collector" because it has no moving parts and does not make any noise. But I see 2 problems for me,
1) Where I live (Canary Islands) it is very dry in the summer time. So maybe the grounding would be worthless as all the soil is dry. But maybe it would help to give the grounding some water just like the plants. Also, the ground is very stony, even rocky, it would be impossible to rim a 3m pipe into the ground with just a hammer, some kind of machine would be needed.
2) Difficulties to get the Diodes. It's quite difficult to get these Germanium diodes. What I can get are 1N60 for 1,75EURO per unit. Well better than nothing, but... why not use SCHOTTKY diodes? They have similar properties like the Germanium diodes and are far cheaper.
I have not started yet, but these 2 questions came in my mind.
Hi Captain Kirk, or may I call you Jim
your ground quality is very similar to mine: stony and difficult to drive a pipe/rod into, however there is a solution to this. In his patent (685,958) Tesla shows the ground for his original apparatus as a PLATE, oriented in a vertical plane, just like the collection plate. If you dig a trench, as I have and install a suitably sized plate (I have used a steel plate 1000x500x6 mm) buried at a depth of about one metre and keep it watered to improve conductivity it should suffice. Good Luck.
Hi Guys inform on your results cause I'm still a bit doubtful on this circuit cause when I check it I only see 0.5v but on battery last time I was seeing it charging. Maybe there's something to the battery.
Or is it the wire I'm using cause I'm using a TV wire?
Я ДОЛГО ЧИТАЛ ВАШИ ПОСЛАНИЯ ДРУГ К ДРУГУ А ТЕПЕРЬ ХОЧУ СПРОСИТЬ:
для создания данной схемы необходимо:
1 лист алюминия 50*60см
2 провод моножильный сечением не менее 4мм2
3 2 конденсатора 220nF ~ 275v
4 2 конденсатора 100nF ~ 50v
5 диоды германиевые или Шоттки
6 заземление
7 труба медная
при таких условиях имеем 20-28v на выходе
все правильно?
Your schematis is wrong, the ground is connected thry D2, and all power coming from the aerial will go to the ground.
wait a min.
All here are using, a germanium diodes, and 1N type
1N34A............................
GENERAL SPECIFICATIONS
Peak Inv. Voltage(PIV): 60 Volts
Max. Average Rectified Current: 50mA @ 25 deg C
Junction Temperature (TJ): 100 deg C Max.
FWD Voltage Drop(VF): 1.0V @ 5.0 mA
Reverse Current: IR 15uA @ VR 10 volts
1N4148
IF 200ma
Vr 100v.
And all here are using a PLATE.......WHY.
If you want a sucess "YOU NEED a WIRE"..........
How is done..
First you need a metal plate well worked on drebong machine.
Or just use an old speaker, and remove magnet, juse just metal coil, Larger is better. Now wound a 2mm wire, to fill the all metal coil to the top, 200-500 turns, depends on coil.
Second build a pcb with elements like in picture.
Important: Do not use a 1N34 germanium or 1N4148 diodes, coz there are a low power diodes, you can not expect good result whit them.
Use Fast or Super fast diodes with more power.
Example: BYV29SI-D 500V7.4A<50ns, or
SF3006PT SuperFastDiode400V30A 35nsTO247AD,
or BYV32 2xSI-D 200V20A/230Ap25n, use only 2 of them(2 diodes in one case).
NOW you can expect an good result with voltage and amperage without droping.
Experiment with turns, more turns of the coil=more voltage, more thick wire=more amperage
And final when you assemble all, you do not need to climb the coil higher of the ground.
Best regards from Macedonia..
